Watched Words Reference Guide
:bookmark: This is a reference guide for describing how the Watched Words page functions and the different types of action types you can use to block specific words on a Discourse site.
:person_raising_hand: Required user level: Administrator
Understanding Watched Words
You can setup Watched Words to take actions based on words found in a topic or post (located at .../admin/customize/watched_words ).
There’s a max of 2000 words per type of action.
On all actions, * can be used as a wildcard, and there’s an option to select if the watched words are case-sensitive.
By default, the watched words are hidden. Checking the “show words” checkbox will display them and allow you to delete them. Using the search field will also reveal any matching words.
Lists of Watched Words can be uploaded in bulk using the “Add from File” button, and a list of Watched Words for any action type can be downloaded from Discourse with the “Download” button. CSV is the required file format for uploading watched words in bulk.
All actions also have a “Test” button that can be used to test if a specific word or phrase contains any watched words.
Example of a matched watched word phrase
Example of a phrase with no matches
Action Types
The Watched Words page allows you to take the following types of actions on matched words:
:information_source: A Watched Word can only exist in one action type list. If a duplicate word is added to a second list it will be removed from the previous list.
Block
Prevents topics or posts containing these words from being posted at the time they are submitted by blocking the entire topic / post. The user will see an error message when they try to submit their post.
Censor
Allows posts containing these words, but replace the words with characters that hide the censored words. Censored words will be replaced with blocks. (Ex: ■■■■■■■■)
Require Approval
Posts containing these words will require approval by staff before they can be seen. Upon submitting a post with a word with this action type, the post will be hidden until staff reviews it.
Admin posts will not be scanned for require approval words.
Flag
Allows posts containing these words, but flags them so moderators can review them. A post with a flagged word will appear normally but be submitted for review. The reviewer will have various options:
If they hide the post, it will still be viewable but will look something like this:
Clicking on the ‘View ignored content’ link will show the full contents, but still in the ‘post-hidden’ state.
If they choose ‘Keep Post,’ or choose ‘Disagree’ from the options, the post will look like this:
Admin posts will not be scanned for flagged words.
:information_source: You can also use the Flag Post on Words Automation to flag a topic on creation/edition if it contains specific words.
Link
Replaces words in posts with links. More commonly used to replace common words with links to specific topics or external URLs instead of censoring words.
If no Link URL is selected when adding a word to this type of action, the homepage of the Discourse site will automatically be used as the link to replace the word.
Replace
Replaces words in posts with other words.
If no Replacement word is selected when adding a word to this action, the word will be removed from the post, but no word replacement will take it’s place - the word will disappear from the post, and the post will be allowed to be submitted (Not Recommended).
The replace action type also has an Outputs HTML in the replacement checkbox option.
This feature allows admins to use HTML formatting when setting replacement text, which can be especially useful for creating links and adding styling emphasis to automatically substituted text.
:warning: Remapping links through the use of watched words is not recommended, and can cause more trouble than intended. Therefore, the ability to remap links using Watched Words → Replace setting is intentionally disabled, and links will not be remapped in topics or posts regardless of watched word settings.
Tag
Automatically tags topics with these words based on first post in the topic. One or more tags can be added for each word included in this action.
A tag must be included when submitting a word with this type of action, otherwise you will receive an error.
Also note that when tagging topics with a watched word, the word must be included in the topic at the time the topic is posted in order for the topic to be correctly tagged. Editing a topic after it has been created with a watched word for a tag will not add the tag to the topic.
Silence
First posts of users containing these words will require approval by staff before they can be seen and the user will be automatically silenced. A user who uses a “silence” word on their first post will be silenced and the post be will sent to the moderation queue
Regex Expressions
For information about using Regex Expressions with Watched Words see:
Watched Words and AI Triage
In addition to manually configuring actions through Watched Words, Discourse can also integrate with AI tools to help automate and optimize moderation efforts in your community. By using the Discourse AI - AI triage features you can setup Toxicity Detection and NSFW Detection to enhance your ability to identify and handle problematic content effectively.
For full setup instructions, you can visit:
Watched Words in Personal Messages
Watched Words of the ‘Flag’ type will be triggered in Personal Messages (PMs). See the relevant section above for details about how that works.
