Topic structured data: all posts declared as "mainEntityOfPage"
Structured Data Issue with mainEntityOfPage
rrit points out that in the structured data model, every single post is declared as mainEntityOfPage, which is incorrect. According to schema.org, there should only be one mainEntity or mainEntityOfPage per page.
rrit suggests that Google sees each page as its own context, allowing for one post to be declared as mainEntity per URL. For example, https://DOMAIN/t/SLUG/43 could have #post_1 as its mainEntity.
sam agrees and notes that using https://schema.org/DiscussionForumPosting for every post is incorrect. Instead, it should only be used for the first post, and subsequent posts should use https://schema.org/Comment. This approach would eliminate pagination issues and improve the structured data model.
rrit suggests an alternative approach, where the relations between DiscussionForumPostings are made clearer by using https://schema.org/about to declare the parent post inside each answer.
Example of Correct Structured Data Model
rrit shares an example of a working structured data model for forum posts, using XenForo. The example shows how to correctly use https://schema.org/DiscussionForumPosting for the first post and https://schema.org/Comment for subsequent posts.
In the example, the HTML code includes a script tag with the structured data in JSON format, using https://schema.org/DiscussionForumPosting for the first post and specifying the headline, articleBody, author, and other relevant properties.
In the structured data model there should be only one object declared as mainEntity / mainEntityOfPage.
See “mainEntity” - Background information - Data Model - schema.org
Right now every single post is declared to be the mainEntityOfPage.
Google sees every page (= url) as its own context. Thereby it is possible to declare one post for each url as mainEntity – e.g.
  • https://DOMAIN/t/SLUG/43: main entity is #post_1
  • https://DOMAIN/t/SLUG/43?page=2: main entity is one of #post_10 to #post_19
  • https://DOMAIN/t/SLUG/43?page=3: main entity is one of #post_20 to #post_29
See also Discussion for schema.org on “pagination of ItemLists” and Google: pagination for ItemList · Issue #1714 · schemaorg/schemaorg · GitHub
  • pagination for ItemList · Issue #1714 · schemaorg/schemaorg · GitHub
The above excerpt from Google’s developer documentation might be outdated as it is missing right now: General Structured Data Guidelines | Google Search Central  |  Documentation  |  Google for Developers
Does this not relate to the use of: DiscussionForumPosting - Schema.org Type
We use this for every single post, it looks like we should only use it for the first post and then use Comment - Schema.org Type for the rest.
That way we get rid of all the repeat titles pagination stuff and and the rest of things that are not a good fit.
Google may not really care about sub-types like DiscussionForumPosting and map these to the ancestor type Article instead.
By doing this Discourse might look more like a blog with Articles plus Comments from Googles perspective.
Maybe another way is to make the relations between DiscussionForumPostings more clear:
e.g. by using about - Schema.org Property to declare the parent post inside each answer.
post_1 (mainEntityOfPage)
+-- post_2 (about post_1)
+-- post_3 (about post_1)
|   + post_4 (about post_3)
|   + post_6 (about post_3)
+ post_5 (about post_1)
There is a discussion on how to use DiscussionForumPosting:
One opinion - see: We have DiscussionForumPosting but no DiscussionForum... · Issue #125 · schemaorg/suggestions-questions-brainstorming · GitHub
The description of DisccussionForumPosting is “A posting to a discussion forum.”.
A typical forum is made up of categories. Categories contain forums, and a forum contains topics. A topic contains 1 or more forum posts.
The description seems to indicate that this schema is for an individual forum post but the example seems to show it is for a topic which can have multiple forum posts from multiple authors.
I stumbled upon a working structured data model (= Google makes rich snippets) for forum posts in the wild: XenForo
Google SERP mobile view
Google SERP desktop view
Technical details
e.g. https://www.audiosciencereview.com/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/
Heavily reduced HTML code:
<!DOCTYPE html>
<html>
    <head>
        <title>Headphones and the Harman target curve | Audio Science Review (ASR) Forum</title>
    </head>
    <body>
        <script type="application/ld+json">
                "@context": "https://schema.org",
                "@type": "DiscussionForumPosting",
                "@id": "https://audiosciencereview.com/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/",
                "headline": "Headphones and the Harman target curve",
                "articleBody": "I recently started dabbling with EQ'ing my headphones (APO+Peace). I've been going back and fort with this with two of my headphones, the Hifiman Ananda and the Denon AH-D7200. With both of them, I think the Harman target profile sounds like...",
                "articleSection": "Headphones and Headphone Amplifier Reviews",
                "author": {
                    "@type": "Person",
                    "name": "spittiz"
                "datePublished": "2020-11-27T20:59:17+00:00",
                "dateModified": "2022-11-14T12:49:45+00:00",
                "image": "https://audiosciencereview.com/forum/data/avatars/h/6/6175.jpg?1606506178",
                "interactionStatistic": {
                    "@type": "InteractionCounter",
                    "interactionType": "https://schema.org/ReplyAction",
                    "userInteractionCount": 353
                "publisher": {
                    "@type": "Organization",
                    "name": "Audio Science Review (ASR) Forum",
                    "logo": {
                        "@type": "ImageObject",
                        "url": "https://www.audiosciencereview.com/forum%20resources/Two-line%20ASR%20Logo-new.png"
                "mainEntityOfPage": {
                    "@type": "WebPage",
        </script>
        <h1>Headphones and the Harman target curve</h1>
        <ul>
            <li>
                <a href="/forum/index.php?members/spittiz.6175/" itemprop="name">spittiz</a>
            </li>
            <li>
                <a href="/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/">
                    <time datetime="2020-11-27T20:59:17+0000" title="Nov 27, 2020 at 8:59 PM">Nov 27, 2020</time>
                </a>
            </li>
        </ul>
        <nav>
            <ul>
                <li><a href="/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/">1</a></li>
                <li><a href="/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/page-18">18</a></li>
            </ul>
        </nav>
        <!-- Topic opening post -->
        <article id="js-post-582475">
            <section itemscope itemtype="https://schema.org/Person"></section>
            <header>
                <time datetime="2020-11-27T20:59:17+0000" title="Nov 27, 2020 at 8:59 PM" itemprop="datePublished">Nov 27, 2020</time>
            </header>
            <article>
                [post text]
            </article>
        </article>
        <!-- First answer -->
        <article id="js-post-582631">
            <section itemscope itemtype="https://schema.org/Person">[…]</section>
            <header>
                <time datetime="2020-11-28T01:50:59+0000" title="Nov 28, 2020 at 1:50 AM" itemprop="datePublished">Nov 28, 2020</time>
            </header>
            <article>
                <blockquote>
                    [quote text]
                </blockquote>
                [post text]
            </article>
            <time datetime="2020-11-28T02:03:35+0000" title="Nov 28, 2020 at 2:03 AM" itemprop="dateModified">Nov 28, 2020</time>
        </article>
        <article id="js-post-582634">[…]</article>
        <article id="js-post-584460">[…]</article>
        <article id="js-post-584505">[…]</article>
    </body>
</html>
Reduced HTML source (click here to open)
<!DOCTYPE html>
<html>
    <head>
        <meta name="description" content="I recently started dabbling with EQ&#039;ing my headphones (APO+Peace). I&#039;ve been going back and fort with this with two of my headphones, the Hifiman Ananda and..." />
        <meta property="og:description" content="I recently started dabbling with EQ&#039;ing my headphones (APO+Peace). I&#039;ve been going back and fort with this with two of my headphones, the Hifiman Ananda and the Denon AH-D7200. With both of them, I think the Harman target profile sounds like shit. Especially with the Ananda it&#039;s like throwing a..." />
        <meta property="twitter:description" content="I recently started dabbling with EQ&#039;ing my headphones (APO+Peace). I&#039;ve been going back and fort with this with two of my headphones, the Hifiman Ananda and the Denon AH-D7200. With both of them..." />
        <meta property="og:url" content="https://audiosciencereview.com/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/" />
        <link rel="canonical" href="https://audiosciencereview.com/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/" />
        <link rel="next" href="/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/page-2" />
        <meta property="og:site_name" content="Audio Science Review (ASR) Forum" />
        <meta property="og:type" content="website" />
        <meta property="twitter:card" content="summary" />
        <meta property="og:title" content="Headphones and the Harman target curve" />
        <meta property="twitter:title" content="Headphones and the Harman target curve" />
        <meta property="og:image" content="https://www.audiosciencereview.com/forum%20resources/Two-line%20ASR%20Logo-new.png" />
