I have two S3 buckets, one for backups one for uploads. I have one user/policy for both with full s3 access. I have both uploads and backups set to go to s3. Strangely, I can make a backup and it will end up on s3, but any kind of image upload or attachment attempts give Access Denied errors.
I have tried rebuilding. I have created new buckets and policies. None of that has helped.
This also seems to prevent adding Gravatar images. Sidekiq has a bunch of pending tasks saying:
Jobs::HandledExceptionWrapper: Wrapped Aws::S3::Errors::AccessDenied: Access Denied
I can manually add things on the AWS site to the uploads bucket. Also can do the same using the aws cli tool.
Any thoughts?
Output from the logs:
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-core-3.27.0/lib/seahorse/client/plugins/raise_response_errors.rb:15:in
call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-s3-1.19.0/lib/aws-sdk-s3/plugins/sse_cpk.rb:22:in
call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-s3-1.19.0/lib/aws-sdk-s3/plugins/dualstack.rb:26:in
call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-s3-1.19.0/lib/aws-sdk-s3/plugins/accelerate.rb:35:in
call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-core-3.27.0/lib/aws-sdk-core/plugins/jsonvalue_converter.rb:20:in
call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-core-3.27.0/lib/aws-sdk-core/plugins/idempotency_token.rb:17:in
call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-core-3.27.0/lib/aws-sdk-core/plugins/param_converter.rb:24:in
call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-core-3.27.0/lib/aws-sdk-core/plugins/response_paging.rb:10:in
call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-core-3.27.0/lib/seahorse/client/plugins/response_target.rb:23:in
call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-core-3.27.0/lib/seahorse/client/request.rb:70:in
send_request' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-s3-1.19.0/lib/aws-sdk-s3/client.rb:5498:in
put_object' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-s3-1.19.0/lib/aws-sdk-s3/file_uploader.rb:42:in
block in put_object' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-s3-1.19.0/lib/aws-sdk-s3/file_uploader.rb:50:in
open_file' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-s3-1.19.0/lib/aws-sdk-s3/file_uploader.rb:41:in
put_object' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-s3-1.19.0/lib/aws-sdk-s3/file_uploader.rb:34:in
upload' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/aws-sdk-s3-1.19.0/lib/aws-sdk-s3/customizations/object.rb:308:in
upload_file' /var/www/discourse/lib/s3_helper.rb:28:in
upload' /var/www/discourse/lib/file_store/s3_store.rb:48:in
store_file' /var/www/discourse/lib/file_store/s3_store.rb:22:in
store_upload' /var/www/discourse/lib/upload_creator.rb:126:in
block (2 levels) in create_for' /var/www/discourse/lib/upload_creator.rb:125:in
open' /var/www/discourse/lib/upload_creator.rb:125:in
block in create_for' /var/www/discourse/lib/distributed_mutex.rb:34:in
synchronize' /var/www/discourse/lib/distributed_mutex.rb:5:in
synchronize' /var/www/discourse/lib/upload_creator.rb:36:in
create_for' /var/www/discourse/app/models/user_avatar.rb:41:in
block in update_gravatar!' /var/www/discourse/lib/distributed_mutex.rb:34:in
synchronize' /var/www/discourse/app/models/user_avatar.rb:14:in
update_gravatar!' /var/www/discourse/app/jobs/regular/update_gravatar.rb:12:in
execute' /var/www/discourse/app/jobs/base.rb:137:in
block (2 levels) in perform' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.4/lib/rails_multisite/connection_management.rb:63:in
with_connection' /var/www/discourse/app/jobs/base.rb:127:in
block in perform' /var/www/discourse/app/jobs/base.rb:123:in
each' /var/www/discourse/app/jobs/base.rb:123:in
perform' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:187:in
execute_job' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:169:in
block (2 levels) in process' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/middleware/chain.rb:128:in
block in invoke' /var/www/discourse/lib/sidekiq/pausable.rb:81:in
call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/middleware/chain.rb:130:in
block in invoke' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/middleware/chain.rb:133:in
invoke' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:168:in
block in process' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:139:in
block (6 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/job_retry.rb:98:in
local' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:138:in
block (5 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq.rb:36:in
block in <module:Sidekiq>' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:134:in
block (4 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:199:in
stats' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:129:in
block (3 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/job_logger.rb:8:in
call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:128:in
block (2 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/job_retry.rb:73:in
global' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:127:in
block in dispatch' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/logging.rb:48:in
with_context' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/logging.rb:42:in
with_job_hash_context' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:126:in
dispatch' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:167:in
process' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:85:in
process_one' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/processor.rb:73:in
run' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/util.rb:16:in
watchdog' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.1.3/lib/sidekiq/util.rb:25:in
block in safe_thread'
merefield
(Robert)
December 23, 2018, 5:14pm
3
If you see Access Denied, it may well be that it is indeed, denied.
