Still seeing issues. How to use “the fix”?
Users are troubleshooting a Discourse site that went offline after a rebuild, following a PostgreSQL upgrade. David Taylor advised running ./launcher rebuild app to apply the fix, but some users report errors like missing or failed substitutions involving postgresql--pgvector, PG_VERSION, and /etc/postgresql//main/*. supermathie notes that Docker version 20.10.5 is deprecated and may be contributing to the issue, and recommends checking PG_VERSION and backing up data immediately. pfaffman clarifies that #installation is for self-hosters with broken sites, not fresh installs, and warns that reverting changes is not possible without a server backup. They suggest moving to a new droplet with a fresh install and restoring from a backup — or using rsync to migrate the site to a new VPS for testing before switching DNS. The consensus leans toward migration over repair, especially if no backup exists.
Continuing the discussion from Site offline after rebuild (4th Feb 2025):
How do I implement “the fix”?
You rebuild.
Each of these indicates a failed or missing substitution - I haven’t read over all of the previous posts but I see a LOT of people on Docker version 20.10.5 are having trouble:
This might be a cause of the problem.
Did you take a backup of the server first? Can you revert back to before you first tried the upgrade?
If not, I’m sure all of the data is still there,
Regardless, take a backup of it now.
What do you see if you:
cat /var/discourse/shared/standalone/postgres_data/PG_VERSION
At some point they decided that Support was for help with using a working Discourse site and #installation was for help for self-hosters who don’t have a working discourse site. It’s not help with installation, but help with your installation, whether it exists or not. So it’s installation as a noun rather than a verb. I was confused the first dozen times they did it to me too. :person_shrugging:
You can’t. There’s no going back. (Unless, perhaps, you have a backup image of the whole server.)
I thought I’d seen that you’d reverted to some old server image and your site was running again? Or maybe that was someone else.
You can answer the above questions and maybe Michael can help you. I think that it will be much faster, easier and safer to move to a new droplet. If you have a recent discourse backup ,you can just do a fresh install and restore that backup there. If you don’t, you can follow the Move a Discourse site to another VPS with rsync instructions and try the upgrade there. You have nothing to lose since your existing site will keep functioning. If you find that it works, then you can stop your old site, run the rsync command, do it again, and then switch the DNS.
