The "Start Upgrading" button does not disappear during upgrade
The “Start Upgrading” button does not disappear during the upgrade process, causing confusion. uwe_keim first reported this issue and dax suspected it to be a regression, as the button should be hidden during the upgrade. dax further investigated and found errors in the browser console, including a 502 error and 500 errors, which might be related to the issue. The upgrade process itself is not affected, but the button’s behavior is a GUI problem. codinghorror confirmed the bug and codinghorror requested a fix. The issue was eventually fixed by tgxworld in a commit to the docker_manager repository.
Since some days, the Start Upgrading button does not hide during upgrading:
I don’t know how it looked before that change, but probably there was a cancel button or the like.
3 Curtiram
It looks like a regression, in fact it should be like that
at least until 1.9.0.beta10 +12 version I’m using.
EDIT : I can see the Start Upgrading button again, only if the upgrade fails for some reason. In this case it reappears. Check the log to see you find errors or not.
EDIT 2 : I can confirm that after the upgrade (done now) the Upgrading and the Reset Upgrade buttons are no longer displayed and the Start upgrading remains visible and clickable even if the upgrade is running.
5 Curtiram
I see this kind of errors in the browser console:
I do not know if they are related errors but I share them, just in case…
a 502 error relative to the /push-service-worker.js
and 500 errors for the /admin/docker/upgrade
I tried to click on the start upgrading button when a plugin update had already begun to see what would happen → the upgrade seems to stop (the log disappears, after some minutes it reappears).
But If I click to turn back to the docker/upgrade/versions I see this:
and if I click on Currently Upgrading:
I can see the disappeared buttons (the log reappears after few minutes, about 3 or 4, at the beginning it remains completely empty).
1 Curtiu
So will this be fixed some day?
É mais um problema de interface gráfica do usuário do que um bug grave.
Não impede nem influencia a atualização, mas na verdade causa um pouco de confusão.
Tenho certeza de que a equipe o corrigirá o mais rápido possível.
(Recategorizo o tópico na categoria Contribute > UX)
5 Curtiram
Oh I see this is a legit bug, the button changes and then immediately changes back @tgxworld
8 Curtiram
We still need to fix this @tgxworld
5 Curtiram
Fixed in
https://github.com/discourse/docker_manager/commit/6cc836e7c3b197f2800a21b4926b18ba0169cb77
6 Curtiram
