Opslaggebruik
Tried searching, didn’t find something similar.
Is there a way to generate a report of storage usage by user?
I run a very small discourse community- around 20 really active users, and around 40 total folks.
I bear the cost myself, which is fine.
I’d like to be able to do something like:
User A 1GB upload
User B 10GB upload
User C 100 GB upload
To have a relative reference on who is driving storage cost.
Any ideas?
Would something like this fit the bill?
SELECT
    user_id,
    ROUND(SUM(filesize)/1048576.00,1) AS "Storage (MB)"
FROM uploads
GROUP BY user_id
ORDER BY 2 DESC
LIMIT 100
I will give it a try, thank you!
You could conceivably make a custom badge that used something like the suggested query to give people a badge when they hit each of the thresholds.