I had a simliar issue recently, you need to loosen access restriction on AWS just enough to resolve it.
The S3 user has all access to all buckets. (Uncertain why backups work but not upload.)
merefield
(Robert)
December 23, 2018, 5:17pm
5
Mine was working fine for ages then broke, but modifying the access rights resolved it.
Somewhere there was a change.
Getting an Access Denied issue in error log … which seems to be causing Sidekiq to stay paused after backups!! (which is interesting on its own) - is my access policy on IAM not generous enough?:
"Version": "2012-10-17",
"Statement": [
"Effect": "Allow",
"Action": [
"s3:GetBucketLocation",
"s3:ListAllMyBuckets"
"Resource": "*"
"Effect": "Allow",
I can try, but this is my current policy:
"Statement": [
"Effect": "Allow",
"Action": "s3:*",
"Resource": "*"
So the user should be able to do anything.
Tried again with this, same issue - backups work but uploads do not:
"Statement": [
"Sid": "VisualEditor0",
"Effect": "Allow",
"Action": [
"s3:PutAccountPublicAccessBlock",
"s3:GetAccountPublicAccessBlock",
"s3:ListAllMyBuckets",
"s3:ListBucket",
"s3:HeadBucket",
"Resource": "*"
"Sid": "VisualEditor1",
"Effect": "Allow",
"Action": "s3:*",
"Resource": [
"arn:aws:s3:::gauntlet-forums-backup",
"arn:aws:s3:::gauntlet-forums-storage",
"arn:aws:s3:::gauntlet-forums-backup/*",
"arn:aws:s3:::gantlet-forums-storage/*"
"Sid": "VisualEditor2",
"Effect": "Allow",
"Action": "s3:*",
"Resource": "arn:aws:s3:::*/*"
Tried it with the policy in your post and in Setting up file and image uploads to S3 - still no dice.
Fixed typo. No change. Still not working.
gerhard
(Gerhard Schlager)
December 23, 2018, 7:25pm
11
Is your uploads bucket empty? Delete it and let Discourse create the bucket. Also, make sure you follow the instructions in Setting up file and image uploads to S3 .
Huzzah! Deleting the bucket fixed it! Thanks for that!
gerhard
(Gerhard Schlager)
December 23, 2018, 7:33pm
13
That’s so weird. I’ve seen that outcome a couple of times in the last few weeks. I’m not sure what’s going on with manually created buckets yet.
Strange to be sure… I swapped out that highly-permissive policy for one made from the two posts referenced and things seem good now too.
deleted the bucket from where? I have not been able to upload images on my forum too…
pfaffman
(Jay Pfaffman)
December 23, 2018, 7:55pm
16
I had trouble getting uploads to work with digitalocean spaces yesterday, also with an error about the bucket already existing. I ran out of time before I could fully diagnose its. 'tis the season.
I deleted the bucket from S3 and let Discourse create it itself.
zogstrip
(RĂ©gis Hanol)
December 24, 2018, 10:48am
18
I think that’s because S3 changed their default permission settings.
The settings when I create it manually
The settings when Discourse creates it
My settings are same with the discourse permission settings, yet images won’t upload.
Inspect elements shows something like "failed to load resource …
gerhard
(Gerhard Schlager)
January 4, 2019, 1:40pm
20
jidetheblogger:
images won’t upload
Are you sure? You should see an “Access Denied” error if the upload fails. I thinks it’s a problem with a policy or CORS configuration. According to your screenshot the bucket permissions seem correct (both checkboxes under the “Manage public access control lists (ACLs)” are unchecked) and you “failed to load resource” looks like the browser simply isn’t allowed to load the image.
I’ve updated the instructions in Setting up file and image uploads to S3 . Maybe it helps you find the difference in your S3 bucket configuration.
