Bucle de redirección SSO
Hey there,
we’re using Discourse [v2.3.0.beta2 +130] with SSO. For a few months now (sorry that I can’t pinpoint the exact update that caused the issue) collegues are reporting SSO redirect loops (followed by 429 errors which is ok) when clicking on discourse links in webmail clients. This only happens, if one is already logged in. We can reproduce in Firefox and Chrome on Windows and Linux. Steps to reproduce:
  • When logged out of discourse (all cookies cleaned etc)
  • Click on a Disourse link in Gmail or Zimbra
  • A new tab opens with the Discourse URL
  • After getting redirected to our SSO login enter your credencials
  • You get successfully logged in
  • Click on another Discourse link in Gmail or Zimbra
  • You get redirected to the SSO login
  • Then you get redirected back to Disrourse with the token in the URL
  • Then Discourse redirects you back to the SSO login
  • and so on …
Strangly this doesn’t happen if the link is copy/pasted instead of clicked on. This strikes me as weird.
These are the URLs in the loop
  • https:// forum.our.tld/
  • https:// forum.our.tld/session/sso
  • https:// sso.our.tld/sso/discourse?sso=bm9u…%3D%3D&sig=3944…
  • https:// forum.our.tld/session/sso_login?sso=bm9uY…1B%0AbmRyZWFz…Vhc19sYXV0X…JTQwZ2…dHAlM0ElMkYl…BBKitodHRw…pdG9y…rJTI4ZW…Vu%0AZGUr…9fdXJs%0APWh0…Nlc3Npb2…3D%0A&sig=13f4…
I found similar topics here but none of them is matching my exact problem:
Any ideas what might be wrong here?
I’d be interested to check the email provider responsible for sending emails on behalf of your discourse install, I’ve seen similar behaviour on a client when they accidentally enabled email tracking (which essentially rewrites the links) on the discourse emails.
There can be other potential candidates too which may need the forum link for identification.
Discourse is sending mails via our own mailservers. There’s no link rewriting or tracking involved.
I also suspected Gmail at first, but the issue is the same with Zimbra.
Did you check the email raw? Maybe something interesting can be found there.
But before I row this to the wrong bank, are those links actually being opened in a real browser or some sort of web-view
It’s a real desktop browser. Right-click → copy link location → paste works. A simple left-click opens a new tab and then hangs in the loop. I don’t know if some Javascript is interfering with what’s actually happening or if it’s just a target=blank.
I think You really need to check the email RAW for possible issues since the link being sent is correct.
I can even reproduce with this page:
<!doctype html>
<html>
  <head><title>foo</title></head>
  <body>
    <a href="https://forum.our.tld/t/title/3940/551">https://forum.our.tld/t/title/3940/551</a>
  </body>
</html>
When clicking on the link I’m in the redirect loop, if I copy/paste it it works.
I’m … puzzeled.
The only thing I can think of that’s different in a browser when clicking on a link vs. copy/pasting the link is the referrer.
Disculpa si estoy diciendo lo más obvio, pero veo el origen del problema en este asunto en WebKit WebView. Intenté los workarounds mencionados aquí en el foro de Discourse sin éxito.
Uno de mis colegas (él es programador web, yo no) sugirió cambiar algo en el proveedor de SSO (no myforum.com/session/sso_provider) para que, cuando llame al foro, envíe una petición GET en la cadena de consulta de la URL con un parámetro adicional login=mylogin. Probablemente la llamada para crear el token vaya de myssoprovider.com/sso?sso=xxxxx&sig=xxxxx a myssoprovider.com/sso?sso=xxxxx&sig=xxxxx&login=mylogin.
Pero, por lo que sé, no es posible implementar algo así desde el panel de configuración de Discourse; más bien requeriría un mod que incida más profundamente y que podría causar problemas o perderse en las actualizaciones.
Gracias por tus sugerencias.
¿Nadie tiene ninguna idea al respecto aparte de esperar a que Apple lo solucione?
Hola @nikod, tuvimos un problema similar en nuestra empresa y lo resolvimos configurando la opción de ‘cookies del mismo sitio’ en “lax” en lugar de “strict”:
