There is an envelope icon to the left of personal message titles with the tooltip:
"This topic is a personal message"
That’s somewhat informative, but it totally hides the more important fact that clicking on the envelope takes you to your Inbox
You can change that message at: Customize / Text / js.topic_statuses.personal_message.title
But it might be preferable if the default were already “Go to Inbox” or something similar
              I wonder if it’s worth having the link there at all? It’s a bit of an oddball ninja navigation feature.
This topic is a personal message (select to go to your inbox)
                jomaxro
                (Joshua Rosenfeld)
              4
              I click the envelope frequently too. If we remove the link from it, we need to add some other way to “go to inbox”. A
 button perhaps?
              I definitely would like a button, and it would help if it were more obvious what it does.
              Sure, maybe it should be styled as a button? I’m not sure. What do you think @awesomerobot ?
              I also use this all the time to find my way back to the inbox. I like the idea of making this link back more obvious.
