What URL should we monitor to be sure Discourse is up
We are using Zabbix as monitoring tool for our infrastructure.
Standard templates give us status of, memory consumed, disk space, processors usage etc.
Sometimes these parameters looks good on monitoring system but Discourse simple does not work as should.
Is there any endpoint or something similar which is going to tell us that Discourse has problems.
How do you monitor your instances ?
We have an http endpoint for this, I can’t remember its path at the moment.
@adopilot the endpoint you are looking for is /srv/status . Should reply “ok” if everything’s good :wink:
