averi
(Andrea Veri)
2 oktober 2019 om 10:44
1
We recently upgraded to 2.4.0.beta5 from 2.4.0.beta4 and sidekiq fails to start with the following traceback:
> $ bundle exec sidekiq -C config/sidekiq.yml
> uninitialized constant SiteSetting::SiteSettingExtension
> /discourse/app/models/site_setting.rb:5:in `<class:SiteSetting>'
> /discourse/app/models/site_setting.rb:3:in `<top (required)>'
> /discourse/vendor/bundle/ruby/2.5.0/gems/zeitwerk-2.1.10/lib/zeitwerk/kernel.rb:23:in `require'
> /discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-6.0.0/lib/active_support/dependencies/interlock.rb:14:in `block in loading'
> /discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-6.0.0/lib/active_support/concurrency/share_lock.rb:151:in `exclusive'
> /discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-6.0.0/lib/active_support/dependencies/interlock.rb:13:in `loading'
> /discourse/config/initializers/004-message_bus.rb:120:in `<top (required)>'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/engine.rb:667:in `block in load_config_initializer'
> /discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-6.0.0/lib/active_support/notifications.rb:182:in `instrument'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/engine.rb:666:in `load_config_initializer'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/engine.rb:624:in `block (2 levels) in <class:Engine>'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/engine.rb:623:in `each'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/engine.rb:623:in `block in <class:Engine>'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/initializable.rb:32:in `instance_exec'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/initializable.rb:32:in `run'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/initializable.rb:61:in `block in run_initializers'
> /usr/local/lib/ruby/2.5.0/tsort.rb:228:in `block in tsort_each'
> /usr/local/lib/ruby/2.5.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
> /usr/local/lib/ruby/2.5.0/tsort.rb:422:in `block (2 levels) in each_strongly_connected_component_from'
> /usr/local/lib/ruby/2.5.0/tsort.rb:431:in `each_strongly_connected_component_from'
> /usr/local/lib/ruby/2.5.0/tsort.rb:421:in `block in each_strongly_connected_component_from'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/initializable.rb:50:in `each'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/initializable.rb:50:in `tsort_each_child'
> /usr/local/lib/ruby/2.5.0/tsort.rb:415:in `call'
> /usr/local/lib/ruby/2.5.0/tsort.rb:415:in `each_strongly_connected_component_from'
> /usr/local/lib/ruby/2.5.0/tsort.rb:349:in `block in each_strongly_connected_component'
> /usr/local/lib/ruby/2.5.0/tsort.rb:347:in `each'
> /usr/local/lib/ruby/2.5.0/tsort.rb:347:in `call'
> /usr/local/lib/ruby/2.5.0/tsort.rb:347:in `each_strongly_connected_component'
> /usr/local/lib/ruby/2.5.0/tsort.rb:226:in `tsort_each'
> /usr/local/lib/ruby/2.5.0/tsort.rb:205:in `tsort_each'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/initializable.rb:60:in `run_initializers'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/application.rb:363:in `initialize!'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/railtie.rb:190:in `public_send'
> /discourse/vendor/bundle/ruby/2.5.0/gems/railties-6.0.0/lib/rails/railtie.rb:190:in `method_missing'
> /discourse/config/environment.rb:7:in `<top (required)>'
> /discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.2.7/lib/sidekiq/cli.rb:288:in `boot_system'
> /discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.2.7/lib/sidekiq/cli.rb:46:in `run'
> /discourse/vendor/bundle/ruby/2.5.0/gems/sidekiq-5.2.7/bin/sidekiq:12:in `<top (required)>'
> /discourse/vendor/bundle/ruby/2.5.0/bin/sidekiq:23:in `load'
> /discourse/vendor/bundle/ruby/2.5.0/bin/sidekiq:23:in `<top (required)>'
> /usr/local/lib/ruby/site_ruby/2.5.0/bundler/cli/exec.rb:74:in `load'
> /usr/local/lib/ruby/site_ruby/2.5.0/bundler/cli/exec.rb:74:in `kernel_load'
> /usr/local/lib/ruby/site_ruby/2.5.0/bundler/cli/exec.rb:28:in `run'
> /usr/local/lib/ruby/site_ruby/2.5.0/bundler/cli.rb:463:in `exec'
> /usr/local/lib/ruby/site_ruby/2.5.0/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
> /usr/local/lib/ruby/site_ruby/2.5.0/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'
> /usr/local/lib/ruby/site_ruby/2.5.0/bundler/vendor/thor/lib/thor.rb:387:in `dispatch'
> /usr/local/lib/ruby/site_ruby/2.5.0/bundler/cli.rb:27:in `dispatch'
> /usr/local/lib/ruby/site_ruby/2.5.0/bundler/vendor/thor/lib/thor/base.rb:466:in `start'
> /usr/local/lib/ruby/site_ruby/2.5.0/bundler/cli.rb:18:in `start'
> /usr/local/bin/bundle:30:in `block in <main>'
> /usr/local/lib/ruby/site_ruby/2.5.0/bundler/friendly_errors.rb:124:in `with_friendly_errors'
> /usr/local/bin/bundle:22:in `<main>'
Any guidance on where to look next? Thanks!
Falco
(Falco)
2 oktober 2019 om 12:14
This isn’t a install that followed our official guide, so there isn’t much we can help you with.
averi
(Andrea Veri)
2 oktober 2019 om 12:27
3
We’re currently running discourse on Openshift so surely it’s not a standard install , I’ll review the official guide and see whether I missed anything on the current deployment, thanks.
azawawi
(Ahmad M. Zawawi)
2 oktober 2019 om 12:39
4
Actually even the following docker command is triggering the same stack trace in my discourse vagrant machine over virtualbox:
vagrant ssh -c '(cd ~/discourse && sudo bin/docker/sidekiq)'
Falco
(Falco)
2 oktober 2019 om 12:42
5
You sure about that? The official guide doesn’t have anything related manual starts of sidekiq and there is no /home/discourse folder in it.
Are you running a development install in production ??
azawawi
(Ahmad M. Zawawi)
2 oktober 2019 om 12:45
6
I am using the docker commands to test and develop discourse plugins.
The other script I am currently using is:
# Clear temporary discourse cache and launch development rails
vagrant ssh -c '(rm -rf ~/discourse/tmp/cache)'
vagrant ssh -c '(cd ~/discourse && sudo bin/docker/rails s)'
azawawi
(Ahmad M. Zawawi)
2 oktober 2019 om 12:50
8
Falco
(Falco)
2 oktober 2019 om 12:51
9
Oh it may be. The fact that you didn’t state that this is your development setup and not a dev environment didn’t help.
So you are saying that our docker dev setup is currently broken?
azawawi
(Ahmad M. Zawawi)
2 oktober 2019 om 12:59
11
Reverting that commit makes sidekiq work again.
Falco
(Falco)
2 oktober 2019 om 13:11
12
Looks like this is one for you @kris.kotlarek
Ok, I know what happened here, it is my fault. I removed a lot of require_dependency since they are not required anymore when using Zeitwerk autoloader.
However, in application.rb we got that:
if !Sidekiq.server?
config.autoload_paths += Dir["#{config.root}/lib"]
Which means that Sidekiq is not looking for lib directory to find dependencies and we explicitly define what is required in specific files.
I can bring back that require_depenedency for files which are used by Sidekiq or remove that guard in application.rb.
I guess that we used that explicit require to save some memory for workers, so probably we should follow that path. I will bring back require_dependency
@sam what is your opinion?
sam
(Sam Saffron)
2 oktober 2019 om 23:36
14
We should remove the guard, I don’t like it cause you have no idea if your process will become a sidekiq or not. In our deployments we have: unicorn master → fork → sidekiq worker. At fork time application.rb was already parsed.
azawawi
(Ahmad M. Zawawi)
3 oktober 2019 om 07:18
15
@kris.kotlarek Thanks for the fix. Sidekiq is now working along with the discourse official plugins .
