ما الذي يُفترض أن يفعله أمر start-cmd في المشغّل؟
The help for launcher has
Usage: launcher COMMAND CONFIG [--skip-prereqs] [--docker-args STRING]
Commands:
    start:       Start/initialize a container
    start-cmd:   Generate docker command used to start container
and since I know launcher is at times issuing Docker container commands I was expecting start-cmd to show the Docker command with all the parameters to start the container.
This was the result
groot@galaxy:/var/discourse$ ./launcher start-cmd
Commands:
a dump of the command help.
How is this command used?
إعجاب واحد (1)
You still need to give it the config for which to issue the command, e.g.: ./launcher start-cmd app
4 إعجابات
Thanks.
groot@galaxy:/var/discourse$ sudo ./launcher start-cmd app
+ true run --shm-size=512m -d --restart=always -e LANG=en_US.UTF-8 -e RAILS_ENV=production -e UNICORN_WORKERS=4 -e UNICORN_SIDEKIQS=1 -e RUBY_GLOBAL_METHOD_CACHE_SIZE=131072 -e RUBY_GC_HEAP_GROWTH_MAX_SLOTS=40000 -e RUBY_GC_HEAP_INIT_SLOTS=400000 -e RUBY_GC_HEAP_OLDOBJECT_LIMIT_FACTOR=1.5 -e DISCOURSE_DB_SOCKET=/var/run/postgresql -e DISCOURSE_DB_HOST= -e DISCOURSE_DB_PORT= -e LETSENCRYPT_DIR=/shared/letsencrypt -e DISCOURSE_HOSTNAME=planet.galaxy.org  -e DISCOURSE_DEVELOPER_EMAILS=groot@galaxy.org -e DISCOURSE_SMTP_ADDRESS=smtp.mailgun.org -e DISCOURSE_SMTP_PORT=587 -e DISCOURSE_SMTP_USER_NAME=groot@mg.galaxy.org -e DISCOURSE_SMTP_PASSWORD=not_here -e LETSENCRYPT_ACCOUNT_EMAIL=groot@galaxy.org -h site-app -e DOCKER_HOST_IP= www.xxx.yyy.zzz --name app -t -p 80:80 -p 443:443 -v /var/discourse/shared/standalone:/shared -v /var/discourse/shared/standalone/log/var-log:/var/log --mac-address ab:cd:ef:gh:ij:kl local_discourse/app /sbin/boot
Obviously specific values were sanitized.
إعجاب واحد (1)
