Launcher rebuild app Failure
The user omppatil encountered a failure while rebuilding the Discourse app using ./launcher rebuild app, with the error pointing to a plugin issue. The error occurred during the db:migrate step, specifically due to a register_asset call in the dsc-hide-post-toggle plugin, which is no longer supported. Firepup650 identified the issue and suggested removing the plugin, which omppatil confirmed resolved the problem after removing the manual register_asset calls.
Hello!,
I tried to rebuild Discourse using ./launcher rebuild app and after that it fails to rebuild , giving following error:
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 3316 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
Actually I’m trying to upload my plugin in Discourse which I have developed locally which works fine on the local environment and but when I try to upload plugin to the Discourse server it gives above error and with some warnings which are as follows:
warning "@discourse/lint-configs > eslint-plugin-ember > ember-eslint-parser@0.2.5" has unmet peer dependency "@typescript-eslint/parser@^6.15.0".
warning "@discourse/lint-configs > eslint-plugin-ember > ember-eslint-parser@0.2.5" has incorrect peer dependency "typescript@^5.3.3".
warning " > @glint/environment-ember-loose@1.3.0" has unmet peer dependency "@glimmer/component@^1.1.2".
warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
warning Pattern ["wrap-ansi@^7.0.0"] is trying to unpack in the same destination "/home/discourse/.cache/yarn/v6/npm-wrap-ansi-cjs-7.0.0-67e145cff510a6a6984bdf1152911d69d2eb9e43-integrity/node_modules/wrap-ansi-cjs" as pattern ["wrap-ansi-cjs@npm:wrap-ansi@^7.0.0"]. This could result in non-deterministic behavior, skipping.
warning " > discourse-markdown-it@1.0.0" has unmet peer dependency "xss@*".
warning "workspace-aggregator-98dafb8f-3047-47b1-9d38-9da6ff65f457 > discourse > @uppy/aws-s3@3.0.6" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-98dafb8f-3047-47b1-9d38-9da6ff65f457 > discourse > @uppy/aws-s3-multipart@3.1.3" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-98dafb8f-3047-47b1-9d38-9da6ff65f457 > discourse > @uppy/xhr-upload@3.1.1" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-98dafb8f-3047-47b1-9d38-9da6ff65f457 > discourse > ember-router-service-refresh-polyfill@1.1.0" has incorrect peer dependency "ember-source@^3.4 || 4".
warning "workspace-aggregator-98dafb8f-3047-47b1-9d38-9da6ff65f457 > discourse-plugins > ember-this-fallback@0.4.0" has unmet peer dependency "ember-source@^3.28.11 || ^4.0.0".
warning "workspace-aggregator-98dafb8f-3047-47b1-9d38-9da6ff65f457 > admin > ember-source > router_js@8.0.3" has unmet peer dependency "rsvp@^4.8.5".
warning "workspace-aggregator-98dafb8f-3047-47b1-9d38-9da6ff65f457 > discourse > @uppy/aws-s3 > @uppy/xhr-upload@3.3.0" has incorrect peer dependency "@uppy/core@^3.2.1".
I even cleaned up the containers using ./launcher cleanup and tried rebuilding it. But nothing worked.
Can anyone guide me to get this issue resolved?
Hello,
it would help if you could do that or paste the log here. :+1:
The warnings are expected and can be ignored!
I, [2024-02-06T12:34:29.772046 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2024-02-06 12:34:29.917 UTC [54] postgres@postgres ERROR:  database "discourse" already exists
2024-02-06 12:34:29.917 UTC [54] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2024-02-06T12:34:29.921646 #1]  INFO -- :
I, [2024-02-06T12:34:29.922307 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2024-02-06 12:34:30.035 UTC [58] postgres@discourse ERROR:  role "discourse" already exists
2024-02-06 12:34:30.035 UTC [58] postgres@discourse STATEMENT:  create user discourse;
I, [2024-02-06T12:34:30.038648 #1]  INFO -- :
I, [2024-02-06T12:34:30.039394 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2024-02-06T12:34:30.115792 #1]  INFO -- : GRANT
I, [2024-02-06T12:34:30.116712 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2024-02-06T12:34:30.196923 #1]  INFO -- : ALTER SCHEMA
I, [2024-02-06T12:34:30.197758 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2024-02-06T12:34:30.305929 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-06T12:34:30.306810 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2024-02-06T12:34:30.383971 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-06T12:34:30.384850 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists vector;"'
NOTICE:  extension "vector" already exists, skipping
I, [2024-02-06T12:34:30.456459 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-06T12:34:30.457296 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2024-02-06T12:34:30.535128 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-06T12:34:30.535940 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2024-02-06T12:34:30.606543 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-06T12:34:30.607292 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists vector;"'
I, [2024-02-06T12:34:30.679393 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-06T12:34:30.680298 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2024-02-06T12:34:30.687340 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2024-02-06T12:34:30.807686 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2024-02-06T12:34:30.818932 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2024-02-06T12:34:30.819617 #1]  INFO -- : > echo postgres installed!
