Errores no capturados
I got many errors as below:
Summary
Uncaught Error: Nothing handled the action 'refresh'. If you did handle the action, this error can be caused by returning true from an action handler in a controller, causing the action to bubble. Url
Fr 11:45 pm
Uncaught TypeError: document.getElementsByClassName.ToString is not a function Url: Line: 1 Column: 33 Window Location: https://abc.com/t/4564adbbds/45574
Fr 11:47 pm
Uncaught TypeError: document.getElementsByClassName.ToString is not a function Url: Line: 1 Column: 33 Window Location: https://abc.com/t/thjuekksbjal
12:41 am
Uncaught TypeError: document.getElementsByClassName.ToString is not a function Url: Line: 1 Column: 33 Window Location: https://abc.com/t/howcanidoit/1254
12:44 am
Unable to get property 'getItem' of undefined or null reference Url: https://abc.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js Line: 2 Column: 10713 W
1:13 am
8
TypeError: Cannot call method "create" of undefined (https://abc.com/assets/vendor-6e59f8d0190b766ab492d48c83983f67bb7a5ecbff9e213f79fa12e4c72a06e6.js#4) Url: https://vnzones.com/ Line: 4 Column:		1:31 am
2:13 am
Could not find module `pretty-text/censored-words` imported from `discourse/models/topic` Url: https://abc.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.
3:28 am
Uncaught SyntaxError: Unexpected token else Url: https://abc.com/t/xiaomi-mi-max-319-7/1274 Line: 6 Column: 10 Window Location: https://abc.com/t/xiaomi-mi-max
3:41 am
TypeError: undefined is not an object (evaluating 'd.tagName.toUpperCase') Url: https://abc.com/c/hotnews Line: 1 Column: 265 Window Location: https://abc.com/c/hotnews
4:56 am
5:23 am
3
6:23 am
9
NoMethodError (undefined method `id' for nil:NilClass) /var/www/discourse/plugins/discourse-question-answer/lib/qa_post_edits.rb:12:in `actions_summary'
How can I fix?
Don’t despair. Take a safe first step.
But what made these errors and how can I fix?
Probably disable the plugin: discourse-question-answer
The author corrected.
