`info` でタグ付けされたトピックの見た目が不自然です
A few days ago I noticed that on our Discourse 2.4.0.beta10 (bd49d4af1a) instance single topics look strange, even with safe mode enabled:
Compare this to a regular look:
The topics all have in common that they are tagged with info. This also corresponds with a different appearance of the tag page:
Again, compare this with a “regular” look:
The /logs are as follows:
Do you have any idea what might be going on here?
Any chance this is sk2 @j.jaffeux? I can repro it on try adding the info tag.
No it’s not related to select-kit 2, but it’s impacting select-kit. It appears we have a .tag-info css selector defined in tagging.scss and if you have a tag named info we end up generating a tag-info class on various elements (and select-kit/tag-drop is part of these elements).
I made the selector more specific and that should fix it:
https://github.com/discourse/discourse/pull/8902
