Preso no Docker atualmente durante a atualização
I was upgrading the docker via web xxxx/admin/upgrade
I clicked upgrade and left the webpage.
After a few days, I found the web page stuck there. It shows that the docker manager is still “currently upgrading”.
If I click “Reset Upgrade”, I get a warning message:
WARNING: You should only reset upgrades that have failed and are not running. This will NOT cancel currently running builds and should only be used as a last resort.
Should I just reset the upgrade process?
Reset upgrade
Then upgrade again.
If that doesn’t work,
SSH into Your server and rebuild
4 curtidas
