rehe
(Miguel)
31 באוגוסט, 2017, 11:03pm
1
Hi!
Since the last update I have seen something that does not work well. Any content inside a Summary is not displayed (image, youtube video, gif, mp4, etc.), only the link is displayed. Before this did not happen, the Summary content was displayed correctly.
Any ideas?
Thanks!
Edit:
Okay, I see that the same thing happens here too
Summary
לייק 1
rehe
(Miguel)
31 באוגוסט, 2017, 11:06pm
3
jomaxro:
I can repro.
I do not understand. Sorry, my english is very bad!
jomaxro
(Joshua Rosenfeld)
4
My apologies. Repro is short for reproduce. I was confirming that I can follow the steps you provided and make the issue you’ve reported occur myself.
5 לייקים
xrav3nz
1 בספטמבר, 2017, 1:44am
5
Not sure if this is related, but I just stumbled upon a similar issue:
I have an empty quote
… or do I?
[details="I have an empty quote"]
[/details]
Weirdly, this works fine on the preview panel inside composer.
4 לייקים
rehe
(Miguel)
2 בספטמבר, 2017, 8:11pm
6
I have updated to the latest version and the bug is still present
coderberry
(Eric Berry)
8 בדצמבר, 2017, 10:03pm
7
This is a test to see if it’s still an issue:
Summary
2 לייקים
coderberry
(Eric Berry)
8 בדצמבר, 2017, 10:04pm
8
It appears this has since been fixed for new summaries? It’s odd that it hasn’t retroactively fixed the other examples above on this thread.
I’ll dig in a little bit and see what I can find.
Why is that odd? Posts are baked into HTML once, at post time, to save server time. They reflect the state of the code as of post time. If you want to rebake a post (and have mod / admin access), select the wrench menu and then rebake.
There’s also a global rebake rake task for all posts.
לייק 1
coderberry
(Eric Berry)
8 בדצמבר, 2017, 10:16pm
10
Ah. I wasn’t aware. Sounds like this is a closed issue then
2 לייקים
jomaxro
(Joshua Rosenfeld)
9 בדצמבר, 2017, 2:10am
13
Hmm…I don’t think the bug originally reported is fixed. The report was for a oneboxed image failing in a details block.
This is an imgur link:
This is the link oneboxed:
This is the link in a details block:
[details="Summary"]
[/details]
This is the details block:
Summary
Oneboxing is still not happening inside details.
4 לייקים
cpradio
(cpradio)
9 בדצמבר, 2017, 3:57am
14
As a work around, they can use (note the empty lines above and below the image line)
<details><summary>Test</summary>
</details>
Which produces
Test
2 לייקים
jomaxro
(Joshua Rosenfeld)
9 בדצמבר, 2017, 3:58am
15
Edited my post, still not working. Strange that the HTML details works but the bbcode details doesn’t.
2 לייקים
coderberry
(Eric Berry)
11 בדצמבר, 2017, 9:48pm
16
I’ll take a stab at fixing this.
@jomaxro I just want to confirm: Expected behavior is we do not need to use markdown to display images inline, correct?
For example, this should show the image inline:
[details="Summary"]
https://i.imgur.com/CCNdQ8e.jpg
[/details]
As well as this:
[/details]
לייק 1
jomaxro
(Joshua Rosenfeld)
11 בדצמבר, 2017, 10:34pm
17
@coderberry , that’s my understanding, yes. If that imgur link “expands” outside of a details block, it should expand the same inside.
2 לייקים