        <meta property="twitter:image" content="https://www.audiosciencereview.com/forum%20resources/Two-line%20ASR%20Logo-new.png" />
    </head>
    <body>
                "author": {
                    "@type": "Person",
                    "name": "spittiz"
                "publisher": {
                    "logo": {
                    "@type": "WebPage",
        </script>
        <header>
        </header>
        <nav>
            <ul itemscope itemtype="https://schema.org/BreadcrumbList">
                <li itemprop="itemListElement" itemscope itemtype="https://schema.org/ListItem">
                    <a href="/forum/index.php" itemprop="item">
                    <span itemprop="name">Forums</span>
                    </a>
                    <meta itemprop="position" content="1" />
                </li>
                    <a href="/forum/index.php#audio-audio-audio.40" itemprop="item">
                    <span itemprop="name">Audio, Audio, Audio!</span>
                    </a>
                    <meta itemprop="position" content="2" />
                </li>
                    <a href="/forum/index.php?forums/headphones-and-headphone-amplifier-reviews.57/" itemprop="item">
                    <span itemprop="name">Headphones and Headphone Amplifier Reviews</span>
                    </a>
                    <meta itemprop="position" content="3" />
                </li>
            </ul>
        </nav>
        <ul>
            <li>
            </li>
            <li>
                <a href="/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/"><time datetime="2020-11-27T20:59:17+0000" title="Nov 27, 2020 at 8:59 PM">Nov 27, 2020</time></a>
            </li>
        </ul>
        <nav>
            <ul>
                <li><a href="/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/page-2">2</a></li>
                <li><a href="/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/page-3">3</a></li>
            </ul>
        </nav>
                <a href="/forum/index.php?members/spittiz.6175/">
                <img src="/forum/data/avatars/m/6/6175.jpg?1606506178" alt="spittiz" width="96" height="96" itemprop="image" />
                </a>
                <h4><a href="/forum/index.php?members/spittiz.6175/" itemprop="name">spittiz</a></h4>
                <h5 itemprop="jobTitle">Member</h5>
                <dl>
                    <dt>Joined</dt>
                    <dd>Feb 7, 2019</dd>
                </dl>
                <dl>
                    <dt>Messages</dt>
                    <dd>14</dd>
                </dl>
                <dl>
                    <dt>Likes</dt>
                    <dd>12</dd>
                </dl>
            </section>
            <header>
                <ul>
                    <li>
                        <a href="/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/post-582475" rel="nofollow">
                        </a>
                    </li>
                </ul>
                <ul>
                    <li>
                            rel="nofollow">
                        </a>
                    </li>
                    <li>
                        #1
                        </a>
                    </li>
                </ul>
            </header>
            <article>
                [post text]
            </article>
            <footer>
                <span>Reactions:</span>
                <a href="/forum/index.php?posts/582475/reactions" rel="nofollow"><bdi>tmtomh</bdi>, <bdi>yigitboy</bdi>, <bdi>Frank Dernie</bdi> and 2 others</a>
            </footer>
        </article>
                <a href="/forum/index.php?members/dreyfus.6150/">
                <img src="/forum/data/avatars/m/6/6150.jpg?1601328956" alt="Dreyfus" width="96" height="96" itemprop="image" />
                </a>
                <h4><a href="/forum/index.php?members/dreyfus.6150/" itemprop="name">Dreyfus</a></h4>
                <h5 itemprop="jobTitle">Active Member</h5>
                <dl>
                    <dt>Joined</dt>
                </dl>
                <dl>
                    <dt>Messages</dt>
                    <dd>234</dd>
                </dl>
                <dl>
                    <dt>Likes</dt>
                    <dd>287</dd>
                </dl>
                <dl>
                    <dt>Location</dt>
                    <dd>
                        <a href="/forum/index.php?misc/location-info&amp;location=Germany" rel="nofollow noreferrer" target="_blank">Germany</a>
                    </dd>
                </dl>
            </section>
            <header>
                <ul>
                    <li>
                        <a href="/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/post-582631" rel="nofollow">
                        </a>
                    </li>
                </ul>
                <ul>
                    <li>
                            rel="nofollow">
                        </a>
                    </li>
                    <li>
                        #2
                        </a>
                    </li>
                </ul>
            </header>
            <article>
                <blockquote>
                    <a href="/forum/index.php?goto/post&amp;id=582475"
                        rel="nofollow">spittiz said:</a>
                    [quote text]
                </blockquote>
                [post text]
                <blockquote>
                    [quote text]
                </blockquote>
                [post text]
            </article>
            <footer>
                <a href="/forum/index.php?posts/582631/reactions" rel="nofollow"><bdi>Presently42</bdi>, <bdi>Ilkless</bdi>, <bdi>oivavoi</bdi> and 3 others</a>
            </footer>
        </article>
