My forum is: Education.
A large number of readers (students) created Onebox,
As a result, our Sever CPU is overloaded, the website has 2 errors: 502 Bad Gateway and 504 Gateway Time-out error, unable to access the website.
I want to find the solution: Reduce the frequency (reduce the speed) of Onebox creation in Discourse (Onebox is still being generated, but the time it takes to create consecutive oneboxes will be longer).
If we can prolong the creation time of Oneboxs, then our server CPU will not be overloaded.
Thank you.
סיכום מבוסס בינה מלאכותית
Users hoangviet and hokod report that excessive Onebox generation by students (around 10,000 users) is overloading their Discourse server, causing 502 and 504 errors. While server CPU usage averages 25-45%, spikes cause inaccessibility. pfaffman suggests upgrading hardware or tuning the database, noting Sidekiq queues may be contributing. hokod specifically wants to throttle Sidekiq’s “Low” queue frequency to reduce job rate, as it runs too fast and crashes the site. IAmGav and merefield confirm Sidekiq OSS lacks rate limiting; upgrading to Sidekiq Pro ($99/month) could help but is costly. merefield suggests hardware upgrades or managed hosting as more practical. codinghorror requests data on onebox density per reply/topic to better diagnose. Overall, solutions revolve around hardware scaling, database tuning, or costly Sidekiq Pro features — no simple config change exists to throttle onebox creation rate in vanilla Discourse.
The easiest thing is likely to increase the ram and or cpu on your server. What are your server specs? How many posts are created each day?
A large number of students make a lot of oneboxes, we have about 10000 students,
I also thought of solutions: Increase CPU, Ram,
However when we tested the CPU, the performance averaged between 25-45%; In some time, our Discourse gets CPU overload, resulting in inaccessibility to our website.
So I wanted another solution,
Jay Pfaffman, Thank you !!!
Did you adjust the memory parameters after adjusting the memory? It sounds like the database is your bottleneck. There are some topics about tuning large servers. That’s where to look.
You can look at the sidekiq queue and see if perhaps those jobs should be in a lower priority queue, but I think database tuning is probably where to look.
We are also facing the same problem, sidekiq ( low) runs fast, causing our discourse to fail to access the website.
Is there a way to adjust sidekiq frequency (low)
I think your options are to add cpu and ram or limit how many links users can make.
my problem is almost similar,
In sidekiq, how to reduce the frequency of running sidekiq.
Pictures below:
We want to reduce the frequency of running Low in sidekiq.
Because Low in sidekiq runs too fast (high frequency), causing website errors, readers cannot visit website (502, 504).
I want to specify Sidekiq: Sidekiq (Low) is only allowed to run with how many requests/second
Can you that help me?
for me the CPU, Ram is not high.
With my sidekiq, Low (sidekiq) runs too fast. Make the website fail
As far as I know, sidekiq is not customizable.
With those numbers that you are showing, I would suggest you upgrade your server with more memory & processes.
Looking at the sidekiq product level feature chart two things jump out:
the basic OSS tier bundled free with Discourse lacks:
- rate limiting (which I believe is what you are after?)
- batches (which you might use to do work outside of busy user periods for those jobs you could defer)
As such I think you need to look at the hardware side.
However it would be interesting to know if some sites could upgrade to Pro and how much work would be involved (is it just adding a licence key?) Perhaps someone has attempted this before?
The Pro product is not cheap though at $99/month. Makes a case for spending a lot more on hardware? Even $50/month might buy you a significant hardware upgrade? How much are you spending now?
If you want to look at using the Pro product with Discourse that’s something Pavilion could help you with, but that consulting would also cost.
Then there’s always the option of getting someone to host it for you and take on all those challenges.
I think you are going to need to increase your budget significantly in order to run the system the way you want it to work.
Can you provide some data? How many oneboxes per reply, how many replies per topic, and how many oneboxes total per topic?
