Import du thème via fichier ne fonctionne pas
I haven’t had to use this in a while, but a need arose today. I tried on two different sites and am unable to import a theme file through the Themes page of the Admin Panel. When I click on the import button and open the file chooser, all the .dcstyle.json theme files listed are greyed out.
Not sure if anything here could be related:
Any thoughts?
1 « J'aime »
If you file chooser has an Options button, click it, and then select All Files. That should let you upload the file.
3 « J'aime »
Is this a legit bug or is the UI unclear here?
It’s a bug, at least in Chrome and Firefox.
3 « J'aime »
As a workaround, in OSX you can also drag the file onto the ‘Choose file’ button:
5 « J'aime »
This is a weird mac issue. Let’s try this and see how we go:
https://github.com/discourse/discourse/commit/73688413744ae141690e86f2e1e5395c31d1ba12
5 « J'aime »
I remember trying to fix this with Data Explorer too… what’s the <input> look like for that?
I hacked this in accept='.dcstyle.json,application/json' it seems to be ok in my vm
Answer:
 return ".json,application/json,application/x-javascript,text/json" + (this.get('extension') ? "," + this.get('extension') : "");
https://github.com/discourse/discourse-data-explorer/blob/master/assets/javascripts/discourse/components/json-file-uploader.js.es6#L44-L46
I think that allowing .json is probably important.
This topic was automatically closed after 27 hours. New replies are no longer allowed.
