Move a Discourse site to another VPS with rsync
This method is different than restoring file in UI.
Maybe there is a more downtime but it’s simpler for linux folks without Discourse knowledge and it’s easy to automate.
Prepare new VPS
First, prepare our new Current Ubuntu LTS VPS with empty Discourse dir, OS upgrade and Docker install
sudo mkdir -p /var/discourse
sudo apt-get update
sudo apt-get dist-upgrade
wget -qO- https://get.docker.com/ | sh
Then, make sure that we are on latest installed kernel and other libraries by just restarting
sudo reboot
Copy files to new VPS
Let’s copy all Discourse files, this first sync pass will reduce our downtime later.
On our new VPS let’s run
rsync -rvz example.com:/var/discourse /var
where example.com is our old VPS with forum files.
This may take a while so grab some favourite drink.
Turn off current forum and sync again
After first sync pass, turn off forum on old VPS via
cd /var/discourse/
./launcher stop app
Now when forum is stopped, let’s run sync on new VPS again
rsync -rvz --delete example.com:/var/discourse /var
--delete makes sure that will be 1:1 copy
Start forum on new host
After final sync we can finally run Discourse.
Rebuild and start container.
This may take a few minutes.
./launcher rebuild app
Done!
All settings, posts, threads, backups were copied to new location, no UI interaction was needed.
How to migrate the discourse container to another machine
Self-Hosting Advice
Make (temporary) use of Network Storage for Restores, PSQL Update,
Upgrading v2.2.0.beta4 forum with unknown local changes
500 Error trying to upgrade discourse
Rebuild fails: Data directory /shared/postgres_data must not be owned by root
Discourse-chat-integration prevents upgrade
Old installation failing upgrade
Discourse Randomly Does Not run or Rebuild
Hanging on app rebuild
Another discourse offline "bootstrap failed with exit code 5"
Failed to upgrade 3.1.0 Beta7 to 3.2.0 Beta3 as of 12/31/2023
I can't start a Discourse
Discourse offline after failed upgrade "bootstrap failed with exit code 5"
What to be aware of when updating an old Discourse version to the latest?
Stuck with 500 error after weird bugs and a rebuild
Update Fails with Unexpected Error During Rebuild
Determining whether my VPS needs any upgrades (generally)
Set up a staging server
Problems rebuilding app
SSL on new host
Move topics from one Discourse instance to another
Docker Upgrade Removed AUFS Storage Driver, Killed Discourse
Can't get Ruby to update so ./launcher rebuild app keeps failing
Backup Prod -> Snap -> Build Test -> Change Address
Update/Rebuild Error Code 1 (3.1.0.beta4 -> 3.3.0.beta3) - Redis port 6379 related?
Help with e-mail and service update
Site upgrade insisting on database upgrade after manual db upgrade
Upgrading Discourse: Multiple failures
Can I just tar the whole /var/discourse and run it on a new server?
Database files are incompatible with server (updating inside Linode)
Update “3.4.0.beta4” failed
Stuck and lost updating forum, problems with PG migration
Specifically for 3.4.0.beta4 -- what are the system requirements?
Trying to update Docker on DigitalOcean; stuck on Docker 19.03.13 😔
Discourse Update/Upgrade dependency check
Update broken stuck on Docker version
Welcome to nginx! page before rebuild, site won't rebuild now
Unable to upgrade to PostgreSQL 15/
My install is 16,359 commits behind! Advice?
How to manually migrate s3 files to local?
How to properly package discourse as an image
Cannot upgrade / send emails / fetch themes... Docker problem?
Major upgrade -- best practices?
Move your Discourse Instance to a Different Server
Upgrading from 2.6.0.beta1 to latest stable
Pause images optimization upon restore to new instance of server
Ältere Discourse Produktiv-Instanz 1:1 auf Testserver Migrieren
Trouble updating discourse after some time - UPGRADE OF POSTGRES FAILED
One server for 2 Discourse communities?
Admin/Update screen is blank. How to manually updtate docker via SSH Console?
Moving to New Server woes
Database access issues after upgrade v3.5.2 -> v3.6.0.beta2
Proper way to upgrade docker OS (bullseye)
Upgrade fails (again :) )
Sysadmins Index
Change server to a two-container setup
Discourse Update Error: Your Docker installation is not working correctly
Still seeing issues. How to use “the fix”?
This should really be:
rsync -rvz example:com:/var/discourse /var
Otherwise, you’ll end up with a discourse directory under /var/discourse.
Update: After doing this, all images in Assets for Site Design are now broken. Any ideas, what’s going on? @codinghorror Here’s our site: https://discuss.dgraph.io/
True, my mistake, forgot to add slashes,
Edited and fixed :slight_smile:
Did you modified links config somehow?
No. Didn’t modify any configs. All the previous assets don’t load. But any new ones that we add work just fine. The files are definitely there.
Check permissions and owner of assets.
So, the permissions are okay, owner ubuntu and group www-data. The real problem I just identified was that I think I must have changed the settings for the static resources to upload to Amazon S3. So, all the new resources are going there, and that’s where discourse is probably reading them from.
So, it’s no longer looking at the stored data in /var/discourse/shared/standalone/uploads.
Btw, so 2 things:
  • Is using S3 for static resources not recommended?. I understand it’s not deprecated, but checking to ensure we’re following the recommended setup for discourse.
  • If it is recommended, what’re my options? I suppose I could just upload all the existing assets on disk to S3. Then, we should be able to retrieve them just like before. Right?
You have an answer then :slight_smile:
I think this questions belong to other topics.
OK, not sure if the instructions here are out-dated or anything.
