Hi @angus , thanks for reply!
My case is:
Only specific group (staff would be enough, let it be) is allowed to add/remove stars
Only staff can see stars
Non-group users should not see any ratings (as this plugin not installed).
The scenario is necessary to rate topics and posts by staff members. It will allow to gather statistics (data explore plugin is used) about the most important conversations, thoughts directions or people. This can help to improve services that we provide to our community via forum.
Unfortunately I had not success to develop this function by myselfâŚ
angus
(Angus McLeod)
April 4, 2018, 11:59am
165
Sorry, just to be sure Iâm understanding you, staff will be rating other peopleâs (normal users) posts?
No problem. Yes, staff will rate usersâ posts. Also staff users will rate posts the same way both in private categories and categories shared between other registered users.
angus
(Angus McLeod)
May 9, 2018, 6:31am
168
Yup, Iâll tackle these a bit later in the week.
Task List
Hide âno ratingsâ when there is no rating.
Add a setting to not check add a rating by default.
Add a ratings-specific topic list that lists topics by average rating.
Improve the rspec and unit tests.
alxsal
(Alex Salvador)
May 30, 2018, 11:16pm
169
I have a topic for which I unchecked the âAdd Ă ratingâ box. However, each time I edit this topic, the âAdd a topicâ box appears checked again, and I have to uncheck it each time.
Is it possible to keep track of the fact that the box was chosen unchecked upon creation of the topic, and keep this preference by default when editing that topic ?
angus
(Angus McLeod)
June 5, 2018, 7:31am
170
parisa
(Pari)
June 10, 2018, 3:51am
171
Iâm having the following error with rating topics:
### Message
NoMethodError (undefined method `to_i' for [3730, 3730]:Array Did you mean? to_s to_a to_h) /var/www/discourse/plugins/discourse-ratings/plugin.rb:104:in `rating_count'
### Backtrace
/var/www/discourse/plugins/discourse-ratings/plugin.rb:104:in `rating_count' /var/www/discourse/plugins/discourse-ratings/plugin.rb:145:in `has_ratings' /var/www/discourse/plugins/discourse-ratings/plugin.rb:129:in `include_average_rating?' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:375:in `include?' (eval):58:in `_fast_attributes' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:468:in `rescue in attributes' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:455:in `attributes' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:480:in `_serializable_hash' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:359:in `serializable_hash' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:347:in `as_json' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.2.0/lib/active_support/json/encoding.rb:35:in `encode' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.2.0/lib/active_support/json/encoding.rb:22:in `encode' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.2.0/lib/active_support/core_ext/object/json.rb:41:in `to_json' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:331:in `to_json' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/multi_json-1.13.1/lib/multi_json/adapters/oj.rb:40:in `dump' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/multi_json-1.13.1/lib/multi_json/adapters/oj.rb:40:in `dump' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/multi_json-1.13.1/lib/multi_json/adapter.rb:25:in `dump' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/multi_json-1.13.1/lib/multi_json.rb:139:in `dump' /var/www/discourse/app/controllers/application_controller.rb:395:in `render_json_dump' /var/www/discourse/app/controllers/topics_controller.rb:777:in `block (2 levels) in perform_show_response' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_controller/metal/mime_responds.rb:203:in `respond_to' /var/www/discourse/app/controllers/topics_controller.rb:769:in `perform_show_response' /var/www/discourse/app/controllers/topics_controller.rb:128:in `show' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:194:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_controller/metal/rendering.rb:30:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:42:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:132:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:41:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_controller/metal/rescue.rb:22:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in `block in instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.2.0/lib/active_support/notifications/instrumenter.rb:23:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:32:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_controller/metal/params_wrapper.rb:256:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/railties/controller_runtime.rb:24:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:134:in `process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionview-5.2.0/lib/action_view/rendering.rb:32:in `process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:191:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:252:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:52:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:34:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:52:in `block in serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in `each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:840:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-protection-2.0.2/lib/rack/protection/frame_options.rb:31:in `call' /var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/tempfile_reaper.rb:15:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/conditional_get.rb:25:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/head.rb:12:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/http/content_security_policy.rb:18:in `call' /var/www/discourse/lib/middleware/anonymous_cache.rb:200:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:232:in `context' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:226:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/cookies.rb:670:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:98:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:26:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.9/lib/logster/middleware/reporter.rb:31:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:38:in `call_app' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:28:in `call' /var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call' /var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/remote_ip.rb:81:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/request_id.rb:27:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/method_override.rb:22:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/executor.rb:14:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/sendfile.rb:111:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiler.rb:174:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.5/lib/message_bus/rack/middleware.rb:63:in `call' /var/www/discourse/lib/middleware/request_tracker.rb:186:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.2.0/lib/rails/engine.rb:524:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `public_send' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `method_missing' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/urlmap.rb:68:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:563:in `maintain_worker_count' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:293:in `join' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>' /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `load' /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `<main>'
### Env
hostname talk-app
process_id 2810
application_version 4b2e42757d00556468ec82047a8fcc723b087e1a
HTTP_HOST talk.zabanshenas.com
REQUEST_URI /t/540.json?api_key=1d4d600b283c1e2b3f7092ccbc51ba8fabe0040991d57f978b30bccef1695b95&api_username=pompi
REQUEST_METHOD GET
HTTP_ACCEPT */*
HTTP_X_FORWARDED_FOR 5.114.215.8, 5.114.215.8
HTTP_X_REAL_IP 5.114.215.8
username pompi
params api_key 1d4d600b283c1e2b3f7092ccbc51ba8fabe0040991d57f978b30bccef1695b95
api_username pompi
angus
(Angus McLeod)
June 11, 2018, 4:37am
172
This is a strange error. It should not be possible. Nevertheless, Iâve added some logic that handles it. Please update and it should work.
