Topic Entrance has a lot of space. How can I fix?
Hi everyone, how can I fix that ? please teach me
Hi,
What do you mean? It’s by design aligned to the right.
What are you trying to achieve?
Hi @Arkshine
When I click on the topic, the Topic Entry Window always opens. It has a very wide area towards the left, I want to narrow it down.
You mean this?
And you would prefer to open it only when clicking on the number.
Am I correct?
Yes that’s true
It looks the same on in your screenshots. Even when you click on the space, that window opens.
I just want that window to open when I click on the number.
Can you try this snippet?
    api.modifyClass("component:latest-topic-list-item",  {
        pluginId: "showEntrance",
        showEntrance(event) {
            if (event.target.classList.contains('posts-map')) {
                return this.unhandledRowClick(event, this.topic);
            return this._super(...arguments);
</script>
EDIT: The code can be actually simplified.
It works! Thank you very much. :heart:
