A timezone bug has been identified in the calendar feature. RGJ encountered the issue when clicking on dates in the same paragraph, and provided a gif to illustrate the problem. twofoursixeight also experimented with the calendar feature and found related weird behavior on mobile. ted explained that the bug is due to a fallback mechanism for detecting date ranges, which relies on counting child elements in a paragraph and is disrupted by the modal element. A fix has been implemented in PR#19477, as confirmed by ted.
When we added dedicated support for date ranges we also added a fallback for the old, “automagic” way of detecting them (i.e. are there two dates in the paragraph, if so consider it a range.)
This fallback relies on checking the number of child elements in the paragraph. When expanding the modal, the modal element is added as a child element as well. This is why there are different results when clicking a date depending on whether a modal is already open or not.
