محاولة فهم launcher كسلسلة من أوامر Docker
I am trying to understand the Docker commands issued by launcher.
This also requires understanding the other bash commands in the script. As I am no bash expert I have to do some research to figure some parts. Normally I read the code and manually figure out the command and then test run it to make sure, e.g.
docker info 2> /dev/null
Sometimes some of the lines are more complicated and I run an equivalent, e.g.
test=$(($(stat -f --format="%a*%S" /var/lib/docker)/1024**3 < 5)); echo $test
The current subroutine I am working on is host_run() for which I have no idea where the input to the routine is coming from.
https://github.com/discourse/discourse_docker/blob/master/launcher#L259-#L287.
Now I could ask many questions for the next few days or sprinkle echo statements in a modified launcher but there has to be something better.
Is there a means like the command script that will capture the internal Docker commands being run and log them to a file?
EDIT
This seems to work. See: Debugging Bash scripts
Simply use the bash -x option, e.g.
groot@galaxy:/var/discourse$ sudo bash -x launcher start app
To capture this to file
  1. Create directory to hold traces. This is created under the ~ path to avoid permission problems.
groot@galaxy:/var/discourse$ mkdir ~/traces
  1. Run bash command of interest. The trick is that the trace output does not go to stdout, but stderr so use 2> instead of > which is really 1>.
groot@galaxy:/var/discourse$ sudo bash -x launcher start app 2> ~/traces/start_01
  1. Filter the file showing lines with the docker command.
groot@galaxy:/var/discourse$ grep /usr/bin/docker ~/traces/start_01
Example output:
+ docker_path=/usr/bin/docker
+ '[' -z /usr/bin/docker ']'
++ /usr/bin/docker info
++ /usr/bin/docker --version
++ /usr/bin/docker images
++ /usr/bin/docker run -i --rm -a stdout -a stderr discourse/base:2.0.20200512-1735 echo working
++ /usr/bin/docker info --format '{{.DockerRootDir}}'
++ /usr/bin/docker ps
++ /usr/bin/docker ps -a
+ /usr/bin/docker start app
That may look like a lot more Docker commands than expected but launcher is doing a lot of integrity checking that you would have to do by hand. This convinces me to use launcher for the regular tasks for which it was created.
