UI issue when merging accounts
Today I ran into a strange problem here on meta when merging two accounts, at the request of a member. I was able to do it as usual and it worked, but something went wrong in the UI.
Steps:
  1. merge using the button at the bottom of the user admin page of the account you want to merge into another account
  2. page greys out and a “Merge process” popup is shown. It does not show any progress indicator and does not go away or offer a way to close. Clicking away or ESC does nothing.
  3. refresh the page and a 404 page not found error is shown
I don’t recall how this used to work previously, but I think there should be a progress indicator on the popup and it should indicate when is done, with a close button. Then you should land on the user admin page of the user that got merged into.