I, [2024-02-06T12:34:30.823257 #1]  INFO -- : postgres installed!
Here are the error messages I found when I scrolled up.
Still not errors. The whole log.
Does your plugin do any database migrations? Maybe share a link to it
This is the whole log after doing ./launcher rebuild app
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20231218-0429: Pulling from discourse/base
Digest: sha256:468f70b9bb4c6d0c6c2bbb3efc1a5e12d145eae57bdb6946b7fe5558beb52dc1
Status: Image is up to date for discourse/base:2.0.20231218-0429
docker.io/discourse/base:2.0.20231218-0429
/usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-02-06T14:18:26.260895 #1]  INFO -- : Reading from stdin
I, [2024-02-06T14:18:26.273805 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2024-02-06T14:18:26.352125 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2024-02-06T14:18:26.352980 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2024-02-06T14:18:26.356630 #1]  INFO -- :
I, [2024-02-06T14:18:26.357542 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2024-02-06T14:18:26.361423 #1]  INFO -- :
I, [2024-02-06T14:18:26.362096 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2024-02-06T14:18:26.364494 #1]  INFO -- :
I, [2024-02-06T14:18:26.365242 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2024-02-06T14:18:26.368363 #1]  INFO -- :
I, [2024-02-06T14:18:26.368969 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2024-02-06T14:18:26.371436 #1]  INFO -- :
I, [2024-02-06T14:18:26.372124 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2024/02/06 14:18:26 socat[18] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2024-02-06T14:18:26.384491 #1]  INFO -- :
I, [2024-02-06T14:18:26.385119 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2024-02-06T14:18:26.389313 #1]  INFO -- :
I, [2024-02-06T14:18:26.389932 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2024-02-06T14:18:26.393828 #1]  INFO -- :
I, [2024-02-06T14:18:26.394439 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2024-02-06T14:18:26.397864 #1]  INFO -- :
I, [2024-02-06T14:18:26.398558 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2024-02-06T14:18:26.401379 #1]  INFO -- :
I, [2024-02-06T14:18:26.407865 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2024-02-06T14:18:26.414052 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2024-02-06T14:18:26.420350 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2024-02-06T14:18:26.425985 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2024-02-06T14:18:26.426819 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2024-02-06T14:18:29.957091 #1]  INFO -- :
I, [2024-02-06T14:18:29.958357 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2024-02-06T14:18:29.962053 #1]  INFO -- :
I, [2024-02-06T14:18:29.962675 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2024-02-06T14:18:30.005248 #1]  INFO -- :
I, [2024-02-06T14:18:30.006245 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2024-02-06T14:18:30.010124 #1]  INFO -- :
I, [2024-02-06T14:18:30.011061 #1]  INFO -- : > /root/upgrade_postgres
I, [2024-02-06T14:18:30.025786 #1]  INFO -- :
I, [2024-02-06T14:18:30.026082 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2024-02-06T14:18:30.031110 #1]  INFO -- :
I, [2024-02-06T14:18:30.034124 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-06T14:18:30.035045 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-06T14:18:30.035465 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-06T14:18:30.036472 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-06T14:18:30.037322 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-06T14:18:30.038051 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-06T14:18:30.038858 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2024-02-06T14:18:30.044011 #1]  INFO -- :
I, [2024-02-06T14:18:30.045054 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-06T14:18:30.046123 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-06T14:18:30.046991 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-06T14:18:30.048633 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-02-06T14:18:30.049563 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-02-06T14:18:30.050826 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-02-06T14:18:30.051424 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-02-06T14:18:30.054166 #1]  INFO -- : > sleep 5
2024-02-06 14:18:30.161 UTC [41] LOG:  starting PostgreSQL 13.13 (Debian 13.13-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2024-02-06 14:18:30.163 UTC [41] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2024-02-06 14:18:30.164 UTC [41] LOG:  listening on IPv6 address "::", port 5432
2024-02-06 14:18:30.175 UTC [41] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-02-06 14:18:30.190 UTC [44] LOG:  database system was shut down at 2024-02-06 14:15:37 UTC
