No entiendo esto, pero parece un error. Estoy intentando hacer un bootstrap en este sitio. No hay plugins no estándar. Solo moví los activos de un bucket a otro y todo funciona. Estaba haciendo una reconstrucción más para agregar DISCOURSE_S3_UPLOAD_BUCKET al ENV para que no aparezca en la UX. Cuando esto falló la primera vez, comenté esa línea e intenté de nuevo con la misma configuración que funcionó hace 3 días.
Done compressing embed-application-9cef8308c816fc1d83137e63d6c556c6cc2b68fe2b6e5ce16cca6766ba2c0ae4.js : 0.17 secs
844614.350963717 Compressing: discourse/tests/test_helper-8590b31b8e73c4172aeea4a4a6bd1930ccbce2547a20d831a30d457ba092a631.js
terser '/var/www/discourse/public/assets/discourse/tests/_test_helper-8590b31b8e73c4172aeea4a4a6bd1930ccbce2547a20d831a30d457ba092a631.js' -m -c -o '/var/www/discourse/public/assets/discourse/tests/test_helper-8590b31b8e73c4172aeea4a4a6bd1930ccbce2547a20d831a30d457ba092a631.js' --source-map "base='/var/www/discourse/public/assets/discourse/tests',root='/assets/discourse/tests',url='https://CORRECT_CDN_ADDRESS.b-cdn.net/assets/discourse/tests/test_helper-8590b31b8e73c4172aeea4a4a6bd1930ccbce2547a20d831a30d457ba092a631.js.map'"
Killed
rake aborted!
Errno::ENOENT: No such file or directory @ rb_file_s_size - /var/www/discourse/public/assets/discourse/tests/test_helper-8590b31b8e73c4172aeea4a4a6bd1930ccbce2547a20d831a30d457ba092a631.js
/var/www/discourse/lib/tasks/assets.rake:290:in `size'
/var/www/discourse/lib/tasks/assets.rake:290:in `block (4 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:181:in `block in concurrent?'
/var/www/discourse/lib/tasks/assets.rake:281:in `block (3 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:272:in `each'
/var/www/discourse/lib/tasks/assets.rake:272:in `block (2 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:181:in `concurrent?'
/var/www/discourse/lib/tasks/assets.rake:269:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => assets:precompile
I, [2021-04-26T18:38:36.072881 #1] INFO -- : Updating Discourse Loading Slider...
Downloading MaxMindDB...
Compressing Javascript and Generating Source Maps
Me pregunté si había algún problema con la URL del CDN, pero todas las líneas anteriores la incluían y funcionaban bien.
¿Significa esto que hay CSS defectuoso en su tema? Si es así, ¡ay! Solo hay algo de CSS en su tema principal. También estos componentes: https://github.com/discourse/DiscoTOC.git y https://github.com/davidtaylorhq/discourse-loading-slider.git