                <a href="/forum/index.php?members/feelas.22359/">
                <img src="/forum/data/avatars/m/22/22359.jpg?1612728223" alt="Feelas" width="96" height="96" itemprop="image" />
                </a>
                <h4><a href="/forum/index.php?members/feelas.22359/" itemprop="name">Feelas</a></h4>
                <h5 itemprop="jobTitle">Senior Member</h5>
                <dl>
                    <dt>Joined</dt>
                    <dd>Nov 20, 2020</dd>
                </dl>
                <dl>
                    <dt>Messages</dt>
                    <dd>376</dd>
                </dl>
                <dl>
                    <dt>Likes</dt>
                    <dd>307</dd>
                </dl>
            </section>
            <header>
                <ul>
                    <li>
                        <a href="/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/post-584505" rel="nofollow">
                        <time datetime="2020-11-30T08:37:59+0000" title="Nov 30, 2020 at 8:37 AM" itemprop="datePublished">Nov 30, 2020</time>
                        </a>
                    </li>
                </ul>
                <ul>
                    <li>
                            rel="nofollow">
                        </a>
                    </li>
                    <li>
                        #20
                        </a>
                    </li>
                </ul>
            </header>
            <article>
                <blockquote>
                    <a href="/forum/index.php?goto/post&amp;id=584460"
                        rel="nofollow">Senior NEET Engineer said:</a>
                    [quoted text]
                </blockquote>
                [post text]
            </article>
            <footer></footer>
        </article>
        <nav>
            <ul>
            </ul>
            <a href="/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/page-2">Next</a>
            <a href="/forum/index.php?threads/headphones-and-the-harman-target-curve.17914/page-18" title="Last"><span>Last</span></a>
        </nav>
        <div>
            <h3>Similar threads</h3>
            <div>
                <div>
                    <div>
                        <a href="/forum/index.php?threads/usound-target-curve-for-iems.35086/">USound target curve for IEMs</a>
                        <ul>[…]</ul>
                    </div>
                </div>
                <div>
                    <div>
                        <a href="/forum/index.php?threads/my-hrtf-target-vs-harman-target.36255/">My HRTF Target vs Harman Target</a>
                        <ul>[…]</ul>
                    </div>
                </div>
                <div>
                    <a href="/forum/index.php?members/dazerdoreal.52898/">
                    <span role="img">D</span>
                    </a>
                    <div>
                        <a href="/forum/index.php?threads/the-iem-harman-target-2019-sounds-off-to-me-is-it-just-me.38113/">The IEM Harman Target 2019 sounds &quot;off&quot; to me. Is it just me?</a>
                        <ul>
                            <li><a href="/forum/index.php?members/dazerdoreal.52898/" itemprop="name">Dazerdoreal</a></li>
                            <li><a href="/forum/index.php?threads/the-iem-harman-target-2019-sounds-off-to-me-is-it-just-me.38113/" rel="nofollow"><time datetime="2022-10-08T17:06:16+0100" title="Oct 8, 2022 at 5:06 PM">Oct 8, 2022</time></a></li>
                            <li><a href="/forum/index.php?forums/headphone-iem-reviews-discussions.58/">Headphone &amp; IEM Reviews &amp; Discussions</a></li>
                        </ul>
                        <span>
                        <a href="/forum/index.php?threads/the-iem-harman-target-2019-sounds-off-to-me-is-it-just-me.38113/page-2">2</a>
                        <a href="/forum/index.php?threads/the-iem-harman-target-2019-sounds-off-to-me-is-it-just-me.38113/page-3">3</a>
                        </span>
                    </div>
                    <div title="First message reaction score: 1">
                        <dl>
                            <dt>Replies</dt>
                            <dd>52</dd>
                        </dl>
                        <dl>
                            <dt>Views</dt>
                            <dd>4K</dd>
                        </dl>
                    </div>
                    <div>
                        <a href="/forum/index.php?threads/the-iem-harman-target-2019-sounds-off-to-me-is-it-just-me.38113/latest" rel="nofollow"><time datetime="2022-11-16T05:05:28+0000" title="Nov 16, 2022 at 5:05 AM">Today at 5:05 AM</time></a>
                        <a href="/forum/index.php?members/aperiodic.7528/" itemprop="name">Aperiodic</a>
                    </div>
                    <a href="/forum/index.php?members/aperiodic.7528/">
                    <span role="img">A</span>
                    </a>
                </div>
                <div>
                    <div>
                        <a href="/forum/index.php?threads/sloped-neutral-target-curves-for-headphones-and-iems.36532/">&quot;Sloped neutral&quot; target curves for headphones and IEMs?</a>
                        <ul>[…]</ul>
                    </div>
                </div>
                <div>
                    <div>
                        <a href="/forum/index.php?threads/looking-for-bt-anc-over-ear-with-hardware-eq.36328/">Looking for BT/ANC over ear with &#039;hardware EQ&#039;</a>
                        <ul>[…]</ul>
                    </div>
                </div>
            </div>
        </div>
                </a>
            </li>
                </a>
            </li>
                </a>
            </li>
        </ul>
        <footer>
        </footer>
    </body>
</html>