2024-02-06 14:18:30.203 UTC [41] LOG:  database system is ready to accept connections
I, [2024-02-06T14:18:35.059469 #1]  INFO -- :
I, [2024-02-06T14:18:35.059863 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2024-02-06 14:18:35.203 UTC [54] postgres@postgres ERROR:  database "discourse" already exists
2024-02-06 14:18:35.203 UTC [54] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
I, [2024-02-06T14:18:35.206739 #1]  INFO -- :
I, [2024-02-06T14:18:35.207533 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2024-02-06 14:18:35.330 UTC [58] postgres@discourse ERROR:  role "discourse" already exists
2024-02-06 14:18:35.330 UTC [58] postgres@discourse STATEMENT:  create user discourse;
I, [2024-02-06T14:18:35.334356 #1]  INFO -- :
I, [2024-02-06T14:18:35.335100 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2024-02-06T14:18:35.406985 #1]  INFO -- : GRANT
I, [2024-02-06T14:18:35.407749 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2024-02-06T14:18:35.482659 #1]  INFO -- : ALTER SCHEMA
I, [2024-02-06T14:18:35.483378 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
I, [2024-02-06T14:18:35.564958 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-06T14:18:35.565622 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
I, [2024-02-06T14:18:35.635827 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-06T14:18:35.636470 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists vector;"'
I, [2024-02-06T14:18:35.704628 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-06T14:18:35.705404 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2024-02-06T14:18:35.781299 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-06T14:18:35.781945 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2024-02-06T14:18:35.850284 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-06T14:18:35.850951 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists vector;"'
I, [2024-02-06T14:18:35.919005 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-06T14:18:35.919852 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2024-02-06T14:18:35.926081 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2024-02-06T14:18:36.036112 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2024-02-06T14:18:36.044311 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2024-02-06T14:18:36.045089 #1]  INFO -- : > echo postgres installed!
I, [2024-02-06T14:18:36.048379 #1]  INFO -- : postgres installed!
I, [2024-02-06T14:18:36.054139 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2024-02-06T14:18:36.060031 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2024-02-06T14:18:36.065442 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2024-02-06T14:18:36.067526 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2024-02-06T14:18:36.068816 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2024-02-06T14:18:36.069797 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-02-06T14:18:36.073493 #1]  INFO -- :
I, [2024-02-06T14:18:36.074402 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-02-06T14:18:36.075399 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2024-02-06T14:18:36.076391 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-02-06T14:18:36.077382 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-02-06T14:18:36.078228 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-02-06T14:18:36.079108 #1]  INFO -- : > echo redis installed
I, [2024-02-06T14:18:36.082478 #1]  INFO -- : redis installed
I, [2024-02-06T14:18:36.083158 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-02-06T14:18:36.088540 #1]  INFO -- : logfile ""
I, [2024-02-06T14:18:36.089149 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-02-06T14:18:36.091164 #1]  INFO -- : > sleep 10
110:C 06 Feb 2024 14:18:36.110 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
110:C 06 Feb 2024 14:18:36.111 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=110, just started
110:C 06 Feb 2024 14:18:36.111 # Configuration loaded
110:M 06 Feb 2024 14:18:36.112 * monotonic clock: POSIX clock_gettime
110:M 06 Feb 2024 14:18:36.113 * Running mode=standalone, port=6379.
110:M 06 Feb 2024 14:18:36.114 # Server initialized
110:M 06 Feb 2024 14:18:36.114 * Loading RDB produced by version 7.0.7
110:M 06 Feb 2024 14:18:36.115 * RDB age 179 seconds
110:M 06 Feb 2024 14:18:36.115 * RDB memory usage when created 7.85 Mb
110:M 06 Feb 2024 14:18:36.145 * Done loading RDB, keys loaded: 1117, keys expired: 0.
110:M 06 Feb 2024 14:18:36.146 * DB loaded from disk: 0.031 seconds
110:M 06 Feb 2024 14:18:36.146 * Ready to accept connections
I, [2024-02-06T14:18:46.095442 #1]  INFO -- :
I, [2024-02-06T14:18:46.096340 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-02-06T14:18:46.116357 #1]  INFO -- : thpoff is installed!
