After a discussion about moderators about spending an extended amount of time on the screen, I decided it’ll be best to remind staff members(and non-staff!) to frequently take a break from the forums after looking at it for a long time. New update: It also works on non-staff and can be toggled on and off via theme settings.
What does it do?
This theme component shows an alert message after the member is on the forums for x amount of seconds. So 30 minutes would be 1800 seconds until the message is shown. This component has 4 main settings that let you customize your message and change the time until the message is shown.
It’s PROVEN to help you if you take a break from the screen. This is especially for moderators and admins who sometimes spend the night doing staff work! This component is a great reminder to take a break if you’re moderating or looking at the forums for too long. This component also helps for those who can’t stop replying, posting, etc. It’s always good to take a break!
Preview
Here’s a quick preview video(Sorry the webpage took so long to load)
Since changing the settings in theme creator is currently broken, you can download this component on your instance and try changing the message and the time!
Maybe there should be an option to show it to users, too (not only staff). As a regular user I would be fascinated to see that the forum admins care about users’ health
equality in js should be checked with === and not ==
Let me know if you need more help, happy to review more.
I’m a little bit concerned we can’t disable it on per user basis, as I would never use this. But we don’t have per user setting in theme components ATM. So I don’t see any good/easy solution here.
Maybe a good solution would be to have a pair of groups/message, that would make it slightly more configurable.
Added an option for normal users. (Default is off for normal users)
Fixed. Sorry about that.
I haven’t checked discourse for a while. I’ll go over it tomorrow. I’ll also check on the other ones too. I’ll message you if I have trouble with any on them. Thanks
Eindrucksvoll! Ich hätte selbst nie gedacht, dass es für verschiedene Zwecke angepasst werden kann! Es ist großartig zu hören, dass es hilft. Das Beantworten unbeantworteter Threads wird überall ausdrücklich begrüßt, unabhängig davon, wofür das Forum genutzt wird. Danke fürs Teilen!
Ich habe es nicht so eingestellt, dass es verhindert wird, wenn ein Benutzer tippt (obwohl es den Editor nicht schließt). Sie können diese Komponente definitiv für Werbung verwenden, aber ich empfehle diese Lösung, da sie für Werbung optimierter ist:
Entschuldigung für das Aufwärmen, aber ich habe einige Vorschläge: Vielleicht sollte es vom Benutzer in den Einstellungen konfigurierbar sein, sodass man die Farbe ändern kann. Anstatt eines X sollten zwei Buttons vorhanden sein: einer für eine Social-Media-Plattform wie YouTube, die vom Benutzer geändert werden kann, und einer mit der Aufschrift „Mir geht es gut
Ist es überhaupt möglich, HTML zum Text hinzuzufügen? Das wäre wirklich schön, falls ja. (Und vielleicht in diesem Fall eine zusätzliche Option für die Häufigkeit… z. B. nur jeden „n-ten
Ich verwende bereits das offizielle Werbe-Plugin. Ich möchte wissen, ob es möglich ist, beim Laden der Seite Pop-up-Werbeanzeigen wie im folgenden Link anzuzeigen. Führt es Google AdSense-Code aus?
Standardmäßig ist es nur dazu gedacht, normalen Text anzuzeigen. Wenn Sie in den Quellcode eintauchen und ihn ändern, können Sie definitiv eine Anzeige anzeigen.
@Pravi, wenn du möchtest, kannst du das Repository forken und dir die Datei head-tag.htmlhier in der Komponente ansehen (hier werden die Pop-ups und alles andere umgesetzt), um sie an deine Vorlieben anzupassen. showModal wird hier aufgerufen. Du solltest wahrscheinlich ein bisschen mit dem Code herumspielen
