Stats reports on a per-category basis?
Hi folks, wasn’t able to find this discussed previously.
Is there a way to generate reports (pageviews, topics, posts) on a per-category basis?
We created a new category that’s generating interest from our community, and we’d like to see its growth curve over time as we make people aware it’s there.
Would that be possible? Could that be done by 1) customizing the stock Discourse reports UI, or 2) by using analytics tools on my end to look at the Discourse database through the API?
Check out the Data Explorer plugin.
You can use this to generate reports from SQL queries, here’s a query that will capture some of what you want to track.
-- [params]
-- date :start_date = 2020-04-01
-- date :end_date = 2020-04-29
SELECT c.id category_id, COUNT(DISTINCT(t.id)) topics, COUNT(p.id) posts, sum(p.like_count) likes, sum(p.reads) reads
FROM categories c
INNER JOIN topics t ON (t.category_id = c.id)
INNER JOIN posts p ON (p.topic_id = t.id AND p.post_type = 1)
WHERE p.created_at BETWEEN :start_date AND :end_date
GROUP BY c.id
ORDER BY COUNT(p.id) DESC
You can share these reports with groups via the Data Explorer UI:
And it will appear in the group page like this:
7 个赞
谢谢你,这正是我需要的(也让我更深入地研究了可以查询的内容)。我在 SELECT 语句中添加了以获取主题回复的数量
 sum(t.reply_count) replies,
