Tips for Preventing Spam
:bookmark: This documentation provides a comprehensive guide on preventing spam in Discourse forums, and includes information about various settings and tools designed to help maintain a spam-free community environment.
:person_raising_hand: Required user level: Administrator
On most forums spam is rare. However, if you’re having problems with spam on your site, Discourse comes with numerous tools to help you automatically prevent spam.
The following guide offers some recommendations on how you can help prevent spam, while still maintaining a positive and welcoming environment for your community.
Spam Detection with Discourse AI
AI Spam Detection is one of the best Discourse features for automated spam detection. Unlike other tools, it can automatically block users and posts based on preconfigured rules. AI Spam Detection is available to all users on Discourse hosting, and on self-hosted sites with an LLM configured.
Benefits of AI Spam Detection include:
  • Automation: No manual intervention is needed to block obvious spam.
  • Customizability: You can tailor it to your community’s unique requirements.
  • Scalability: Works well even when communities are under heavy spam attacks.
  • Broad compatibility: Free (on Discourse hosting) and budget-friendly LLMs like GPT-4, Claude 3.5, and Gemini Flash can handle spam detection effectively.
Setting up AI spam detection
:megaphone: This is now default turned on for Starter and Standard customers
Simply turn it on in Admin settings → plugins → AI → Spam Handling (details here).
By default it uses a prompt that Discourse has tailored for our sites, but you may add custom instructions specific to your site.
Example tailored prompt
:information_source: With Discourse AI you can also use the creative AI bot to generate tailored prompts that are specific to your site’s needs.
Default Trust Levels
The default trust level for new users on your site can be adjusted on the .../admin/site_settings/category/trust page, however, we recommend keeping the default trust level set to 0.
If you’ve modified the value of this setting, we strongly recommend changing it back to 0: new user, as changing this setting can put your site at serious risk for spam, due to the way that trust levels interact with Discourse’s spam related settings.
Spam Related Site Settings
:warning: Unless you are specifically having trouble with spam, we recommend keeping the following settings at their default values.
Discourse has several spam related site settings that you can access on your site’s .../admin/site_settings/category/spam page.
These settings can be adjusted to increase or decrease the sensitivity of spam detection, and the strictness of the consequences associated with posting spam.
The following are some of the more commonly adjusted spam related settings that have a notable impact on how spam is handled on a site.
The default values for all settings are shown below.
Hiding Posts
The hide post sensitivity and cooldown minutes after hiding posts settings control the likelihood that a flagged post will be automatically hidden by Discourse, and how long a user must wait before they can edit a flagged and hidden post.
Silencing New Users
Discourse has a num users to silence site setting, which will automatically silence a new user if they receive a certain number of spam flags.
By default this is set to 3, so you may want to consider lowering this if you’re consistently having problems with spam coming from the same user(s).
Limiting Links
Discourse limits the number of posts a new user can make that contain links to an outside domain with the newuser spam host threshold setting. If new users on your site are frequently spamming links to the same domain, you may want to consider lowering the value of this setting.
Limiting IP Addresses
Discourse limits the number of new accounts a user can make from any given IP address. If you’re finding that problematic users on your site are repeatedly creating accounts to spam your site, you could consider lowering this from the default value.
There’s also a flag sockpuppets checkbox that you can enable to prevent users from creating multiple accounts and then commenting on the same topic:
Additionally, you can manually look up the IP addresses of problematic users on their admin page under the Last IP Address and Registration IP Address fields, and delete other accounts associated with the same IP address.
Or consider blocking IP addresses that spammers are using on the “Logs → Screened IPs” page (.../admin/logs/screened_ip_addresses):
Adjusting Flag Requirements
By default, a topic needs to be flagged by 5 unique users before Discourse will automatically suspending posting to that topic.
You can adjust the num flaggers to close topic site setting to raise or lower the number of flaggers required to suspend posting on a topic, and adjust the auto close topic sensitivity setting to change the likelihood that the topic in question will get automatically closed instead.
Watched Words
Watched Words are another great feature for helping block or limit posts that contain words, phrases, or URL links that spammers might be repeatedly using.
Considering adding some “Blocked” or “Silence” Words to your site if you’re finding that spammers are frequently using the same types of text in their posts.
For a more advanced use of Watched Words, you could also consider Using Regex with Watched Words.
Increase Trust Level Requirements
If you’re finding that spam is coming mainly from TL0 users, you may also want to adjust some of the trust level settings to make it harder to get to TL1:
hCaptcha Plugin
The Discourse hCaptcha plugin aims to enhance security and bot protection by integrating hCaptcha into the local sign-up form.
:sparkles: On all Discourse hosted sites, this plugin is automatically included.
Additional Steps
It’s important to understand why users are spamming your site. Are they’re bored, malicious, or looking to promote themselves?
Suggestions for dealing with The Difficult User, along with a variety of other moderation topics can be found in our Discourse Moderation Guide, so you may want to read through this guide for some additional ideas regarding moderating your site.
Outside of the above, ramping up your moderation team for the short term, so that you have full coverage is another good approach to combatting spam. The key is to wear the problem users down so they get bored and move on.
If you’re continually having problems with spam after going through this guide, you could also consider placing all or some posts from new users into the review queue with the approve post count, approve unless trust level, or approve new topics unless trust level settings:
However, it’s important to make sure you have enough moderators at hand to handle this, as this can have the potential make it difficult for new users to start interacting with the site if posts go unapproved.
