Suppress category from Latest top menu only [1.5.x]
AI 生成的摘要
Users are discussing an issue in Discourse 1.5.x where suppressing a category from the homepage does not also exclude it from the /latest page, contrary to expectations. mr8 reports that while the setting hides the category from /categories, topics still appear under /latest — a regression from 1.4’s |latest,-Category Name| behavior. cpradio confirms the bug occurs when /categories is set as the homepage, not /latest. codinghorror initially disagrees but later acknowledges the issue, suggesting suppression should apply to both pages. mr8 proposes separate options: suppress from latest and suppress from categories. zogstrip agrees to rename the setting to “suppress from latest and categories” to cover both. Later users like Pad_Pors, Aron_Hamvas, gusgonnet, and scombs report the issue persists in later versions (e.g., 1.7.0 beta7) and under specific settings like “Categories and Latest Topics” desktop style. theguy and Jeroen_Van_Der_Mark revive the thread seeking a solution to hide categories from /latest while keeping them visible on the homepage. jomaxro eventually directs users to a newer thread for resolution and closes this one to avoid duplication here.
Continuing the discussion from 1.5.0.beta1 breaks category exclusion from homepage:
Is there a way to exclude a category from the Latest top menu like we had in 1.4?
I tried the new Suppress this category from the homepage option, but that seems to remove the category from /categories and the posts from that category still showed up under /latest.
Ideally we’d still like to have the excluded category show up on our homepage (/categories), but excluded from /latest like we used to do with the |latest,-Category Name| option under basic setup > top menu.
I believe this person was wanting the same thing
https://meta.discourse.org/t/can-i-hide-a-category-from-the-latest-page/6728/57?u=cpradio
Incorrect, suppressing the category should also remove it from /latest. If it is not doing that, that’s a bug.
I tested on try.discourse.org by suppressing the “school” category and it worked. There are no “school” topics on the homepage any more. See for yourself. (There is one school topic – I just replied to it and it still does not appear on the homepage.)
So I am not quite sure what you’re on about here..
It fails to work when latest isn’t the front/home page. If you have categories as the home/front page, it doesn’t suppress from latest (which is now a secondary page)
However, that makes sense, as the setting is suppress from Homepage, not suppress from Latest
Hmm, I see what you mean. I think this should suppress from both pages regardless.
Perhaps we could have an option to suppress from latest and another to suppress from categories regardless of what is set as the default?
I will rename the setting to suppress from latest and categories and make sure it removes the category from both pages.
currently top page is our landing page, and the categories that are suppressed from our homepage, is still shown in the latest page.
does it meant to be like this?
Using 1.7.0 beta7 and we still have this issue. :frowning:
Hi, has the feature regressed in 1.7 or changed shape perhaps?
thanks!
Gustavo.
The category setting for Suppress this category from the homepage is not working when desktop category page style is set to Categories and Latest Topics.
So my try/sandbox category and other suppressed categories are showing on that page. Can we suppress on that page also?
Sorry for waking up such an old post, but I am looking for this too!
I want to keep the category name on the front page, but I want the topics from only some categories to appear in the Latest list.
Edit: By the way i want to suppress some topics from Latest top menu and also from Latest hybrid front page Latest topics list.
Did someone already found an answers to this question/problem? :slight_smile:
This is a fairly old topic. Which specific issue above are you running into?
@jomaxro yeah thanks for responding.
Is it possible to hide certain category’s front the latest page? That’s what @Frank also mentioned i guess.
It is possible. Check out Hidden category appearing again after update - #4 by awesomerobot for the details.
Closing this topic so we don’t keep multiple conversations about the same topic running.
