Trying to set up SSO
When do i need to use a webhook?
I’m trying to setup SSO or possible create a new user through the API.
Do i need to setup a webhook for that?
So i’m confused as to the use case for webhooks? and when to use them or use the API or SSO?
I think you probably want this guide instead:
If you’d like further assistance with your SSO integration, please describe in more detail what you’re trying to accomplish.
A webhook is normally used for an outgoing transaction. For example if you have a user created in discourse or a new topic created etc it can update / create record in outbound system.
The API is used for inbound transactions. Creating new users / topics in discourse etc.