Most of my 3rd-party plugins with jobs are not working now . Most likely caused by the following commit not being applied on their Jobs:: classes.
https://github.com/discourse/discourse-assign/commit/d59e7fe1fbe95789324010b3729d0589a8a9789f#diff-5428237aebbe478a7a57cc3d42db4bb1
Broken 3rd-party plugins
module Jobs
class MigrateStaticPagesPlugin < ::Jobs::Onceoff
# Migrate content from dl_static_pages name to procourse_static_pages
def execute_onceoff(args)
dl_page_presence = PluginStoreRow.where(plugin_name: "dl_static_pages").exists?
if dl_page_presence
# Migrate the page content rows
PluginStoreRow.where(plugin_name: 'dl_static_pages')
.find_each do |row|
PluginStore.set("procourse_static_pages", row.key, row.value)
row.destroy # clean up dl_static_pages row
# frozen_string_literal: true
# name: discourse-whos-online
# about: Display a list of online users at the top of the screen
# meta_topic_id: 52345
# version: 2.0
# authors: David Taylor
# url: https://github.com/discourse/discourse-whos-online
enabled_site_setting :whos_online_enabled
register_asset "stylesheets/whos_online.scss"
after_initialize do
module ::DiscourseWhosOnline
CHANNEL_NAME = "/whos-online/online"
register_presence_channel_prefix("whos-online") do |channel_name|
if channel_name == "/whos-online/online"
config = PresenceChannel::Config.new(timeout: SiteSetting.whos_online_active_timeago * 60)
if SiteSetting.whos_online_display_public
config.public = true
else
config.allowed_group_ids = [::Group::AUTO_GROUPS[:trust_level_0]]
config.count_only = SiteSetting.whos_online_count_only
config
on(:user_seen) do |user|
hidden = false
hidden ||= user.user_option.hide_presence if defined?(user.user_option.hide_presence)
hidden ||= user.id < 0
next if hidden
PresenceChannel.new(DiscourseWhosOnline::CHANNEL_NAME).present(
user_id: user.id,
client_id: "seen",
rescue PresenceChannel::InvalidAccess
add_to_serializer(
:site,
:whos_online_state,
include_condition: -> do
@whos_online_channel ||= PresenceChannel.new(DiscourseWhosOnline::CHANNEL_NAME)
@whos_online_channel.can_view?(user_id: scope.user&.id)
end,
) do
PresenceChannelStateSerializer.new(@whos_online_channel.state, root: nil)
You are right, all Jobs::Onceoff, Jobs::Base and Jobs::Scheduled require now ::
I fixed discourse-whos-online and created pull requests for other plugins:
https://github.com/gdpelican/babble/pull/287
https://github.com/procourse/procourse-static-pages/pull/11
azawawi
(Ahmad M. Zawawi)
4 oktober 2019 om 05:13
17
@kris.kotlarek Thanks a lot . I took a look at your post for the zeitwork auto-loader. Is there a plan to enable a development plugin auto-reloading feature to speed up plugin development.
https://github.com/fxn/zeitwerk
There are still places containing require or require_dependency but many are removed.
I think that now plugin’s code should be automatically reloaded without a problem. We need to play a little bit to ensure, but I have a positive feeling
azawawi
(Ahmad M. Zawawi)
6 oktober 2019 om 09:21
19
It seems we need to enable it first as per its documentation. I tried it in development and no plugin changes were reloaded
https://github.com/fxn/zeitwerk#reloading
This guide documents how autoloading and reloading works in zeitwerk mode.After reading this guide, you will know: Related Rails configuration Project structure Autoloading, reloading, and eager loading Single Table Inheritance And more
fzngagan
(Faizaan Gagan)
6 oktober 2019 om 09:23
20
This would be great. I had some hope but your words give me more hope. Plugin devs will love this.
