Unknown Primary Key
When I try to login I get:
Started POST "/session" for <IP> at 2023-04-07 20:57:15 +0000
Processing by SessionController#create as */*
  Parameters: {"login"=>"<user>", "password"=>"[FILTERED]", "second_factor_method"=>"1", "timezone"=>"<TIME_ZONE>"}
start
done
Completed 500 Internal Server Error in 161ms (ActiveRecord: 0.0ms | Allocations: 154577)
ActiveRecord::UnknownPrimaryKey (Unknown primary key for table posts in model Post.)
lib/freedom_patches/ams_include_without_root.rb:49:in `include!'
app/controllers/application_controller.rb:496:in `serialize_data'
app/controllers/application_controller.rb:505:in `render_serialized'
app/controllers/session_controller.rb:714:in `login'
app/controllers/session_controller.rb:341:in `create'
app/controllers/application_controller.rb:397:in `block in with_resolved_locale'
app/controllers/application_controller.rb:397:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
lib/middleware/anonymous_cache.rb:358:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/request_tracker.rb:198:in `call'
Also when trying to open other topics I get:
Started GET "/t/le-numerique-alternatif-et-ecologique-murena-e-os-fairphone-telecoop-commown/48638" for <IP> at 2023-04-07 20:56:40 +0000
Processing by TopicsController#show as HTML
  Parameters: {"slug"=>"le-numerique-alternatif-et-ecologique-murena-e-os-fairphone-telecoop-commown", "topic_id"=>"48638"}
Completed 500 Internal Server Error in 11ms (ActiveRecord: 0.0ms | Allocations: 3093)
lib/freedom_patches/fast_pluck.rb:59:in `pluck'
lib/freedom_patches/fast_pluck.rb:52:in `pluck'
lib/topic_view.rb:143:in `initialize'
app/controllers/topics_controller.rb:89:in `new'
app/controllers/topics_controller.rb:89:in `show'
lib/middleware/anonymous_cache.rb:356:in `call'
Maybe your Satan’s didn’t get migrated?
You can try
rake db:migrate
You don’t have skip post migrations set, do you? Is this a standard install?
It was docker setup and Discourse was running fine, I just exported the Docker container and imported it on another server along with the /var/discourse and started it, that’s all.
I also executed rake db:migrate but didn’t help.
Did you restore the backup?
Have you tried a rebuild?
I don’t think the database files are inside the container, so postgresql is likely to be missing the discourse database if not the entire set of database files.
A restore should fix it, as standard postgresql restore should create the discourse database. (But if that fails, try creating the database then do a restore.)
That isn’t the correct way to Move your Discourse Instance to a Different Server and will never work.
