Ah yes, I forgot due to spam risks we disallow editing after {x} days. But deletion should still be allowed. Can you verify this is the case @techAPJ? Deletion is safe (at the rate limit) in a way that old edits are not.
It shouldnât be easy but at least it should be autonomous process to at least anonymize the user maybe with a catch that they will be given details on screen to read with all the warnings related to anonymisation and they canât create another account in future.
Just double checking: are you sure the admin understands what you are asking? I can see why an admin wouldnât want to delete, so asking for deletion may have set them off in the wrong direction. So make sure they understand that you are asking for anonymization and that they understand that this means that all the content will remain (you never know).
If itâs a discourse forum, you can also point out how easy it is to actually do what you are asking (perhaps even send step-by-step instructions).
The fact is that itâs just one admin and isnât responding to the messages that are sent from my account.
So start a public topic tagging them and mention that youâre unsure they received your PM attempts!
Will try that (hoping it works)
Post deletion is not allowed if post_edit_time_limit is passed. That setting defaults to 60 days (86400 minutes). Here is the description of the setting:
The author can edit or delete their post for (n) minutes after posting. Set to 0 for forever.
As a baby step in this direction we might allow deletion since that is less risky than editing (and itâs rate limited, or should be anyway). The intent of the setting is editing as you may have noticed: post_edit_time_limit
Added on my list to allow post deletion regardless of the setting post_edit_time_limit and verify that post deletions are rate limited.
If you are planning to have member editing and member deleting separate, rather than a âregardlessâ please have it have a separate time limit setting. Deletion of posts mid-topic could render it more difficult to read if not completely trash the topic.
Irrelevant, this can already happen and effectively does not. Remember itâs âintent to deleteâ not an immediate delete. Try it!
Done via:
Also verified that post deletions are rate limited. Three post deletions are allowed every one minute, should we make it more aggressive? Or at least add another hourly rate limit?
Probably a daily limit is more sensible.
I would say this almost qualifies as a GDPR-notable change cc @riking @gerhard
It was basically accidental that we prevented old post deletions after {x} days when the setting was called post_edit_time_limit ⌠never âdeleteâ. That might be because upon delete, the post is edited â by the system, not the user â to say
(post retracted by author, will be deleted in 24 hours unless flagged)
prior to delete. You can see where that might have (wrongly) gotten caught in the edit logic.
So does it still do that after the change so that people have a chance to flag? (I know thatâs not what OP was concerned about, but in a more normal forumâŚ)
As I said, this has been allowed forever with rate limits, and we historically donât have an actual de-facto real world problem with it on live sites.
Beyond that, GDPR even more explicitly allows this, and within the constraints of rate limiting, I agree with it too.
Added daily rate limit of 50 via:
Should we make this a site setting configurable by admin?
Yes definitely make it a site setting in the rate limits section.
A post was split to a new topic: Post deletions rate limit per day not working