I, [2024-02-06T14:18:46.117325 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2024-02-06T14:18:46.241320 #1]  INFO -- :
I, [2024-02-06T14:18:46.242077 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2024-02-06T14:18:46.367601 #1]  INFO -- :
I, [2024-02-06T14:18:46.368355 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-02-06T14:18:46.494449 #1]  INFO -- :
I, [2024-02-06T14:18:46.495204 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-02-06T14:18:46.500083 #1]  INFO -- :
I, [2024-02-06T14:18:46.503817 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2024-02-06T14:18:46.519146 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2024-02-06T14:18:46.524878 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2024-02-06T14:18:46.530345 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2024-02-06T14:18:46.535624 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2024-02-06T14:18:46.540932 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2024-02-06T14:18:46.541436 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2024-02-06T14:18:46.542092 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-02-06T14:18:46.545346 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
137:C 06 Feb 2024 14:18:46.563 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
137:C 06 Feb 2024 14:18:46.564 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=137, just started
137:C 06 Feb 2024 14:18:46.564 # Configuration loaded
137:M 06 Feb 2024 14:18:46.565 * monotonic clock: POSIX clock_gettime
137:M 06 Feb 2024 14:18:46.566 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
137:M 06 Feb 2024 14:18:46.566 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (33715/33715), done.
I, [2024-02-06T14:18:56.293089 #1]  INFO -- : HEAD is now at 6ab1a19e9 DEV: Convert min_trust_level_to_allow_invite to groups (#24893)
I, [2024-02-06T14:18:56.301032 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-02-06T14:18:56.550228 #1]  INFO -- :
I, [2024-02-06T14:18:56.550905 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
From https://github.com/discourse/discourse
 - [deleted]             (none)     -> origin/0-drop-code
 - [deleted]             (none)     -> origin/bulk-button-class
 - [deleted]             (none)     -> origin/dependabot/bundler/excon-0.108.0
 - [deleted]             (none)     -> origin/dependabot/bundler/hashdiff-1.1.0
 - [deleted]             (none)     -> origin/dependabot/bundler/parallel-1.24.0
 - [deleted]             (none)     -> origin/dependabot/bundler/rubocop-discourse-3.6.0
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/drop-target-2.0.2
 - [deleted]             (none)     -> origin/dev/add-new-chat-metrics
 - [deleted]             (none)     -> origin/dev/allow-chat-mentions-to-have-several-notifications
 - [deleted]             (none)     -> origin/dev/convert-min-trust-level-to-create-tag-to-group
 - [deleted]             (none)     -> origin/dev/convert-min-trust-level-to-ignore-to-groups
 - [deleted]             (none)     -> origin/dev/rethink-mass-mentions-polymorphic
 - [deleted]             (none)     -> origin/feature/migrations-schema-generator
 - [deleted]             (none)     -> origin/fix-join-filter-upload
 - [deleted]             (none)     -> origin/fix-modal-flash-minor
 - [deleted]             (none)     -> origin/global-notice-reactive
 - [deleted]             (none)     -> origin/labeler
 - [deleted]             (none)     -> origin/low-ram-help
 - [deleted]             (none)     -> origin/multi-invite
 - [deleted]             (none)     -> origin/plugin-extra-js
 - [deleted]             (none)     -> origin/table-builder-modal-modifier
 - [deleted]             (none)     -> origin/wip_categories
 - [deleted]             (none)     -> origin/wizard-split
   6ab1a19e9..7fcd7d53f  main                    -> origin/main
 * [new branch]          0-ember-bump            -> origin/0-ember-bump
 * [new branch]          0-event-helper          -> origin/0-event-helper
 * [new branch]          0-extend-native         -> origin/0-extend-native
 * [new branch]          0-rev                   -> origin/0-rev
 * [new branch]          add-api-for-forced-auth -> origin/add-api-for-forced-auth
 * [new branch]          amend-visit-copy        -> origin/amend-visit-copy
 * [new branch]          api-image-wrapper       -> origin/api-image-wrapper
 * [new branch]          asciinema-iframe        -> origin/asciinema-iframe
 * [new branch]          bulk-select-dropdown-items -> origin/bulk-select-dropdown-items
 * [new branch]          convert-header-to-glimmer -> origin/convert-header-to-glimmer
 * [new branch]          decorator-transforms    -> origin/decorator-transforms
 * [new branch]          dependabot/bundler/omniauth-2.0.0 -> origin/dependabot/bundler/omniauth-2.0.0
 * [new branch]          dependabot/bundler/parallel_tests-4.4.0 -> origin/dependabot/bundler/parallel_tests-4.4.0
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/content-tag-2.0.1 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/content-tag-2.0.1
 * [new branch]          dev-convert-topic-map-expanded-widget-to-component -> origin/dev-convert-topic-map-expanded-widget-to-component
 * [new branch]          dev/check-whether-online-user-ids-may-be-memoized-between-job-runs -> origin/dev/check-whether-online-user-ids-may-be-memoized-between-job-runs
 * [new branch]          dev/drop-the-user-id-column-from-chat-mentions -> origin/dev/drop-the-user-id-column-from-chat-mentions
 + e0c0191bb...7029ef16f dev/dry-up-user-status-serializers -> origin/dev/dry-up-user-status-serializers  (forced update)
 * [new branch]          dev/experiment-theme-settings-free-ui -> origin/dev/experiment-theme-settings-free-ui
 * [new branch]          dev/make-admins-tl4-in-tests -> origin/dev/make-admins-tl4-in-tests
 * [new branch]          dev/promote-plugin-post-deploy-migrations -> origin/dev/promote-plugin-post-deploy-migrations
 * [new branch]          dev/proof-of-concept-rewriting-mentions-notification-logic -> origin/dev/proof-of-concept-rewriting-mentions-notification-logic
 * [new branch]          dev_category_order_database -> origin/dev_category_order_database
 * [new branch]          dev_update_category_position -> origin/dev_update_category_position
 * [new branch]          extra-js-revert         -> origin/extra-js-revert
 * [new branch]          fast-edit-expand-regex  -> origin/fast-edit-expand-regex
 * [new branch]          feature/add-new-illegal-flag-reason -> origin/feature/add-new-illegal-flag-reason
 * [new branch]          feature/custom-date-range -> origin/feature/custom-date-range
 * [new branch]          feature/paste-upload-on-first-upload-input-templates -> origin/feature/paste-upload-on-first-upload-input-templates
 * [new branch]          feature_async_hashtags  -> origin/feature_async_hashtags
 * [new branch]          feature_async_load_colors -> origin/feature_async_load_colors
 * [new branch]          fix-email-category-badge -> origin/fix-email-category-badge
 * [new branch]          fix_category_chooser    -> origin/fix_category_chooser
 * [new branch]          fix_in_any_groups       -> origin/fix_in_any_groups
 * [new branch]          fix_reviewable_translation -> origin/fix_reviewable_translation
   7f2bdca65..4f57be1a8  generic-import-latest   -> origin/generic-import-latest
 * [new branch]          hijacks                 -> origin/hijacks
 * [new branch]          issue/run-admin-sidebar-init-after-logs-notice -> origin/issue/run-admin-sidebar-init-after-logs-notice
 * [new branch]          loic-rubocop-plugin-rules -> origin/loic-rubocop-plugin-rules
 + 90a3535b7...e6e64cfd5 migrations-convert      -> origin/migrations-convert  (forced update)
 * [new branch]          promote-migration-tweak -> origin/promote-migration-tweak
 * [new branch]          redesign-my-threads-index -> origin/redesign-my-threads-index
 * [new branch]          remove-widget-search-menu -> origin/remove-widget-search-menu
 * [new branch]          revert-25009-dev/convert-min-trust-to-allow-self-wiki-to-groups -> origin/revert-25009-dev/convert-min-trust-to-allow-self-wiki-to-groups
 * [new branch]          revert-bulk-topic-actions -> origin/revert-bulk-topic-actions
 * [new branch]          sidebar-above-outlet    -> origin/sidebar-above-outlet
 * [new branch]          site-logo-height        -> origin/site-logo-height
 * [new branch]          sort-chat-channels-by-activity -> origin/sort-chat-channels-by-activity
   d7f7f79b6..07fb62331  stable                  -> origin/stable
 * [new branch]          support-reset-bump-date-post-id -> origin/support-reset-bump-date-post-id
 * [new branch]          system-test-for-soft-load-search -> origin/system-test-for-soft-load-search
   6ab1a19e9..7fcd7d53f  tests-passed            -> origin/tests-passed
 * [new branch]          unhide_lazy_load_categories -> origin/unhide_lazy_load_categories
 * [new branch]          universal-nonce         -> origin/universal-nonce
 * [new branch]          unread-mobile-indicator -> origin/unread-mobile-indicator
 * [new branch]          ux-user-name            -> origin/ux-user-name
 * [new branch]          virtual-scroll-list     -> origin/virtual-scroll-list
 t [tag update]          beta                    -> beta
 t [tag update]          latest-release          -> latest-release
 * [new tag]             v3.1.4                  -> v3.1.4
 * [new tag]             v3.1.5                  -> v3.1.5
 * [new tag]             v3.2.0                  -> v3.2.0
 * [new tag]             v3.2.0.beta4            -> v3.2.0.beta4
 * [new tag]             v3.2.0.beta5            -> v3.2.0.beta5
I, [2024-02-06T14:18:58.135755 #1]  INFO -- :
I, [2024-02-06T14:18:58.136372 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2024-02-06T14:19:06.214070 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2024-02-06T14:19:06.214701 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-02-06T14:19:06.230463 #1]  INFO -- :
I, [2024-02-06T14:19:06.231175 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-02-06T14:19:06.236452 #1]  INFO -- :
I, [2024-02-06T14:19:06.237281 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-02-06T14:19:06.241609 #1]  INFO -- :
I, [2024-02-06T14:19:06.242215 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-02-06T14:19:06.246902 #1]  INFO -- :
I, [2024-02-06T14:19:06.247515 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-02-06T14:19:06.251905 #1]  INFO -- :
I, [2024-02-06T14:19:06.252450 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-02-06T14:19:06.261339 #1]  INFO -- :
I, [2024-02-06T14:19:06.261955 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2024-02-06T14:19:06.267363 #1]  INFO -- :
I, [2024-02-06T14:19:06.268001 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-02-06T14:19:06.275190 #1]  INFO -- :
I, [2024-02-06T14:19:06.275791 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-02-06T14:19:06.282090 #1]  INFO -- :
I, [2024-02-06T14:19:06.282740 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2024-02-06T14:19:06.288945 #1]  INFO -- :
I, [2024-02-06T14:19:06.289502 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-02-06T14:19:06.295518 #1]  INFO -- :
I, [2024-02-06T14:19:06.296150 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2024-02-06T14:19:06.303580 #1]  INFO -- :
I, [2024-02-06T14:19:06.304174 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-02-06T14:19:06.310252 #1]  INFO -- :
I, [2024-02-06T14:19:06.310761 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2024-02-06T14:19:06.327368 #1]  INFO -- :
I, [2024-02-06T14:19:06.328041 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-02-06T14:19:06.331433 #1]  INFO -- :
I, [2024-02-06T14:19:06.332174 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-02-06T14:19:06.333086 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2024-02-06T14:19:07.513851 #1]  INFO -- :
I, [2024-02-06T14:19:07.514563 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/dvijtest/dsc-hide-post-toggle.git
Cloning into 'dsc-hide-post-toggle'...
I, [2024-02-06T14:19:07.834467 #1]  INFO -- :
I, [2024-02-06T14:19:07.835547 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2024-02-06T14:19:07.852807 #1]  INFO -- :
I, [2024-02-06T14:19:07.853882 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2024-02-06T14:19:07.858082 #1]  INFO -- :
I, [2024-02-06T14:19:07.858823 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2024-02-06T14:19:07.862527 #1]  INFO -- :
I, [2024-02-06T14:19:07.864247 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2024-02-06T14:19:07.865068 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2024-02-06T14:19:07.865857 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2024-02-06T14:19:07.867191 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2024-02-06T14:19:07.867858 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2024-02-06T14:19:07.868625 #1]  INFO -- : > echo "done configuring web"
I, [2024-02-06T14:19:07.871661 #1]  INFO -- : done configuring web
I, [2024-02-06T14:19:07.872445 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2024-02-06T14:19:08.918258 #1]  INFO -- : Successfully installed bundler-2.5.3
1 gem installed
I, [2024-02-06T14:19:08.918920 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2024-02-06T14:19:23.288009 #1]  INFO -- :
I, [2024-02-06T14:19:23.289037 #1]  INFO -- : > cd /var/www/discourse && if [ "tests-passed" != "tests-passed" ]; then
  rm -rf app/assets/javascripts/node_modules
fi
I, [2024-02-06T14:19:23.292704 #1]  INFO -- :
I, [2024-02-06T14:19:23.293207 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
warning "workspace-aggregator-ace11c4b-1818-41aa-9048-5d3fd25df83c > discourse > @uppy/aws-s3@3.0.6" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-ace11c4b-1818-41aa-9048-5d3fd25df83c > discourse > @uppy/aws-s3-multipart@3.1.3" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-ace11c4b-1818-41aa-9048-5d3fd25df83c > discourse > @uppy/xhr-upload@3.1.1" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-ace11c4b-1818-41aa-9048-5d3fd25df83c > discourse > ember-router-service-refresh-polyfill@1.1.0" has incorrect peer dependency "ember-source@^3.4 || 4".
warning "workspace-aggregator-ace11c4b-1818-41aa-9048-5d3fd25df83c > discourse-plugins > ember-this-fallback@0.4.0" has unmet peer dependency "ember-source@^3.28.11 || ^4.0.0".
warning "workspace-aggregator-ace11c4b-1818-41aa-9048-5d3fd25df83c > admin > ember-source > router_js@8.0.3" has unmet peer dependency "rsvp@^4.8.5".
warning "workspace-aggregator-ace11c4b-1818-41aa-9048-5d3fd25df83c > discourse > @uppy/aws-s3 > @uppy/xhr-upload@3.3.0" has incorrect peer dependency "@uppy/core@^3.2.1".
I, [2024-02-06T14:22:58.829490 #1]  INFO -- : yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
[4/5] Linking dependencies...
[5/5] Building fresh packages...
$ yarn --cwd app/assets/javascripts $(node -e 'const argv = JSON.parse(process.env.npm_config_argv).original; const passthrough = [`--frozen-lockfile`, `-s`].filter(arg => argv.includes(arg)); console.log(passthrough.join(` `));')
[1/4] Resolving packages...
[2/4] Fetching packages...
[3/4] Linking dependencies...
[4/4] Building fresh packages...
$ ./run-patch-package
patch-package 8.0.0
Applying patches...
@ember/test-helpers@2.9.4 ✔
babel-plugin-debug-macros@0.3.4 ✔
content-tag@2.0.1 ✔
ember-cli@5.0.0 ✔
ember-this-fallback@0.4.0 (1 deprecation-name) ✔
ember-this-fallback@0.4.0 (2 themes) ✔
ember-this-fallback@0.4.0 (3 exclude-strict-mode) ✔
virtual-dom@2.1.1 ✔
Done in 101.66s.
Done in 193.99s.
yarn cache v1.22.19
success Cleared cache.
Done in 20.02s.
I, [2024-02-06T14:22:58.864095 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle config --local deployment true'
I, [2024-02-06T14:22:59.878242 #1]  INFO -- :
I, [2024-02-06T14:22:59.878878 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle config --local without "development test"'
I, [2024-02-06T14:23:00.186660 #1]  INFO -- : You are replacing the current local value of without, which is currently "test:development"
I, [2024-02-06T14:23:00.187328 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --retry 3 --jobs 4'
I, [2024-02-06T14:24:07.672458 #1]  INFO -- : Fetching gem metadata from https://rubygems.org/.........
Fetching concurrent-ruby 1.2.3
Fetching minitest 5.22.0
Fetching bigdecimal 3.1.6
Fetching cbor 0.5.9.8
Installing cbor 0.5.9.8 with native extensions
Installing bigdecimal 3.1.6 with native extensions
Installing minitest 5.22.0
Installing concurrent-ruby 1.2.3
Fetching excon 0.109.0
Fetching fastimage 2.3.0
Installing excon 0.109.0
Installing fastimage 2.3.0
Fetching google-protobuf 3.25.2 (x86_64-linux)
Fetching highline 3.0.1
Installing highline 3.0.1
Installing google-protobuf 3.25.2 (x86_64-linux)
Fetching image_size 3.4.0
Installing image_size 3.4.0
Fetching regexp_parser 2.9.0
Fetching logster 2.16.0
Installing regexp_parser 2.9.0
Installing logster 2.16.0
Fetching stackprof 0.2.26
Installing stackprof 0.2.26 with native extensions
Fetching nokogiri 1.16.2 (x86_64-linux)
Installing nokogiri 1.16.2 (x86_64-linux)
Fetching bootsnap 1.18.3
Installing bootsnap 1.18.3 with native extensions
Fetching rack-protection 3.2.0
Installing rack-protection 3.2.0
Fetching net-http 0.4.1
Installing net-http 0.4.1
Fetching sass-embedded 1.70.0 (x86_64-linux-gnu)
Installing sass-embedded 1.70.0 (x86_64-linux-gnu)
Fetching puma 6.4.2
Installing puma 6.4.2 with native extensions
Fetching rbtrace 0.5.1
Installing rbtrace 0.5.1 with native extensions
Fetching net-imap 0.4.10
Installing net-imap 0.4.10
Fetching net-smtp 0.4.0.1
Installing net-smtp 0.4.0.1
Fetching activesupport 7.0.8
Installing activesupport 7.0.8
Fetching tzinfo-data 1.2024.1
Installing tzinfo-data 1.2024.1
