Switch to another Disk
By using a Cloud VM, the default disk is too small (20GB for System), I want to move my Discourse to another disk. Is there any system admin tutorial for this?
No, but IMO you should try hosting your assests on s3 if you only have 20gigs of VM space.
It’s typically easier to take a backup, set up a new system with your desired setup (a larger disk), and perform a restore on the new server.
