Ja, das funktioniert bei mir!
Das Problem tritt weiter unten auf. Es sieht so aus, als ob MaxMindDB aufgrund des Fehlers „Invalid license key“ fehlgeschlagen ist. Oh je!
Wie kann ich MaxMindDB für mich deaktivieren? Gibt es eine einfache Möglichkeit?
Done 'Done compressing all JS files' : 73.95 secs
rake aborted!
NameError: undefined local variable or method `name' for main:Object
/var/www/discourse/lib/tasks/assets.rake:296:in `rescue in block (2 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:285:in `block (2 levels) in <main>'
Caused by:
OpenURI::HTTPError: 401 Error: Invalid license key
/var/www/discourse/lib/file_helper.rb:76:in `block in download'
/var/www/discourse/lib/final_destination.rb:503:in `block (3 levels) in safe_get'
/var/www/discourse/lib/final_destination.rb:502:in `catch'
/var/www/discourse/lib/final_destination.rb:502:in `block (2 levels) in safe_get'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/net-http-0.2.2/lib/net/http.rb:1626:in `block in transport_request'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/net-http-0.2.2/lib/net/http/response.rb:185:in `reading_body'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/net-http-0.2.2/lib/net/http.rb:1625:in `transport_request'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/net-http-0.2.2/lib/net/http.rb:1579:in `request'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rack-mini-profiler-3.0.0/lib/patches/net_patches.rb:19:in `block in request_with_mini_profiler'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rack-mini-profiler-3.0.0/lib/mini_profiler/profiling_methods.rb:46:in `step'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rack-mini-profiler-3.0.0/lib/patches/net_patches.rb:18:in `request_with_mini_profiler'
/var/www/discourse/lib/final_destination.rb:463:in `block in safe_get'
/var/www/discourse/lib/final_destination.rb:517:in `block in safe_session'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/net-http-0.2.2/lib/net/http.rb:985:in `start'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/net-http-0.2.2/lib/net/http.rb:628:in `start'
/var/www/discourse/lib/final_destination.rb:515:in `safe_session'
/var/www/discourse/lib/final_destination.rb:455:in `safe_get'
/var/www/discourse/lib/final_destination.rb:147:in `get'
/var/www/discourse/lib/file_helper.rb:68:in `download'
/var/www/discourse/lib/discourse_ip_info.rb:39:in `mmdb_download'
/var/www/discourse/lib/tasks/assets.rake:287:in `block (3 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:286:in `each'
/var/www/discourse/lib/tasks/assets.rake:286:in `block (2 levels) in <main>'
Tasks: TOP => assets:precompile
I, [2022-05-11T18:45:44.667046 #1] INFO -- : Checking 'Nav Links Component' for 'default'... up to date
Checking 'Add Category Column' for 'default'... yarn run v1.22.18
$ /var/www/discourse/app/assets/javascripts/node_modules/.bin/ember build -prod
WARNING: Node v16.14.2 is not tested against Ember CLI on your platform. We recommend that you use the most-recent "Active LTS" version of Node.js. See https://git.io/v7S5n for details.
Environment: production
cleaning up...
Built project successfully. Stored in "dist/".
File sizes:
- dist/assets/admin.js: 1.12 MB (142.42 KB gzipped)
- dist/assets/chunk.143.eacfec4026458f86213f.js: 2.52 KB (1.14 KB gzipped)
- dist/assets/chunk.178.aa554047edf14ebffd85.js: 1.93 KB (1004 B gzipped)
- dist/assets/chunk.682.942bbb3c080f6e2e15a9.js: 800.65 KB (272.68 KB gzipped)
- dist/assets/chunk.920.296a50b5adf700c42f3e.js: 279.42 KB (85.84 KB gzipped)
- dist/assets/core-tests.js: 1.68 MB (231.55 KB gzipped)
- dist/assets/discourse-markdown.js: 349.56 KB (91.04 KB gzipped)
- dist/assets/discourse.js: 2.76 MB (528.16 KB gzipped)
- dist/assets/highlightjs/highlight-test-bundle.min.js: 147.39 KB (42.92 KB gzipped)
- dist/assets/scripts/discourse-boot.js: 689 B (427 B gzipped)
- dist/assets/scripts/discourse-test-listen-boot.js: 423 B (297 B gzipped)
- dist/assets/scripts/module-shims.js: 507 B (278 B gzipped)
- dist/assets/scripts/start-app.js: 164 B (160 B gzipped)
- dist/assets/start-discourse.js: 1.18 KB (625 B gzipped)
- dist/assets/test-helpers.js: 1 MB (146.36 KB gzipped)
- dist/assets/test-i18n.js: 475.76 KB (113.89 KB gzipped)
- dist/assets/vendor.css: 0 B
- dist/assets/vendor.js: 999.61 KB (268.74 KB gzipped)
- dist/javascripts/@json-editor/json-editor/2.6.1/jsoneditor.js: 425.11 KB (79.36 KB gzipped)
- dist/javascripts/Chart.min.js: 169.02 KB (51.67 KB gzipped)
- dist/javascripts/ace.js/1.4.13/ace.js: 363.09 KB (98.66 KB gzipped)
- dist/javascripts/ace.js/1.4.13/ext-searchbox.js: 11.63 KB (3.49 KB gzipped)
- dist/javascripts/ace.js/1.4.13/mode-html.js: 59.46 KB (17.82 KB gzipped)
- dist/javascripts/ace.js/1.4.13/mode-scss.js: 23.47 KB (7.79 KB gzipped)
- dist/javascripts/ace.js/1.4.13/mode-sql.js: 4.73 KB (1.82 KB gzipped)
- dist/javascripts/ace.js/1.4.13/theme-chaos.js: 3.11 KB (1.01 KB gzipped)
- dist/javascripts/ace.js/1.4.13/theme-chrome.js: 2.97 KB (1.03 KB gzipped)
- dist/javascripts/ace.js/1.4.13/worker-html.js: 203.22 KB (46.33 KB gzipped)
- dist/javascripts/ace/ace.js: 362.06 KB (98.41 KB gzipped)
- dist/javascripts/ace/ext-searchbox.js: 11.63 KB (3.49 KB gzipped)
- dist/javascripts/ace/mode-html.js: 59.46 KB (17.82 KB gzipped)
- dist/javascripts/ace/mode-scss.js: 23.47 KB (7.79 KB gzipped)
- dist/javascripts/ace/mode-sql.js: 2.16 KB (1009 B gzipped)
- dist/javascripts/ace/theme-chrome.js: 2.97 KB (1.03 KB gzipped)
- dist/javascripts/ace/worker-html.js: 203.22 KB (46.33 KB gzipped)
- dist/javascripts/chart.js/3.5.1/Chart.min.js: 183.95 KB (63.67 KB gzipped)
- dist/javascripts/chartjs-plugin-datalabels.min.js: 12.76 KB (5.23 KB gzipped)
- dist/javascripts/chartjs-plugin-datalabels/2.0.0/chartjs-plugin-datalabels.min.js: 12.59 KB (5.09 KB gzipped)
- dist/javascripts/count.js: 1.41 KB (636 B gzipped)
- dist/javascripts/diffhtml.min.js: 26.98 KB (9.88 KB gzipped)
- dist/javascripts/diffhtml/1.0.0-beta.20/diffhtml.min.js: 26.98 KB (9.88 KB gzipped)
- dist/javascripts/embed-topics.js: 1.31 KB (630 B gzipped)
- dist/javascripts/embed.js: 2.35 KB (993 B gzipped)
- dist/javascripts/jquery.magnific-popup.min.js: 19.74 KB (7.18 KB gzipped)
- dist/javascripts/magnific-popup/1.1.0/jquery.magnific-popup.min.js: 19.74 KB (7.18 KB gzipped)
- dist/javascripts/media-optimization-worker.js: 4.89 KB (1.71 KB gzipped)
- dist/javascripts/pikaday.js: 40.11 KB (9.08 KB gzipped)
- dist/javascripts/pikaday/1.8.0/pikaday.js: 40.11 KB (9.08 KB gzipped)
- dist/javascripts/squoosh/mozjpeg_enc.js: 38.12 KB (10.49 KB gzipped)
- dist/javascripts/squoosh/squoosh_resize.js: 4.42 KB (1.26 KB gzipped)
- dist/javascripts/workbox/workbox-cacheable-response.dev.js: 6.58 KB (1.73 KB gzipped)
- dist/javascripts/workbox/workbox-cacheable-response.prod.js: 579 B (345 B gzipped)
- dist/javascripts/workbox/workbox-core.dev.js: 48.27 KB (11.21 KB gzipped)
- dist/javascripts/workbox/workbox-core.prod.js: 5.75 KB (2.42 KB gzipped)
- dist/javascripts/workbox/workbox-expiration.dev.js: 20.83 KB (5.48 KB gzipped)
- dist/javascripts/workbox/workbox-expiration.prod.js: 2.82 KB (1.22 KB gzipped)
- dist/javascripts/workbox/workbox-routing.dev.js: 31.54 KB (7.58 KB gzipped)
- dist/javascripts/workbox/workbox-routing.prod.js: 3.32 KB (1.44 KB gzipped)
- dist/javascripts/workbox/workbox-strategies.dev.js: 34.65 KB (4.79 KB gzipped)
- dist/javascripts/workbox/workbox-strategies.prod.js: 4.75 KB (1.16 KB gzipped)
- dist/javascripts/workbox/workbox-sw.js: 1.3 KB (741 B gzipped)
Done in 127.24s.
Downloading MaxMindDB...
Compressing Javascript and Generating Source Maps
I, [2022-05-11T18:45:44.667510 #1] INFO -- : Terminating async processes
I, [2022-05-11T18:45:44.667572 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main pid: 1700
I, [2022-05-11T18:45:44.667643 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 1828
2022-05-11 18:45:44.667 UTC [1700] LOG: received fast shutdown request
1828:signal-handler (1652294744) Received SIGTERM scheduling shutdown...
2022-05-11 18:45:44.669 UTC [1700] LOG: aborting any active transactions
2022-05-11 18:45:44.672 UTC [1700] LOG: worker process: logical replication launcher (PID 1709) exited with exit code 1
2022-05-11 18:45:44.673 UTC [1704] LOG: shutting down
1828:M 11 May 2022 18:45:44.695 # User requested shutdown...
1828:M 11 May 2022 18:45:44.696 * Saving the final RDB snapshot before exiting.
2022-05-11 18:45:44.713 UTC [1700] LOG: database system is shut down
1828:M 11 May 2022 18:45:50.327 * DB saved on disk
1828:M 11 May 2022 18:45:50.327 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 2323 exit 1>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
7a971495e73d4bf35d7f5ef771bfc2c652657c57d667336d3b932b798282816a