Watched Words with Discourse Chat
Some Watched Word types also work in chat channels when Discourse Chat is enabled. The compatibility of each type with chat is as follows:
Watched Word Type Works in chat?
Block :white_check_mark:
Censor :white_check_mark:
Require Approval :cross_mark:
Flag :cross_mark:
Link :white_check_mark:
Replace :white_check_mark:
Tag :cross_mark:
Silence :cross_mark:
These Watched Words apply to all messages in Chat, whether they are in a channel or direct message between users.
Last checked by @hugh 2025-08-01T01:56:59Z
Making a note here to update the guide with the new ‘Outputs HTML in the replacement’ option, which allows some nifty formatting for Replace and some things like <abbr> for Link.
It would be really nice if,
  1. the linkified words had a CSS class attached to them so they could be targeted for different layout (impossible to tell difference between user derived links and auto linked words)
  2. there was an option to only link the first instance of the word, instead of every instance in the post
It may also be worth mentioning that some Watched Word types also work in chat.
I think these are the ones:
Flag :cross_mark:
Tag :cross_mark:
There’s an Add button, but I can’t seem to use it :frowning:
Why?
I was able to remove a single watched word (quickbooks) from the UI. Why can’t I put it back?
Did you enter the word into the “words or phrases” field?
I am sometimes confused because I forget that this is the field where I need to add the word to activate the add button.
:persevering_face:
I didn’t realize the “Has words or phrases” input was a text input. The fact that it’s (apparently) pre-filled with “words or phrases” and the + on the end threw me off entirely.
Thanks @Moin!
I’m glad I’m not the only one who doesn’t realize that this is the input field. Maybe one of the @moderators can move this to a UX topic
I found an issue with the Watched Words feature.
For example, if I add test as a watched word:
  • The phrase hello test world will be matched :white_check_mark:
  • The phrase ä˝  test 弽 will also be matched :white_check_mark:
  • But the phrase ä˝ test弽 will not be matched :cross_mark:
It seems that Watched Words only works when the keyword is separated by spaces or punctuation. This makes it fail in cases where the keyword is adjacent to other characters, which is very common in languages like Chinese or Japanese (where words are not separated by spaces).
Could you please confirm if this is a bug? If so, it would be great to improve Watched Words so that it matches even when the word is directly next to other characters.
Thanks!
I don’t think it’s a bug. Everything seems to be working as expected. If spaces were ignored by default and ass was a watched word, passkey would trigger that. I think you can use *test* instead as the watched words, and it will work for all three of your examples.
Why, after I added the attention word “trash talk” which requires approval, is my post still not being reviewed? Are there other requirements I need to meet?
Does testing the watched word with the text you tried to post work? Maybe you need to add asterisks around your words in case there are no spaces around it as discussed above your post.
Who posted this? Did you use an admin or moderator account for testing? Posts written by staff aren’t queued for approval because they can approve their own posts anyway.
Hi all,
I’m running into an issue with Watched Words (Replace) on our health forum and wondering if anyone has found a solution.
The problem: We use Watched Words to automatically expand medical abbreviations for accessibility (e.g., MGUS → Monoclonal gammopathy of unknown significance (MGUS)). This works perfectly on the initial post, but when anyone edits that post later, the replacement runs again and creates nested recursion like this:
Monoclonal gammopathy of unknown significance (Monoclonal gammopathy of unknown significance (MGUS))
Each subsequent edit adds another layer :melting_face:
What I’ve tried:
  • Adding single quotes around the abbreviation: (term) → ('term') - still recurses
  • Using HTML entities with “Outputs HTML in replacement” enabled - text disappears entirely on edit
  • HTML span tags - displays as literal code and still recurses
I know I could just remove the abbreviation from the replacement text, but it’s important for both internal forum search and external SEO that the abbreviation remains visible in posts. The abbreviations are how most people actually talk about these conditions, and if we only show the expanded term, those searches won’t surface the relevant discussions..
So, I guess my question is whether there’s a way to expand abbreviations that survives post edits without recursion, while keeping the abbreviation visible for searchability?
Looks like a bug in the rich text editor, which should be fixed by
