Suspended, inactive and blocked user with API key can still create topics
User is configured like this:
Inactive and suspended, yet I am still able to create topic with following code:
@data = {
  skip_validations: true,
  auto_track: false,
  title: "test",
  raw: "test"
resp = client.create_topic(@data)
Is this intended behavior? On the other hand category security settings are respected.
What I am trying to achieve: I have open source project with simple ruby script that downloads latest topics from some particular discourse instance and converts that to a static web site.
I would like to commit this API key for read only user, so everyone can clone this repo and start their work.
Is there any other way to achieve this(read-only user with api access)?
Thanks
Edit: It also doesn’t work when user is blocked
4 לייקים
Only API is allowed to do this. We never intended to allow API usage to general public, if you suspend a user you must revoke their keys.
Hmmm, for read only access you don’t need any API key, all the json endpoints work fine without it.
Probably Ok to add a check here in API for suspended user, but this seems like a super freakish edge case to me…
Perhaps the suspend action could auto revoke any API keys this user holds?
5 לייקים
Thanks for tip @sam, problem is gone.
Revoking api keys on suspend/block/deactivate would be far more intuitive.
That’s now done :rat:
https://github.com/discourse/discourse/commit/73624e63c52f915c1530d29a965cee9d0ae2de7d
3 לייקים
