Dépassement de délai lors de l'exécution de rake db:migrate
Every know and then I’m getting the following error when running rake db:migrate. Is it possible, that I’m running into a timeout here? If so, is there a way to increase the timeout?
rake aborted!
MiniRacer::ScriptTerminatedError: JavaScript was terminated (either by timeout or explicitly)
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/mini_racer-0.6.2/lib/mini_racer.rb:223:in `eval_unsafe'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/mini_racer-0.6.2/lib/mini_racer.rb:223:in `block (2 levels) in eval'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/mini_racer-0.6.2/lib/mini_racer.rb:364:in `timeout'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/mini_racer-0.6.2/lib/mini_racer.rb:222:in `block in eval'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/mini_racer-0.6.2/lib/mini_racer.rb:220:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/mini_racer-0.6.2/lib/mini_racer.rb:220:in `eval'
/var/www/discourse/lib/discourse_js_processor.rb:142:in `block in perform'
/var/www/discourse/lib/discourse_js_processor.rb:135:in `synchronize'
/var/www/discourse/lib/discourse_js_processor.rb:135:in `perform'
/var/www/discourse/lib/pretty_text.rb:51:in `apply_es6_file'
/var/www/discourse/lib/pretty_text.rb:70:in `block in ctx_load_manifest'
/var/www/discourse/lib/pretty_text.rb:67:in `each_line'
/var/www/discourse/lib/pretty_text.rb:67:in `ctx_load_manifest'
/var/www/discourse/lib/pretty_text.rb:107:in `create_es6_context'
/var/www/discourse/lib/pretty_text.rb:149:in `block in v8'
/var/www/discourse/lib/pretty_text.rb:147:in `synchronize'
/var/www/discourse/lib/pretty_text.rb:147:in `v8'
/var/www/discourse/lib/pretty_text.rb:301:in `block in escape_emoji'
/var/www/discourse/lib/pretty_text.rb:582:in `block in protect'
/var/www/discourse/lib/pretty_text.rb:581:in `synchronize'
/var/www/discourse/lib/pretty_text.rb:581:in `protect'
/var/www/discourse/lib/pretty_text.rb:300:in `escape_emoji'
/var/www/discourse/app/models/emoji.rb:222:in `unicode_unescape'
/var/www/discourse/app/models/topic.rb:463:in `fancy_title'
/var/www/discourse/app/models/topic.rb:352:in `block in <class:Topic>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:427:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:427:in `block in make_lambda'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:198:in `block (2 levels) in halting'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:604:in `block (2 levels) in default_terminator'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:603:in `catch'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:603:in `block in default_terminator'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:199:in `block in halting'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:512:in `block in invoke_before'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:512:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:512:in `invoke_before'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:115:in `block in run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/autosave_association.rb:385:in `around_save_collection_association'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:126:in `block in run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:137:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:824:in `_run_save_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/callbacks.rb:457:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/timestamp.rb:126:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/persistence.rb:507:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/validations.rb:53:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/transactions.rb:302:in `block in save!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/transactions.rb:354:in `block in with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract/database_statements.rb:318:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/transactions.rb:350:in `with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/transactions.rb:302:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/suppressor.rb:48:in `save!'
/var/www/discourse/app/models/category.rb:290:in `block in create_category_definition'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/transactions.rb:209:in `transaction'
/var/www/discourse/app/models/category.rb:285:in `create_category_definition'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:235:in `block in halting_and_conditional'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:516:in `block in invoke_after'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:516:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:516:in `invoke_after'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:107:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:824:in `_run_create_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/callbacks.rb:461:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/timestamp.rb:108:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/persistence.rb:900:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/callbacks.rb:457:in `block in create_or_update'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
/var/www/discourse/lib/seed_data/categories.rb:114:in `create_category'
/var/www/discourse/lib/seed_data/categories.rb:15:in `block (2 levels) in create'
/var/www/discourse/lib/seed_data/categories.rb:15:in `each'
/var/www/discourse/lib/seed_data/categories.rb:15:in `block in create'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/i18n-1.10.0/lib/i18n.rb:328:in `with_locale'
/var/www/discourse/lib/seed_data/categories.rb:14:in `create'
(eval):6:in `block (2 levels) in run_file'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:46:in `eval'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:46:in `block (2 levels) in run_file'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:58:in `block in open'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:57:in `open'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:36:in `block in run_file'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:35:in `run_file'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:26:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:25:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:25:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/seed-fu-2.3.9/lib/seed-fu.rb:29:in `seed'
/var/www/discourse/lib/tasks/db.rake:225:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:33:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:29:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:14:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:210:in `block in <main>'
Tasks: TOP => db:migrate
Any hints for debugging this issues welcome!
Est-ce un Raspberry Pi ?
Non, s’exécute sur une machine virtuelle avec 1 vCPU et 1 Go de mémoire + 1 Go de swap.
S’il s’agit d’une installation standard en production, pourquoi exécutez-vous cette tâche rake ? Elle n’est nécessaire qu’en développement (ce qui est généralement local). S’il s’agit d’un serveur de développement cloud, alors d’accord.
C’est une machine de test/développement. Des idées ?
Dans ce fil de discussion précédent, le même genre de chose était un timeout : beaucoup d’images à traiter…
Job exception: JavaScript was terminated (either by timeout or explicitly)
