Hello,
I’m forced with an update problem. When I try to update Discourse via admin/upgrade page I receive information about the old Docker image.
So I try to connect to the Discourse server and update by typing the commands git pull and then rebuilding the app. But now I received the below error:
success Cleared cache.
Done in 8.44s.
I, [2022-03-08T17:16:03.605966 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2022-03-08T17:16:08.549201 #1] INFO -- :
I, [2022-03-08T17:16:08.549823 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
ERROR: syntax error at or near "CASCADE"
LINE 1: ...ION IF EXISTS sync_bookmarks_polymorphic_column_data CASCADE
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rack-mini-profiler-3.0.0/lib/patches/db/pg.rb:110:in `exec'
Caused by:
PG::SyntaxError: ERROR: syntax error at or near "CASCADE"
I tried updating Discourse with commented plugins section. But It didn’t help.
Searching discourse abut sync_bookmarks_polymorphic_column_data this function I only find this change in Discourse code DEV: Drop bookmark trigger correctly (#15486)
Where I can find more information about what happened? Or how to try to rebuild Discourse without the above change?
