Imposible mover publicaciones debido a error 500
Hola,
Estoy encontrando un problema al mover una publicación a otro tema.
Cuando reviso el registro de errores:
ActiveRecord::RecordNotUnique (PG::UniqueViolation: ERROR: duplicate key value violates unique constraint \"index_posts_on_topic_id_and_post_number\" DETAIL: Key (topic_id, post_number)=(22680, 3) alr
Y:
rack-mini-profiler (3.0.0) lib/patches/db/pg.rb:72:in `exec_params'
activerecord (7.0.4.3) lib/active_record/connection_adapters/postgresql_adapter.rb:768:in `block (2 levels) in exec_no_cache'
activesupport (7.0.4.3) lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
activesupport (7.0.4.3) lib/active_support/dependencies/interlock.rb:41:in `permit_concurrent_loads'
activerecord (7.0.4.3) lib/active_record/connection_adapters/postgresql_adapter.rb:767:in `block in exec_no_cache'
activesupport (7.0.4.3) lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
activesupport (7.0.4.3) lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
activesupport (7.0.4.3) lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
activesupport (7.0.4.3) lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
activerecord (7.0.4.3) lib/active_record/connection_adapters/abstract_adapter.rb:765:in `block in log'
activesupport (7.0.4.3) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activerecord (7.0.4.3) lib/active_record/connection_adapters/abstract_adapter.rb:756:in `log'
activerecord (7.0.4.3) lib/active_record/connection_adapters/postgresql_adapter.rb:766:in `exec_no_cache'
activerecord (7.0.4.3) lib/active_record/connection_adapters/postgresql_adapter.rb:745:in `execute_and_clear'
activerecord (7.0.4.3) lib/active_record/connection_adapters/postgresql/database_statements.rb:71:in `exec_delete'
activerecord (7.0.4.3) lib/active_record/connection_adapters/abstract/database_statements.rb:175:in `update'
activerecord (7.0.4.3) lib/active_record/connection_adapters/abstract/query_cache.rb:22:in `update'
activerecord (7.0.4.3) lib/active_record/persistence.rb:513:in `_update_record'
activerecord (7.0.4.3) lib/active_record/persistence.rb:1058:in `_update_row'
activerecord (7.0.4.3) lib/active_record/locking/optimistic.rb:88:in `_update_row'
activerecord (7.0.4.3) lib/active_record/persistence.rb:1080:in `_update_record'
activerecord (7.0.4.3) lib/active_record/attribute_methods/dirty.rb:216:in `_update_record'
activerecord (7.0.4.3) lib/active_record/callbacks.rb:465:in `block in _update_record'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:107:in `run_callbacks'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:929:in `_run_update_callbacks'
activerecord (7.0.4.3) lib/active_record/callbacks.rb:465:in `_update_record'
activerecord (7.0.4.3) lib/active_record/timestamp.rb:121:in `_update_record'
activerecord (7.0.4.3) lib/active_record/persistence.rb:1067:in `create_or_update'
activerecord (7.0.4.3) lib/active_record/callbacks.rb:457:in `block in create_or_update'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:118:in `block in run_callbacks'
activerecord (7.0.4.3) lib/active_record/autosave_association.rb:370:in `around_save_collection_association'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:138:in `run_callbacks'
activerecord (7.0.4.3) lib/active_record/callbacks.rb:457:in `create_or_update'
activerecord (7.0.4.3) lib/active_record/timestamp.rb:126:in `create_or_update'
activerecord (7.0.4.3) lib/active_record/persistence.rb:615:in `save'
activerecord (7.0.4.3) lib/active_record/validations.rb:47:in `save'
activerecord (7.0.4.3) lib/active_record/transactions.rb:298:in `block in save'
activerecord (7.0.4.3) lib/active_record/transactions.rb:354:in `block in with_transaction_returning_status'
activerecord (7.0.4.3) lib/active_record/connection_adapters/abstract/database_statements.rb:314:in `transaction'
activerecord (7.0.4.3) lib/active_record/transactions.rb:350:in `with_transaction_returning_status'
activerecord (7.0.4.3) lib/active_record/transactions.rb:298:in `save'
activerecord (7.0.4.3) lib/active_record/suppressor.rb:50:in `save'
app/models/post_mover.rb:206:in `move'
app/models/post_mover.rb:137:in `block in move_each_post'
activerecord (7.0.4.3) lib/active_record/relation/delegation.rb:88:in `each'
app/models/post_mover.rb:135:in `move_each_post'
app/models/post_mover.rb:88:in `move_posts_to'
