Themes and Associated Theme Components Report
SaraDev shares a SQL query that lists all themes in a Discourse instance along with their installed components. The query uses a common table expression (CTE) to identify parent themes and then joins this with child themes to display the component details. The query includes an optional parameter, :theme_name, to filter results by theme name. The results show the theme name, component name, and whether the component is enabled. Themes without components will display NULL values for component fields. The results are ordered alphabetically by theme name and then component name. Example results demonstrate the output format, showing themes like ā€˜Default’ and ā€˜Corporate’ with their respective components and their enabled status.
This query provides a comprehensive view of all themes in your Discourse instance along with their installed components, and can be helpful for admins who manage multiple themes and need to quickly identify which components are installed on each theme.
-- [params]
-- null text :theme_name
-- Query to list all themes and their associated installed components
WITH parent_themes AS (
  SELECT id, name
  FROM themes
  WHERE component = false
    AND (:theme_name IS NULL OR name ILIKE '%' || :theme_name || '%')
SELECT
  pt.name AS theme_name,
  ct.name AS component_name,
  ct.enabled AS component_enabled
FROM parent_themes pt
LEFT JOIN child_themes child ON child.parent_theme_id = pt.id
LEFT JOIN themes ct ON ct.id = child.child_theme_id
ORDER BY pt.name, ct.name
Parameters
  • theme_name: (Optional) Filter results to show only themes containing this text. The default view shows all themes and their components
Results
  • theme_name: The name of each theme
  • component_name: The name of components installed on the theme
  • component_enabled: Whether the component is enabled (true) or disabled (false)
Themes that have no components will appear with NULL values for component fields. Results are ordered alphabetically by theme name and then component name
Example Results
theme_name component_name component_enabled
Default discourse-adplugin true
Default discourse-chat true
Default discourse-signatures false
Corporate discourse-header-search true
Corporate discourse-tooltips true