I cant speak for all forums but I forum I used to be on as TL3 there was at least one spam post still up when I logged on for the first time for the day in my watched categories. And the one I’m currently a mod on we get an average of 2 or so spam posts a day. So I think it is some what common on a lot of forums based on that
One very useful regular expression is \d{3}-\d{4}|[\w+\-.]+@[a-z\d\-]+(\.[a-z\d\-]+)*\.[a-z]+ which blocks email addresses and phone numbers. Don’t forget to enable settings - posting - “watched words regular expressions”.
Hey :wave:
I’ve been making great use of these tips on my forum so…thank you! :heart:
Is there a setting that can be enabled that sends only new users signing up from say a gmail.com domain, to the review queue?
Currently, I have all new users sent to the queue for review but I’ve found the majority of the spam users are ones that are created using a gmail email. Sending only those to the review queue would reduce to load and the review time, for me at least :sweat_smile:
@SaraDev Do you know if this is possible? I’ll love to know too as it would be very helpful to block not just IPs but specific domains!
There is no core Discourse feature to send posts only from users on a specific domain (e.g., gmail.com) to the review queue.
The closest related feature is the auto approve email domains site setting, which allows certain email domains to bypass the manual user approval process by automatically approving users from those domains.
There are also settings for blocked email domains and allowed email domains that provide a way to restrict or control who can register on your site based on their email domains:
However, these settings would all require the must approve users setting to be enabled, and only impact users initially registering on a site, and not the interaction between creating posts and the review queue.
As a workaround, you could use Groups to accomplish a similar functionality though. For example, you could create a custom group and automatically add users who register with a specific email address to the group, and then add this group to the approve unless allowed groups and approve new topics unless allowed groups setting.
With this type of setup, you could effectively bypass the review queue for users with a specific domain, while still sending other posts to the review queue if desired.
Hi, I was wondering whether it is possible to force a captcha on topic and/or post creation?
I don’t know, but what it helps if a bot can bypass captcha when login? Then it can do same when publishing,
True, but there seems to be captcha support for registration, so I was wondering whether the same exists for topic/post creation.
We’ve seen a number of clients hit by large spam attacks lately, and what they all had in common is that they opened up one or more categories to everyone - create, bypassing all trust level restrictions.
For seasoned Discourse admins it’s obvious that this is a bad idea, but for less experienced people it’s not. So it might be a good idea to state the (for us) obvious and add this to the start post of the topic.
Lately, we’ve been dealing with spammers who use automatic registration and then try creating new topics with AI-generated content that looks like genuine requests for advice, but includes Amazon affiliate links. They usually mask those links with various URL shortener engines. They are able to respond to replies and even can chat in PM in a funny way. Has anyone experienced this? I wonder if, since these attempts seem to be fully automated, there would be plenty of other targeted Discourse forums. Do you have any advice on a strategy for cutting them loose?
Hi @Overgrow,
A few ideas you could try here to prevent this:
  • Use Discourse AI - AI triage to Set up spam detection in your community to detect this type of content
  • Add URL shorteners and Amazon affiliate link patterns to your blocked watched words list
  • Lower the newuser spam host threshold and increase requirements for TL1
  • Reduce max new accounts per registration IP and enable flag sockpuppets
  • Use the Discourse hCaptcha plugin to help prevent automated spam/AI registrations on your site.
  • Consider placing all new user content in the review queue until the attack subsides by adjusting:
    • approve post count
    • approve unless trust level
    • approve new topics unless trust level
The approach here will be similar to preventing spam in general, with more of a focus specifically on the shortened URLs, and AI generated content.
For your case here, you could try using an AI prompt for specifically detecting AI content like the following:
You are a spam detection system. Analyze the following content and context.
Notes:
- Replies must remain relevant to the discussion thread.
- Mark as SPAM if the content is irrelevant, promotional, or automated.
- Consider new user posts with links as potential SPAM unless explicitly relevant to the topic.
Watch for content that appears authentic but has unnatural patterns.
Look for text with peculiar phrasing, excessive formality mixed with
casual language, or generic advice that doesn't quite fit the context.
Flag content containing hidden affiliate links, especially when the post
seems designed to naturally lead to product recommendations.
Pay special attention to these red flags:
1. Content that poses as genuine advice requests but contains promotional elements
2. Posts that introduce a problem and then suggest specific products as solutions
3. The presence of URL shorteners (bit.ly, tinyurl, t.co, goo.gl, etc.) which may disguise affiliate links
4. Amazon product links or references, especially with affiliate parameters (tag=, ref=, affiliate=)
5. Content that seems to ask for recommendations but subtly steers toward specific products
6. Artificial quality text - overly formal language mixed with casual expressions or awkward structure
7. New accounts posting content with any of the above patterns
Respond only with "SPAM" or "NOT SPAM".
Having a lot of trouble with bot accounts lately. Ive had to disable new user registrations for the second time. Yesterday had to delete 50 odd bot accounts with roughly 30 spam posts. Have already enabled hcaptcha with a difficult puzzle but hasn’t stopped them. Was on 3.5.0 but just updated to 3.6.0 just after the attack. We already don’t allow links at trust level 0 and require 30 posts before allowing links, but these posts are just walls of text about travel agents and other random nonsense. Had also had AI accounts and posts that refer to actual forum content but don’t quite make sense. Those are somewhat entertaining for our user base, but anyway, I didn’t want to enable AI on the forum but i feel i have exhausted all other options. However, i get this message:
But I don’t see anywhere to add said configuration?
Above all, while the AI might help with the spam, I don’t think that enabling this will help with the bot accounts being created in the first place or am I wrong?
If approve post count is set to 1. Then is modifying these still needed?
I honestly don’t know the answer to that question.