app/models/post_mover.rb:26:in `block in to_topic'
activerecord (7.0.4.3) lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
activerecord (7.0.4.3) lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
activerecord (7.0.4.3) lib/active_record/connection_adapters/abstract/database_statements.rb:316:in `transaction'
activerecord (7.0.4.3) lib/active_record/transactions.rb:209:in `transaction'
app/models/post_mover.rb:26:in `to_topic'
app/models/topic.rb:1239:in `move_posts'
app/controllers/topics_controller.rb:827:in `merge_topic'
actionpack (7.0.4.3) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.0.4.3) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (7.0.4.3) lib/action_controller/metal/rendering.rb:53:in `process_action'
actionpack (7.0.4.3) lib/abstract_controller/callbacks.rb:234:in `block in process_action'
app/controllers/application_controller.rb:414:in `block in with_resolved_locale'
i18n (1.12.0) lib/i18n.rb:322:in `with_locale'
app/controllers/application_controller.rb:414:in `with_resolved_locale'
actionpack (7.0.4.3) lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack (7.0.4.3) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (7.0.4.3) lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport (7.0.4.3) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.0.4.3) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.0.4.3) lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack (7.0.4.3) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.0.4.3) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (7.0.4.3) lib/abstract_controller/base.rb:151:in `process'
actionview (7.0.4.3) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (3.0.0) lib/mini_profiler/profiling_methods.rb:111:in `block in profile_method'
actionpack (7.0.4.3) lib/action_controller/metal.rb:188:in `dispatch'
actionpack (7.0.4.3) lib/action_controller/metal.rb:251:in `dispatch'
actionpack (7.0.4.3) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.0.4.3) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.0.4.3) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (7.0.4.3) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (7.0.4.3) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.0.4.3) lib/action_dispatch/routing/route_set.rb:852:in `call'
lib/middleware/omniauth_bypass_middleware.rb:74:in `call'
rack (2.2.6.4) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.6.4) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.6.4) lib/rack/head.rb:12:in `call'
actionpack (7.0.4.3) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
lib/middleware/anonymous_cache.rb:369:in `call'
rack (2.2.6.4) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.6.4) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/
¿Alguien puede sugerirme cómo solucionar este error, por favor?
¡Gracias de antemano!
1 me gusta
Encontré un problema similar que se solucionó hace 5 años:
¿Tu foro ha sido importado?
1 me gusta
Gracias por tu comentario @Canapin.
Acabo de revisar el tema y no encontré una solución para mi problema.
No, fue una instalación limpia. No se importó ningún contenido. :slight_smile:
Lo mismo aquí, versión actual
Por ‘lo mismo’, ¿te refieres a un error 500 o a un error 500 y el mismo error en /logs?
No puedo mover temas antiguos, incluso los temas nuevos devuelven este error en la consola.
¿Miraste los registros de errores en tu foro? ¿Puedes compartir el error detallado?
1 me gusta
No se pudo procesar correctamente la respuesta secuestrada: ActiveRecord::StatementInvalid: PG::DatetimeFieldOverflow: ERROR: timestamp fuera de rango: \"2739932-10-20 22:37:03.335108\" LÍNEA 1: ...uration_minutes\",
Como un error de marca de tiempo, algo así como un problema anterior
Ok, lo entiendo, mi problema es: /admin/site_settings/category/all_results?filter=delete%20merged Definí 999999999, establecí 7 días y ¡listo, solucionado!
Qué tonto soy.
1 me gusta
He he listado como no listado y configurado un temporizador para eliminar este tema, porque es confuso y el problema original de 2023 nunca se resolvió, y no tiene nada que ver con el problema que @eisammy está publicando más recientemente.
@eisammy en el futuro, por favor, inicia nuevos temas para discutir nuevos problemas y proporciona suficiente información en tus temas sobre el problema que estás encontrando para que tus compañeros de la comunidad aquí puedan ayudarte.
1 me gusta