https://github.com/angusmcleod/discourse-ratings/commit/32a970c78a5694b11164f8533b03f7f67c48bbd7
sam
(Sam Saffron)
June 12, 2018, 12:06am
173
angus:
I have seen this before. I feel there is an internal bug we have where we should be allowed to explicitly register a type and then have core enforce it on the way in and the way out.
angus
(Angus McLeod)
June 12, 2018, 9:17am
174
Yeah, I was thinking the same.
Today the rating plugin make my site down.
NoMethodError (undefined method to_f' for ["4.0", "4.0"]:Array) /var/www/discourse/plugins/discourse-ratings/plugin.rb:92:in average_ratingâ
Oops
The software powering this discussion forum encountered an unexpected problem. We apologize for the inconvenience.
Detailed information about the error was logged, and an automatic notification generated. Weâll take a look at it.
I must remove it.
angus
(Angus McLeod)
June 28, 2018, 4:38am
176
Sorry for the issue. Itâs a similar issue to the one reported above. Iâve added the same fix.
https://github.com/angusmcleod/discourse-ratings/commit/7c94c7a226580088da14e887a7268363252128d3
fix for my error??? or for what error?
angus
(Angus McLeod)
June 28, 2018, 4:51am
178
It should work for you now
OK, I will try again and feedback to you soon.
Site running, but with error log
ActionController::ParameterMissing (param is missing or the value is empty: rating) /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/strong_parameters.rb:4
Summary
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/strong_parameters.rb:443:in require' /var/www/discourse/plugins/discourse-ratings/controllers/rating.rb:4:in rateâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/basic_implicit_render.rb:6:in send_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:194:in process_actionâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/rendering.rb:30:in process_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:42:in block in process_actionâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:132:in run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:41:in process_actionâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/rescue.rb:22:in process_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:34:in block in process_actionâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in block in instrument' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications/instrumenter.rb:23:in instrumentâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in instrument' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:32:in process_actionâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/params_wrapper.rb:256:in process_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/railties/controller_runtime.rb:24:in process_actionâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:134:in process' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionview-5.2.0/lib/action_view/rendering.rb:32:in processâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiling_methods.rb:78:in block in profile_method' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:191:in dispatchâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:252:in dispatch' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:52:in dispatchâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:34:in serve' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:52:in block in serveâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in each' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in serveâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:840:in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/engine.rb:524:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in public_send' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in method_missingâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/mapper.rb:19:in block in <class:Constraints>' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/mapper.rb:48:in serveâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:52:in block in serve' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in eachâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in serve' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:840:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-protection-2.0.3/lib/rack/protection/frame_options.rb:31:in call' /var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/tempfile_reaper.rb:15:in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/conditional_get.rb:38:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/head.rb:12:in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/http/content_security_policy.rb:18:in callâ /var/www/discourse/lib/middleware/anonymous_cache.rb:200:in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:232:in contextâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:226:in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/cookies.rb:670:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:28:in block in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:98:in run_callbacksâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:26:in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/debug_exceptions.rb:61:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/show_exceptions.rb:33:in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.2.9/lib/logster/middleware/reporter.rb:31:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:38:in call_app' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:28:in callâ /var/www/discourse/config/initializers/100-quiet_logger.rb:16:in call' /var/www/discourse/config/initializers/100-silence_logger.rb:29:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/remote_ip.rb:81:in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/request_id.rb:27:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/method_override.rb:22:in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/executor.rb:14:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/sendfile.rb:111:in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiler.rb:174:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/message_bus-2.1.5/lib/message_bus/rack/middleware.rb:63:in call' /var/www/discourse/lib/middleware/request_tracker.rb:186:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/engine.rb:524:in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in public_sendâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in method_missing' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:68:in block in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in each' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in callâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in process_client' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in worker_loopâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in spawn_missing_workers' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in startâ /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/bin/unicorn:126:in <top (required)>' /var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in loadâ /var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `<main>â
angus
(Angus McLeod)
June 29, 2018, 2:10am
181
Iâm surprised that hasnât come up before. Iâve fixed that too:
https://github.com/angusmcleod/discourse-ratings/commit/dd905b7e340920dfb0e6b87a91d31d10a37ab34e
Please give it another shot. Thanks for your patience.
p.s. When you post a error log itâs best to use the Hide Details feature, so the log doesnât take up a lot of space.
so now I just run the ./launcher rebuild app again?
angus
(Angus McLeod)
June 29, 2018, 2:13am
183
Go to /admin/upgrade and upgrade the plugin from there.
