Variabile indefinita 'target_locale' nel plugin libre_translate.rb Discourse Translator
Ho installato Discourse Translator e ho provato a usarlo con la mia istanza self-hosted di LibreTranslate. Non ha funzionato e ho ottenuto il seguente backtrace:
NameError (variabile locale non definita o metodo `target_locale' per la classe DiscourseTranslator::LibreTranslate)
app/controllers/application_controller.rb:427:in `block in with_resolved_locale'
app/controllers/application_controller.rb:427:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:35:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
lib/middleware/anonymous_cache.rb:409:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/processing_request.rb:12:in `call'
lib/middleware/request_tracker.rb:385:in `call'
Backtrace
plugins/discourse-translator/app/services/discourse_translator/libre_translate.rb:107:in `block in translate!'
plugins/discourse-translator/app/services/discourse_translator/base.rb:82:in `save_translation'
plugins/discourse-translator/app/services/discourse_translator/libre_translate.rb:101:in `translate!'
plugins/discourse-translator/app/services/discourse_translator/base.rb:51:in `translate'
plugins/discourse-translator/app/controllers/discourse_translator/translator_controller.rb:44:in `translate'
actionpack (7.2.2.1) lib/action_controller/metal/basic_implicit_render.rb:8:in `send_action'
actionpack (7.2.2.1) lib/abstract_controller/base.rb:226:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/rendering.rb:193:in `process_action'
actionpack (7.2.2.1) lib/abstract_controller/callbacks.rb:261:in `block in process_action'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:121:in `block in run_callbacks'
i18n (1.14.7) lib/i18n.rb:353:in `with_locale'
Controllando il codice:
    def self.translate!(translatable, target_locale_sym = I18n.locale)
      detected_lang = detect(translatable)
      save_translation(translatable, target_locale_sym) do
        res =
          result(
            translate_uri,
            q: text_for_translation(translatable),
            source: detected_lang,
            target: SUPPORTED_LANG_MAPPING[target_locale],
            format: "html",
        res["translatedText"]
in particolare la riga 107, che è:
→ sembra che debba essere ‘target_locale_sym’ invece di ‘target_locale’ o mi sbaglio?
L’ho modificato manualmente in: target: SUPPORTED_LANG_MAPPING[target_locale_sym], ho salvato e riavviato l’app e ha funzionato.
3 Mi Piace
Ciao, grazie per la segnalazione. Daremo priorità a una correzione di bug per questo.
3 Mi Piace
@dorina, questo è ora corretto con FIX: Incorrect lang mapping using non-symbols for LibreTranslate by nattsw · Pull Request #238 · discourse/discourse-translator · GitHub. Puoi scegliere di aggiornare il tuo plugin per questa correzione.
4 Mi Piace
Questo argomento è stato chiuso automaticamente dopo 2 giorni. Non sono più consentite nuove risposte.