I have a forum that I mucked up the O/S. So, like a good cloud citizen, I spun up a brand new shiny Ubuntu 17.10 VM and followed the above instructions.
First thing that I found out immediately is that I need to be root to rsync the files. The rsync command came back with a pile of permission denied errors without copying anything.
Turns out that /var/discourse is owned by root (thanks to sudo mkdir -p /var/discourse in the instructions). Nothing a little hack won’t fix, so I did sudo chown 777 /var/discourse and did the rsync again.
This time it copied most of the files (but unfortunately all owned by me instead of root… probably needs a chown somewhere down the line).
The PostgreSQL files won’t copy and came back as permission denied. I checked the directories on the remote machine and lo and behold those directories are accessible only by root, not by mere mortals.
Using sudo on the rsync didn’t work either because it then asked for the password for root on the remote machine, which is also Ubuntu and thus root doesn’t have a password.
At the end, I gave up and installed a brand new Discourse installation then restored from backup.
I think the above instructions need serious rework especially wrt file ownerships and permissions.
To perform an rsync as root on the sender and as ubuntu on the receiver, put ubuntu@ I’m front of the host, like this:
rsync -rvz ubuntu@example.com:/var/discourse /var
Will that copy the entire tree under the same owner as well as the same permissions?
I suppose rsync preserves permissions, but will it work if all the files are copied under root? I can see that the PostgreSQL data files are owned by some other user etc. And obviously the uploads and backups directories are owned by the admin user, not root.
It won’t be able to preserve the permissions in this case, because ubuntu can’t just change the files it be owned by root.
In this case I wonder whether, after copying the directory tree, it will just work?
Next time I muck up something and have to move to a fresh VM, I’ll try it out! :sweat_smile:
I’m not exactly an rsync guru, but why not copy from as root and to as root, and use the -p switch to preserve permissions?
Apparently, rsync with -g and -o flags, while running as root, can preserve owners and groups. -p with rsync preserves permissions.
So technically speaking… we’ll want rsync -rvzgop ?
The VM is set up to not allow you to SSH in as root directly.
Both of them? i.e. can you “pull” as root from the node which you can’t login directly to as root?
(Like I wrote, I’m not the sharpest knife in the drawer.)
Apparently it may be possible:
I have a very active site I wanted to quickly move over so I decided to use this rsync method rather than the backup/restore approach which is the standard recommended one. (I am also out of disk space on the old node for backups…) There were a few glitches in the above guide so I wrote out my own steps for future reference and thought others might be interested.
The main things I changed from the above is to always do root-root ssh (both of my trees are owned by root), and to use -avz as the rsync parameters — the -a is the archive mode and will preserve dates on files as well. Without -a the second rsync to only update changed files will have to sync all the files again anyway, saving no time at all. With -a in both runs the --delete run of rsync should only take a few minutes.
So here is the plan
  1. Set up the new node as above or however you do it. Make sure you run discourse-setup to generate a default app.yml file which has good parameters for your new machine. (Make sure to set this file aside so step 5. and 8. below don’t overwrite it.)
  2. (24 hours in advance) On your DNS provider page set DNS TTL to a small value on all IPs that will move. The default is often 24 hours, set to 5 minutes. This will let users see the new site sooner. Set up new.example.com as a public name for the new site IP for easy access.
  3. enable root login on new site — make sure line
    # PermitRootLogin no
    in /etc/ssh/sshd_config is commented out on new, if not comment and re-start sshd -
    service ssh restart
  4. Set up ssh key for old-root to new-root login via the usual method (ssh-keygen in the home dir of root user on both sides, move old public key to authorized_keys on new, etc). You can of course use password login instead but it is less secure.
  5. Perform initial rsync while logged in to old (old forum can still be running):
    sudo rsync -avz /var/discourse new.example.com:/var/
  6. Post a message on board that example.com migration is starting in X minutes and site will be down for an hour or so. You could suggest they could temporarily use new.example.com if the site continues to not load. (The latter suggestion is for the cases where their DNS is not getting refreshed like it was supposed to). Note they will need to re-log-in on the new site so you may want to also mention that.
  7. sudo ./launcher stop app
    on old site to shut it down (permanently we hope).
  8. Followup rsync --delete run on old to get any changes since previous rsync:
    sudo rsync -avz --delete /var/discourse new.example.com:/var/
  9. edit app.yml for configuration changes on the new site. This is basically a merge of your old app.yml and the default one you made in step 1. above, which sets the cache, workers, etc parameters based on your new machine.
  10. sudo ./launcher rebuild app on new site to fire it up
  11. If it works, change DNS for all *.example.com (for me I also had mg.example.com for mailgun) to the new IP.
  12. (If it failed, sudo ./launcher start app on old site and try again later.)
  13. restore TTL on DNS.
  14. disable root login on new.
Note I am not running a CDN or https and there are may be other steps needed for those.
Unless CDN is using an ip number rather than the hostname there is nothing to change there.
There no reason not to enable let’s encrypt.
If the new host has different ram and cpu resources, discourse-setup will update the memory settings.
On my old machine I was running three different web servers, thats the reason https was not enabled. Yes I know I could do it but it is a lot harder with proxy servers in the middle. Its also one reason I did the move, now I have a completely vanilla install so I can easily enable https. Vanilla is a good flavor :slight_smile:
Good point about discourse-setup updating various settings … I merged the new machine parameters into my old app.yml during step 9 above. The default app.yml also was slightly revised in other minor ways, and I could also incorporate those changes into my config. I did this before step 7 and put the file aside and plopped it in for step 9, avoiding the need to be contemplating settings while the site was down. Will edit the above to mention this.
The whole changeover (step 7 to having new site up) took 20 minutes and DNS was working for me 10 more minutes later.
