דיון שפורסם ב-'תאריך לא חוקי' עם ActivityPub
סיכום מבוסס בינה מלאכותית
A bug report was submitted regarding topics published via ActivityPub displaying an ‘Invalid date’. NateDhaliwal reported the issue, noting that topics created this way lack a category and show an invalid date. pmusaraj acknowledged the issue and confirmed it needs investigation. angus suggested checking meta logs for further insights. adulau shared a similar experience, observing posts being accepted but not displayed correctly on subscriber platforms. pmusaraj provided a partial fix, explaining the underlying issue involves multiple activity_pub_published_at custom fields causing the date to appear invalid. aschrijver1 cross-referenced a related report from the SocialHub forum. adulau confirmed the fix worked and praised the ActivityPub plugin.
In that topic, the topic says ‘Topic was published via ActivityPub on Invalid date’.
See this screenshot:
4 לייקים
Thanks for the report, appreciate it. I see the same, we will look into it.
3 לייקים
@pmusaraj Could you share any relevant meta logs from Apr 3, 2:42 PM, when that post was posted? It might help determine why the post-publication behaviour, i.e. saving published at, isn’t working in some cases.
לייק 1
We have a similar behavior. We can see the post being POSTed on the activity end-points and accepted but they are not shown in the different subscriber. The only issue we see (after a recent update of the plugin - we run 3.6.0.beta1-dev) Invalid date for ActivityPub post on topic.
What would be the best option for debugging this behavior? In previous version, we didn’t see that error and the posts were published on the subscribers properly.
לייק 1
Oh, I added a partial fix for this in DEV: Ensure activity_pub_published_at returns a single date by pmusaraj · Pull Request #243 · discourse/discourse-activity-pub · GitHub, I think. If you rebuild your instance @adulau you should no longer see this issue.
The underlying bug isn’t fixed. In some cases, the plugin creates multiple activity_pub_published_at custom fields for the same object, which results in the serializer returning an array of dates for topic.activity_pub_published_at. Often these are the same date added twice in the array. The frontend code (Moment) doesn’t know how to interpret an array of dates and outputs invalid date. The fix above ensures the serializer always outputs a single date (without yet fixing the underlying reason for multiple custom fields).
5 לייקים
FYI I reported this as well some time ago in the SocialHub forum. Cross-referencing to https://socialhub.activitypub.rocks/t/topic-was-published-via-activitypub-on-invalid-date/5447
3 לייקים
תודה על התיקון. זה אכן עובד עכשיו. דרך אגב, תוסף ה-ActivityPub הוא באמת מדהים.
4 לייקים
