I’ve got a theme component that started from a skelton a few days ago. It seemed to pass the tests when I ran it locally, but at github it failed. So I ran mass-pr to update the theme stuff and now it’s failing and it looks like it’s not my fault:
Run if test -f stylelint.config.mjs; then
pnpm stylelint --allow-empty-input "{javascripts,desktop,mobile,common,scss}/**/*.scss"
fi
shell: /usr/bin/bash -e {0}
env:
JS_PKG_MANAGER_NULL_VALUE: none
Error: Could not find "@discourse/lint-configs/stylelint". Do you need to install the package or use the "configBasedir" option?
at configurationError (file:///home/runner/work/right-sidebar-blocks-customization/right-sidebar-blocks-customization/node_modules/.pnpm/stylelint@16.14.1_typescript@5.8.2/node_modules/stylelint/lib/utils/configurationError.mjs:12:49)
at getModulePath (file:///home/runner/work/right-sidebar-blocks-customization/right-sidebar-blocks-customization/node_modules/.pnpm/stylelint@16.14.1_typescript@5.8.2/node_modules/stylelint/lib/utils/getModulePath.mjs:29:9)
at loadExtendedConfig (file:///home/runner/work/right-sidebar-blocks-customization/right-sidebar-blocks-customization/node_modules/.pnpm/stylelint@16.14.1_typescript@5.8.2/node_modules/stylelint/lib/augmentConfig.mjs:225:21)
Is there something I can do?
