Leider musste ich den Stecker ziehen
That’s, frankly, a pain on mobile.
5 „Gefällt mir“
I count a single click:
I definitely understand the frustration with old-school users who don’t like change, and certainly the 502 errors. It would be good to hear server stats because it sounds like the server was underpowered for a community of this size.
We also have a fair number of reports of traditional ads not doing well on Discourse @neil. It might be worth drilling into a few of those specifically to get to reasons.
15 „Gefällt mir“
It is?
Assuming you’re not looking to just blindly quote whole posts verbatim every time, how would you make select and tap any quicker?
3 „Gefällt mir“
Try quoting several paragraphs, especially on small devices where you have to scroll off of the visible area of your screen.
Definitely a pain.
4 „Gefällt mir“
Why would you need to quote that much? That’s a bit of an anti-pattern in a community.
You know quotes can be dynamically expanded in Discourse, right? For example click or tap the title bar of this quote to see what I mean ↓
5 „Gefällt mir“
I’m aware, but if you’re trying to pick out two or three paragraphs at a time out of ten or so, it can be a pain on mobile to keep scrolling and hope it doesn’t drop you when you finally get there.
Plus, quoting an entire multi-paragraph post and then breaking it up or editing out parts manually is really not fun compared to other architecture.
You can also press the first button in the toolbar of the editor to do a full quote if you really want to go there.
That’s two clicks / taps, one to initate a reply, then another to the first button in the toolbar.
5 „Gefällt mir“
I know, mostly forum software has this option too.
But its still confuse for those who uses IPboard, Xenforo, PHPBB etc, who still majority on the internet when you talk about forum platforms.
When you click ‘reply’, then click ‘quote’ inside editor its a two-click quoting.
Even in Twitter you can easily quote someone with just a click.
No, that won’t be happening, sorry. If you need that I suggest switching to different software.
The idea is that it’s abusive to all future readers to quote too much content. And it is. So this friction is intentional.
25 „Gefällt mir“
I’m not sure “it doesn’t behave the same way as old software” is really a good reason to mimic any particular behavior.
AFAIK Discourse isn’t trying to be those products.
9 „Gefällt mir“
I absolutely understand you, when a post already has a quote on it/multiple quotes it can get really big.
But as I have seen on other platforms (especially in IPBoard, also in NodeBB who uses infinite scroll), you only quote the text (1) in the post, not the whole thing with another quote inside it. Also, If someone quote a really big post, you need to expand to see it (same behavior i seen on embed topics in Discourse).
That was the behavior that @eesty was talking about.
Also, I really like that Discourse hide quotes when you reply someone above and your concern to make topics easy and clean to read.
Some members from my forum really like this way and others are trying to get used to it (manual quoting for early replies). Do you think if its possible to replicate it with a plugin and make it a option? I was not necessarily talking about putting in the core. :sweat_smile:
kmm
Don’t take it is a insult. I really like Discourse. :wink:
2 „Gefällt mir“
I’m not insulted in the slightest, and this isn’t uncommon. From time to time people post about how much better Discourse would be if it emulated feature X from product Y, whose roots are ~15 years in the past.
The thing which drew me to work with Discourse initially was that it’s not trying to be any of those things. If it was then half of the communities I work with wouldn’t be able to do the things Discourse enables.
10 „Gefällt mir“
I suppose there might be one case where auto-quoting makes sense: when replying to a post which occurs mid-way through a long topic.
Without the quote, it’s hard to see the context, as there may be many posts between the “source” and reply post.
Perhaps it would make sense for Discourse to automatically quote (but only in this case)
1 „Gefällt mir“
Great that you did not take it as an insult, I really think you guys are a step ahead from the other softwares (and I’ve tested plenty). I spent more than 1h per day here trying to learning more and more. The possibilities here seem endless.
I have no complaints at all. Team/staff also is so helpful.
Just the quote-think that are getting some members confused and I’m trying to listen all of them and make it comfortable for everyone… seeing the possible to replicate it with a plugin on marketplace and make it a option. Do you think its possible?
Isn’t that what this button is for? It’s automatically generated for any reply made where posts sit between the post and a response.
10%20PM
When clicked it shows an embedded version of the post being responded to, without losing place in the topic. There’s an arrow in the embed to take you back to the reply in question too.
7 „Gefällt mir“
I agree with you. But not the whole thing (multiple quotes in one) as i said.
On mobile it take you to the post. If you reading post #88 per example, and that person replied post #33 without quoting, you click on it to see the reply and get redirected. Then you need to scroll back or click on “BACK” button to continue reading. If you do this several times, it can be exhausting.
1 „Gefällt mir“
Yes, those features are very useful. But they require a) the user to be aware of them and b) clicking to reveal the context
Late replies without quoting can make a topic can look confusing to the layman. Example (the “yes me” in the below topic, which references a post made earlier in the topic):
I’d suggest Discourse should have auto-quoted the “yes me” post, but avoided auto-quoting the “count me in too Chris”, as this reply came soon after its target post.
2 „Gefällt mir“
This catches me out frequently. You really have to be alert and cross check the avatar to make sure you’re reading it correctly.
3 „Gefällt mir“
Lol, reading this post I made I now understand why @codinghorror get annoyed
Fortunately @ChrisBeach show up to explain in a more intuitive way
Auto-quoting just early replies (the text, not quotes on it) would be great. Just want to know if it’s possible with a plugin too.
4 „Gefällt mir“
