Paginação dos registros de ação da equipe
Any way to retrieve all the logs prior to the past few items? Couldn’t find a way to do that both in the API or on the website. Global export seems overkill for my purposes.
1 curtida
I don’t think that page supports pagination just yet.
@nbianca can you add that to your list? Low pri
5 curtidas
This has been implemented in
https://github.com/discourse/discourse/pull/7596
8 curtidas
awesome! thank you very much for that feature, much appreciated.
Best,
Alessandro
2 curtidas