Fetching faraday-net_http 3.1.0
Installing faraday-net_http 3.1.0
Fetching sassc-embedded 1.70.0
Installing sassc-embedded 1.70.0
Fetching activemodel 7.0.8
Installing activemodel 7.0.8
Fetching faraday 2.9.0
Installing faraday 2.9.0
Fetching actionview 7.0.8
Installing actionview 7.0.8
Fetching activejob 7.0.8
Installing activejob 7.0.8
Fetching activerecord 7.0.8
Installing activerecord 7.0.8
Fetching actionpack 7.0.8
Installing actionpack 7.0.8
Fetching actionmailer 7.0.8
Installing actionmailer 7.0.8
Fetching railties 7.0.8
Installing railties 7.0.8
Bundle complete! 138 Gemfile dependencies, 170 gems now installed.
Gems in the groups 'development' and 'test' were not installed.
Bundled gems are installed into `./vendor/bundle`
I, [2024-02-06T14:24:07.673684 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2024-02-06T14:24:15.520240 #1]  INFO -- : docker_manager is already at latest compatible version
dsc-hide-post-toggle is already at latest compatible version
I, [2024-02-06T14:24:15.521342 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
[dsc-hide-post-toggle] Javascript files under `assets/javascripts` are automatically included in JS bundles.
Manual register_asset calls should be removed. (attempted to add javascripts/discourse/initializers/dsc-hide-post-toggle.js.es6)
/var/www/discourse/lib/plugin/instance.rb:666:in `register_asset'
/var/www/discourse/plugins/dsc-hide-post-toggle/plugin.rb:7:in `activate!'
/var/www/discourse/lib/plugin/instance.rb:727:in `instance_eval'
/var/www/discourse/lib/plugin/instance.rb:727:in `activate!'
/var/www/discourse/lib/discourse.rb:347:in `block in activate_plugins!'
/var/www/discourse/lib/discourse.rb:344:in `each'
/var/www/discourse/lib/discourse.rb:344:in `activate_plugins!'
/var/www/discourse/config/application.rb:227:in `block in <class:Application>'
/var/www/discourse/lib/plugin.rb:6:in `initialization_guard'
/var/www/discourse/config/application.rb:227:in `<class:Application>'
/var/www/discourse/config/application.rb:75:in `<module:Discourse>'
/var/www/discourse/config/application.rb:74:in `<top (required)>'
<internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:37:in `require'
/var/www/discourse/Rakefile:7:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/exe/rake:27:in `<top (required)>'
I, [2024-02-06T14:24:18.095914 #1]  INFO -- :
I, [2024-02-06T14:24:18.097032 #1]  INFO -- : Terminating async processes
I, [2024-02-06T14:24:18.097491 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 41
I, [2024-02-06T14:24:18.097819 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 110
2024-02-06 14:24:18.098 UTC [41] LOG:  received fast shutdown request
110:signal-handler (1707229458) Received SIGTERM scheduling shutdown...
2024-02-06 14:24:18.119 UTC [41] LOG:  aborting any active transactions
2024-02-06 14:24:18.128 UTC [41] LOG:  background worker "logical replication launcher" (PID 50) exited with exit code 1
2024-02-06 14:24:18.129 UTC [45] LOG:  shutting down
2024-02-06 14:24:18.184 UTC [41] LOG:  database system is shut down
110:M 06 Feb 2024 14:24:18.197 # User requested shutdown...
110:M 06 Feb 2024 14:24:18.199 * Saving the final RDB snapshot before exiting.
110:M 06 Feb 2024 14:24:18.264 * DB saved on disk
110:M 06 Feb 2024 14:24:18.266 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 3317 exit 1>
This seems like the fatal failure:
Could you try removing the dsc-hide-post-toggle plugin/theme from your instance and rebuilding?
I removed manual register_asset calls and was able to rebuild.
