Problema con Zeitwerk reload
Un test apparentemente nuovo ha identificato un problema che penso di aver sempre saputo di avere, ma che ho sempre ignorato. Ora non posso più ignorarlo perché fa fallire i test. Ecco le mie route:
# frozen_string_literal: true
require_dependency "pfaffmanager_constraint"
Pfaffmanager::Engine.routes.draw do
  get "/" => "pfaffmanager#index", :constraints => PfaffmanagerConstraint.new
  get "/servers" => "servers#index", :constraints => PfaffmanagerConstraint.new
  #      get "#{root_path}/:username/messages/group/:group_name" => "user_actions#private_messages", constraints: { username: RouteFormat.username, group_name: RouteFormat.username }
  get "/servers/group/:group_name" => "servers#index",
  get "/find/:s" => "servers#index", :constraints => PfaffmanagerConstraint.new
  get "/group/:group_name" => "servers#index",
  get "/inventory/:group_name.json" => "servers#inventory",
  get "/servers/:id" => "servers#show",
  get "/servers/:id/edit" => "servers#edit",
  put "/servers/:id" => "servers#update",
  delete "/servers/:id" => "servers#delete",
  put "/status/:id" => "servers#update_status",
      :constraints => AdminConstraint.new
  post "/api_key/:id" => "servers#set_api_key",
  put "/update_server_status/:id" => "servers#update_server_status",
  post "/upgrade/:id" => "servers#queue_upgrade",
  put "/install/:id" => "servers#install",
  get "/ssh_key/:id" => "serverkeys#get_pub_key"
  get "/ssh-key/:hostname" => "serverkeys#get_pub_key_by_hostname",
      :constraints => {
        hostname: %r{[^/]+}
  post "/servers" => "servers#create",
Discourse::Application.routes.append do
  mount ::Pfaffmanager::Engine, at: "/pfaffmanager"
E fallisce così:
/home/pfaffman/.asdf/installs/ruby/3.2.2/lib/ruby/gems/3.2.0/gems/actionpack-7.0.7/lib/action_dispatch/routing/route_set.rb:588:in `add_route': Invalid route name, already in use: 'pfaffmana
ger'  (ArgumentError)
You may have defined two routes with the same name using the `:as` option, or you may be overriding a route already defined by a resource with the same naming. For the latter, you can restri
ct the routes created with `resources` as explained here:
https://guides.rubyonrails.org/routing.html#restricting-the-routes-created
          raise ArgumentError, "Invalid route name, already in use: '#{name}' \
        from /home/pfaffman/.asdf/installs/ruby/3.2.2/lib/ruby/gems/3.2.0/gems/actionpack-7.0.7/lib/action_dispatch/routing/mapper.rb:1985:in `add_route'
        from /home/pfaffman/.asdf/installs/ruby/3.2.2/lib/ruby/gems/3.2.0/gems/actionpack-7.0.7/lib/action_dispatch/routing/mapper.rb:1956:in `decomposed_match'
2 Mi Piace
Hai visto questo argomento? Se segui la struttura lì (e nello scheletro del plugin), le cose dovrebbero funzionare abbastanza bene:
Una parte importante dell’autocaricamento di Zeitwerk sono i nomi/percorsi dei file, quindi è difficile identificare il problema dallo snippet che hai condiviso. È in un file plugin.rb? O in qualche altro file?
2 Mi Piace
Mi dispiace. Quello è config/routes.rb
Ma ho anche . . . roba . . . in lib/discourse-pfaffmanager/engine.rb, quindi forse devo spostare la roba da routes.rb in lib/pfaffmanager/engine.rb. Leggere il manuale (RTFM) ancora un po’.
1 Mi Piace
Penso che probabilmente devi apportare questa modifica:
- Discourse::Application.routes.append do
+ Discourse::Application.routes.draw do
In questo modo, il file può essere “ricaricato” più volte senza causare un conflitto. (‘draw’ sostituirà qualsiasi route esistente, mentre ‘append’ solleverà un errore in caso di conflitto)
Ciò lo renderebbe anche corrispondente all’attuale plugin-skeleton:
3 Mi Piace
Ci è riuscito!
Sempre così ovvio quando è stato capito.
Grazie mille.
(Ora, se solo potessi far fare a vscode il linting al salvataggio dei file, ma almeno ora avviene localmente prima che vada su github. . . )
1 Mi Piace
Sì, è esattamente una modifica che ho apportato di recente.
3 Mi Piace
Questo mi fa sentire un po’ meglio. . .
Ma ci hai messo 4 ore? :crying_cat_face:
Grazie ancora, David. Apprezzo molto il tuo supporto.
2 Mi Piace
Non in questa occasione, a volte si è fortunati ;). In questa occasione mi è capitato di leggere la guida di David e ho preso nota di quella differenza rispetto al codice che stavo seguendo originariamente.
Ma certo, alcuni problemi richiedono una passeggiata nel parco locale il giorno dopo per essere risolti :deciduous_tree:
1 Mi Piace
Per tua informazione, se pubblico una guida su qualcosa, è generalmente perché ho perso molte ore/giorni cercando di capirlo da solo :sweat_smile:. Tutta questa roba di Zeitwerk rientra decisamente in quella categoria!
:100: :chefs_kiss:
Annotato. Li mangio tutti quando li pubblichi. Avrei dovuto cercare solo zeitwork e forse l’avrei trovato. Ma anche allora, il problema era letteralmente una sola parola che sembrava così innocua.
Ora sto cercando di trasformare tutto il mio {{blah... in \u003cblah... . Mi sta uccidendo. Ma penso di aver capito (abbastanza bene da farlo tra qualche giorno).
2 Mi Piace
Questo argomento è stato chiuso automaticamente 30 giorni dopo l’ultima risposta. Non sono più consentite nuove risposte.
