Travis נכשל בבדיקות עקב eslint
סיכום מבוסס בינה מלאכותית
Travis tests failing due to eslint
@pfaffman reported that two plugins are failing Travis tests due to eslint issues. The problem arises when eslint doesn’t find any files to lint.
@pfaffman jokingly suggested creating an empty .es6 file to satisfy eslint, but later acknowledged that this wasn’t the real solution.
@joffreyjaffeux provided a fix by updating the eslint command to handle cases where no files are found, which was also applied to the rake task. The updated commit is available here.
@pfaffman still experienced issues with another plugin, but @joffreyjaffeux explained that the fix was not yet in the tests-passed branch, which is used by the discourse-plugin-ci script.
I’ve got two plugins that are failing travis tests. It appears that I don’t have any es6 files in them and eslint feels left out?
Running linters/prettyfiers
eslint yarn run v1.22.5
$ /var/www/discourse/node_modules/.bin/eslint -v
v6.8.0
Done in 0.32s.
prettier yarn run v1.22.5
$ /var/www/discourse/node_modules/.bin/prettier -v
2.1.1
Done in 0.28s.
[2020-09-07 01:34:21] bundle exec rubocop --parallel plugins/discourse-allow-pm-to-staff
Inspecting 2 files
2 files inspected, no offenses detected
[2020-09-07 01:34:22] bundle exec ruby script/i18n_lint.rb plugins/discourse-allow-pm-to-staff/config/locales/{client,server}.en.yml
[2020-09-07 01:34:23] yarn eslint --global I18n --ext .es6 plugins/discourse-allow-pm-to-staff
yarn run v1.22.5
$ /var/www/discourse/node_modules/.bin/eslint --global I18n --ext .es6 plugins/discourse-allow-pm-to-staff
Oops! Something went wrong! :(
ESLint: 6.8.0.
No files matching the pattern "plugins/discourse-allow-pm-to-staff" were found.
Please check for typing mistakes in the pattern.
error Command failed with exit code 2.
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
Listing prettier offenses in discourse-allow-pm-to-staff:
Yes, eslint doesn’t like having nothing to do. This makes it feel more useful.
mkdir -p assets/javascripts/discourse
touch assets/javascripts/discourse/eslint.js.es6
git add assets/javascripts/discourse/eslint.js.es6
git commit -m 'try to make eslint not feel left out'
git push
Oh, but I think this is the real solution:
https://github.com/discourse/discourse/compare/master...pfaffman:patch-5
Ah, but how are you going to PR that without eslint complaining? :wink:
I understand so little of what’s going on here that I almost didn’t get your joke!
Yes I pushed this fix for github actions the other day:
https://github.com/discourse/discourse/commit/110f6ec6dd16b154ad796a7de124148321240e40
So basically new eslint doesn’t like when it doesn’t match anything. I also took the opportunity to simplify the commands, will apply the same to our rake task no worries.
That should fix it:
https://github.com/discourse/discourse/commit/a60ba75ac29f748774a495dd60beb28291a2bcb9
Let me know how it goes :+1:
[2020-09-10 18:43:13] bundle exec ruby script/i18n_lint.rb plugins/discourse-topic-default-tag/config/locales/{client,server}.en.yml
[2020-09-10 18:43:13] yarn eslint --global I18n --ext .es6 plugins/discourse-topic-default-tag
yarn run v1.22.5
$ /var/www/discourse/node_modules/.bin/eslint --global I18n --ext .es6 plugins/discourse-topic-default-tag
ESLint: 6.8.0.
No files matching the pattern "plugins/discourse-topic-default-tag" were found.
Listing prettier offenses in discourse-topic-default-tag:
Oops. My bad.
Oh right yes it’s using discourse-plugin-ci stuff, if you read at the code you will see:
And my commit is not yet in tests-passed
