Status Page (Atlassian)
The Status Page (Atlassian) theme component for Discourse is available for installation. It pings a public-facing Atlassian Status Page’s .json endpoint to alert forum users when systems are down. The component has several settings, including messages for different status indicators (minor, major, critical) and a test mode.
@downey suggested displaying separate messages and using different CSS classes based on the StatusPage API indicator values. @jordan-vidrine implemented this feature, allowing for customization of messages and background colors for each indicator. The update also includes a test mode with customizable indicators.
The theme component is maintained by the Discourse team, and support, bug, and feature requests can be made on Meta, tagged with status-page-atlassian.
:discourse2: Summary Status Page (Atlassian) will ping your Public Facing Atlassian Status Page’s .json endpoint and alert forum users when system(s) are down.
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-atlassian-statuspage
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
Add the .json endpoint for your system into the status endpoint textbox in the component settings. When a system is down, your custom message will appear at the top of the forum.
How can I find my public-facing Status Page endpoint?
  1. Visit your websites stauts page in a web browser.
  2. Open the network inspector and refresh the page.
  3. Look for status.json in the list of requests being made and hover over it , it should give you the .json endpoint.
Settings
Name Description
failed status test Turn on to test statusPage failure
test status message Message to display when status is down
test status indicator Indiactor to use when testing statusPage failure.
minor status message Message to display when status is down with a minor indicator
major status message Message to display when status is down with a major indicator.
critical status message Message to display when status is down with a critical indicator.
status endpoint The .json endpoint to make a call to for your sites statusPage. ex. ‘https://status.yourWebsite.com/api/v2/status.json’
status more info link Webpage to send users to upon clicking the ‘Status Down’ alert link.
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
If anyone is eager to do a little work on this theme component, we got some feedback that it would be nice if there was the ability to display separate messages (and perhaps have different CSS classes) based on the various values of the indicator returned by the StatusPage API. (Which are minor, major, or critical, and it turns out there’s also an undocumented value of maintenance as well.) :heart: :nerd_face:
That’s really good feedback! I can definitely look into the possibility of using different statuses to determine how it displays. I’ll add this to some things I’ll be looking into when my current list clears up.
Thanks for the suggestion :+1:
I have pushed a small update to allow the features you mentioned. You can now set up a message for minor, major, critical indicators separately.
Each indicator also changes the background color of the status page alert.
You can also specify which indicator you would like to see when putting the component into test mode.
Minor
Major
Critical
Looks great; thank you! Especially appreciate the unique CSS class for each level so we can get the colors just right.
