アプリの再構築ができません - Data Explorer プラグインの問題の可能性?
皆さんこんにちは、
私の Discourse のバージョンは 2.6.0.beta2 ( 5d7055779a ) です。
./launcher rebuild app コマンドでコマンドラインから Discourse を再構築しようとして問題が発生しています。
一見正常に進んでいるように見えますが、その後以下のように終了してしまいます:
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/tasks/database_tasks.rb:238:in `migrate'
/var/www/discourse/lib/tasks/db.rake:215:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => db:migrate
I, [2020-09-05T08:25:58.657559 #1]  INFO -- : == 20200810053843 CreateDataExplorerQueries: migrating ========================
-- create_table(:data_explorer_queries)
   -> 0.0106s
-- create_table(:data_explorer_query_groups)
   -> 0.0094s
-- add_index(:data_explorer_query_groups, [:query_id, :group_id], {:unique=>true})
   -> 0.0027s
I, [2020-09-05T08:25:58.658141 #1]  INFO -- : Terminating async processes
I, [2020-09-05T08:25:58.658212 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/12/bin/postmaster -D /etc/postgresql/12/main pid: 49
I, [2020-09-05T08:25:58.658286 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 166
166:signal-handler (1599294358) Received SIGTERM scheduling shutdown...
2020-09-05 08:25:58.659 UTC [49] LOG:  received fast shutdown request
2020-09-05 08:25:58.660 UTC [49] LOG:  aborting any active transactions
2020-09-05 08:25:58.666 UTC [49] LOG:  background worker "logical replication launcher" (PID 58) exited with exit code 1
2020-09-05 08:25:58.667 UTC [53] LOG:  shutting down
2020-09-05 08:25:58.683 UTC [49] LOG:  database system is shut down
166:M 05 Sep 2020 08:25:58.719 # User requested shutdown...
166:M 05 Sep 2020 08:25:58.719 * Saving the final RDB snapshot before exiting.
166:M 05 Sep 2020 08:25:59.567 * DB saved on disk
166:M 05 Sep 2020 08:25:59.567 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 3035 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
5146d792aacf0286c008994c87539929db643cb326e686d9fb2a14095697b12b
幸い、サイトは現在も動作しています。
Data Explorer プラグインを削除すると、サイトは正常に再構築されます。
しかし、app.yml に Data Explorer を再度追加すると、再構築に失敗します。
私の app.yml の関連部分は以下の通りです:
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/paviliondev/discourse-locations.git
          - git clone https://github.com/merefield/discourse-onebox-assistant.git
          - git clone https://github.com/discourse/discourse-data-explorer.git
run:
  ## If you want to set the 'From' email address
何かアドバイスをお願いします。
類似の事例:
もしかして :thinking:
ご提示のクエリを実行すると、以下の結果が得られます。
ただし、正直なところ、この分野には詳しくなく、これが良いことなのか悪いことなのかも、次に何をすべきかもわかりません :grimacing:
同一です - @merefield さん、ありがとうございます。
おっしゃる通り、あなたが他の投稿で共有したクエリを実行すると、いくつかの重複したデータエクスプローラークエリが表示されました。
思い切って、あなたがやったように、ID の大きい方を削除し、ID の小さい方を残すことにしました。
その後、Data Explorer プラグインを app.yml に再度追加しましたが、問題やエラーなく正常に再構築されました。
ありがとうございました :bowing_man:
