Unable to ignore user using API
A user, chrisbai2021, is trying to implement a user blocking feature in a mobile app using the Discourse API but encounters a 422 error when attempting to ignore a user via the u/{username}/notification_level.json endpoint. JammyDodger explains that the ignore feature is trust level-based, requiring at least TL2, and cannot be used on admins or moderators. JammyDodger suggests adjusting the min trust level to allow ignore setting or using the mute feature, which is available to all users. After adjusting settings and adding an expiring_at parameter, chrisbai2021 successfully implements the ignore function but notes that ignored users’ posts are hidden while their topics remain visible, a behavior confirmed to be expected in the web UI. chrisbai2021 concludes by realizing the need to use ignored_usernames in the user object to achieve the desired hiding behavior.
Hello friends,
I am building a mobile forum app using Discourse API, and Google requires all apps with UGC to have a blocking feature.
I’ve done some research and it looks like Discourse lets a user ignore another user, which would satisfy this requirement.
However, when I use the following API to ignore a user, I got a 422 error that says “Sorry, you can’t ignore that user.” for any user that I tried ignoring.
with
notification_level=ignore
Does anyone know why this is happening?
Thanks in advance and best,
Chris
Hello and welcome @chrisbai2021 :slight_smile:
The ignore feature is Trust Level based, so it could be that your test user is not at TL2 yet (the default level to use that feature).
You also can’t ignore admins and mods, so it would also depend on who you’re trying to ignore. :slight_smile:
Hi @JammyDodger, thanks for the quick reply.
That makes sense - I guess this means we need to default everyone to at least TL2 upon signup in order to be compliant with Google…
Thanks again!
Alternatively, you can adjust the min trust level to allow ignore setting:
There’s also a ‘mute’ feature that may be of interest to you as well, depending on what you need. That’s available to everyone.
And here’s a topic of lots of features and their trust levels, plus the admin settings connected to them: :slight_smile: :+1: Trust Level Permissions Table (inc Moderator Roles)
Ah awesome, thanks for these pointers!
I tried making myself a TL2 + lowering min trust level to allow ignore to TL0. However, I am now getting a 500 error.
To test things, I changed the supplied notification_level to mute and the request succeeded.
I wonder if there’s a site setting for allowing ignoring as a feature at all… been search in admin settings and seen nothing so far…
Oh, i think i might need to supply a expiring_at…
Looking at the request that gets sent through when I perform the action in the UI, you may need to add the timeframe:
Edit:
Ah, you beat me to it. :slight_smile:
Amazing, thank you! This is super helpful :slight_smile:
This worked!! But I have one last question…
It looks like posts by ignored users are hidden, but not topics… this seems to be the case in the web UI as well. Is this expected?
Ah, I guess I need to use ignored_usernames in the user object to implement the hiding behavior :slight_smile:
