Passé à HTTPS, 1 des liens RSS est en HTTP
on https://talk.remobjects.com/
        <link rel="alternate" type="application/rss+xml" title="Latest posts" href="https://talk.remobjects.com/posts.rss" />
    <link rel="alternate" type="application/rss+xml" title="Latest topics" href="http://talk.remobjects.com/latest.rss" />
The first is fine (i changed the use https setting) the second isn’t, also the fontawesome links seem to still use http:
<style>
  @font-face {
    font-family: 'FontAwesome';
    src: url('/assets/fontawesome-webfont-e2f6015310d7f63fa1537ab9822f1446.eot?http://talk.remobjects.com&amp;2&v=4.5.0');
    src: url('/assets/fontawesome-webfont-e2f6015310d7f63fa1537ab9822f1446.eot?http://talk.remobjects.com&amp;2&v=4.5.0#iefix') format('embedded-opentype'),
         url('/assets/fontawesome-webfont-6d0ddb44b6016bd7adf993e5b9d47ae6.woff2?http://talk.remobjects.com&amp;2&v=4.5.0') format('woff2'),
         url('/assets/fontawesome-webfont-90e687312466f7a4993c85399c116f2f.woff?http://talk.remobjects.com&amp;2&v=4.5.0') format('woff'),
         url('/assets/fontawesome-webfont-f436f853ea7573a6b623eea9bc9d66ec.ttf?http://talk.remobjects.com&amp;2&v=4.5.0') format('truetype');
    font-weight: normal;
    font-style: normal;
</style>
Did rebuild it, didn’t change anymore.
I don’t see this on meta, which is weird.
Is the use https setting enabled? Look in /admin/site_settings/category/security.
Yep.
Maybe something strange is cached, try dumping redis and rebuilding
How do I do that (the redis part)?
The :bomb: option is to redis-cli flushall from inside the container. That’ll remove everything from redis (you may lose some pending emails).
Did that. Then did ./launcher rebuild app; exact same result. What else could I be missing?
Where are you terminating SSL ?
Discourse itself is HTTP, (my own) nginx in front of it does https:
        location @fallback {
                proxy_pass http://unix:/sites/websites/discourse/discourse2/shared/standalone/nginx.http.sock:;
                proxy_set_header Host $http_host;
                proxy_http_version 1.1;
                proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
Try this
https://meta.discourse.org/t/canonical-url-when-using-ssl-offloading/22075/5?u=sam
